-September 2024 Special Lease Deals-
Also, when I am backing into my driveway or parking spot and turn the wheel there is a knocking or popping sound from the front suspension. Anyone else know this sound? It is driving me crazy. Dealership says nothing wrong.
Did I mention the sounds is making me crazy?
Sure love the V6 motor though....amazing.
My Limited with the JBL system only has ASL on/off.
:confuse:
When I picked up the car at 6:30 PM yesterday (9/1/06) I did not hear any evidence of the droning noise when I started the car. I drove it home (about 13 miles) and made a couple of stops along the way and heard no droning during that entire drive so it seems to be fixed because in the past I would hear at least some droning every time I drove it. I did not drive it today, but probably will tomorrow and I'm keeping my fingers crossed that this is a permanent fix. I hope this helps those of you dealing with the droning problem. I will still keep folks posted as to the continuing absence (hopefully) of the noise and also let you know if it returns.
What Toyota basically did was charge for a Premium Radio and installed some piece of junk :mad: :mad: :mad:
Pete
My wife and I went to a dealership in July test drove the V6 Rav4. We drove the Silver Rav4 for a while then went back to the parking lot; we stayed in the car for over 20 minutes per request of the sales person (he's helping someone else); then we heard the droning noise after about 5 minutes sitting in the car in Park mode; the noise continued for over 10 minutes until I shut the engine off. We thought it was this particular car being damaged by abusive driving thus didn't pay too much attention.
We bought a Pacific Blue Limited Edition Rav4 V6 4x4 fully loaded in August, so far I have put on 1000 miles on it. We've noticed that after the car is being running for a while, the droning noise is usually heard at stop in front of red lights, once I start driving again, the noise goes away. My wife believes the noise is coming from the rear of the car, hopefully Toyota have a fix soon.
As best as I can figure the warning light comes on with 3 gallons left in the tank. Is this correct?
Tank is 15.9 gallons. No problems with the car and I change the oil every 5000 with Mobil 1 0-20 weight.
take forever. Sometimes it comes up with "Error 3".
It just seems to get confused every so often. Anyone else
run into this? :confuse:
I've got about 6k miles on my RAV4 and, so far, this is about my only complaint, except for poor gas mileage. I've had absolutely no problems so far with the vehicle. I love this car. And that's saying a lot since the last two cars I owned were BMWs. My only large complaint is that I'm not getting the mileage promised. In the city I get about 23 mpg, which is OK. But on the highway I only get about 27mpg, without the A/C. With the A/C on, I only get about 26mpg.
I though that mileage would be considered good. Is that for the V6?
The mileage I quoted is for a 2006 4cyl 2wheel drive. I find it interesting to note that the 2007 is now rated at 23mpg city/28mpg hwy vs. the 2006 rated at 24/30.
I had a service tech test drive it with me this morning and he said it was behaving normally for this type of vehicle.
I had a VW Passat and it had a great ride.
I asked during maintenace if I had a problem. The tech told me this was at a shift point speed and that's why it happens. He suggested I just ignore it or drive faster. I have to drive at that speed into my subdivision for about 2 miles, so maybe that's why I notice it.
Has anyone else had this problem?
Gil
When mine does it it's coming from beneath the floor behind the driver's seat, as far as I can tell anyway, since I have to have the car in gear to hear it. It's not particularly loud and not something it does often so it doesn't bother me. But at least an explanation of what it is would be nice to have.
Not only I have the annoying droning sound, when driving at parking lot speeds, turning into parking stalls or just going around the corner, the frontend creeks. Also the transmission tends to hesitate finding the gear it wants, after braking around Yield corners and then pressing the gas pedal.
Last but not least, two weeks after taking possession of the Rav, backing out of the driveway - on dry summers day - the Slippery surface symbol flashed on the dash (6 occasions) as if to tell me the road was slippery....it surely was not. It hasn't happened since.
I took it to the dealer today. He hadn't heard of the droning noise, so he says. I explained the hesitating gear change also happened on my 2002 Camry, the car now gone; the shop foreman told me the Camry had a software update to fix the problem. He's going to check with Japan if there's one coming out for the 2006 Rav4.
As for the front end creaking noise, the Shop foreman agreed that it's not normal, as is the droning noise. He ran a scope on the truck during our test drive to see if there was any indication to why the slippery surface light came on - nothing was found.
To say the least, the car is booked for an inspection and they'll provide me with a service loaner car. I have to give that much to dealer, he's trying to get me answers to fix the things that shouldn't be.
So, if anyone discovers things happening that shouldn't be with their Toyota....take it into the shop. Toyota is working at becoming #1 in the world. so lets test them on their desires, challange them to make sure your car is #1.
Regards.
I have faith that Toyota will find a solution. Hopefully everyone that's having the problem will report it...strength in numbers!
I have also experienced the transmission hesitation, most often after I have slowed down to go through a toll booth on the bridge and then try to speed up to merge - there's a hesitation in the response of the transmission, the consequence being that the car doesn't get going very quickly. This could create a dangerous situation.
I have also had the slippery surface symbol light up 3-4 times at a certain gas station when I am pulling up to the pump - not always the same pump and the concrete surface is dry.
I don't experience any front end creaking noise, but I do hae some creaking on the dashboard. The plastic panel which surrounds the emergency flasher button is loose at the bottom (was when I bought the RAV4) and it rattles. I have stuck some clear plactic index tabs in the crack to stop the noise as it could get worse if they take the dashboard apart to try to fix it.
I'm still waiting for a call from the dealer to let me know what Toyota has decided to try next and when I can take the car in.
Anyhow, thanks very much for your post.
Yes, it does stop when you put it in P. However, I've noticed it doesn't stop immediately when going into P, but kind of quickly tails off. Go back into gear and it starts up again.
Any transmission hesitation when coming out of a corner I've chalked up to the tranny's eagerness to be in 5th gear as much as possible, but it isn't making much power at the low rpms that result. Step on the gas after a corner and you catch it napping and have to wait while it shifts down into 4th or 3rd.
Have not seen the skid control light flash except when I'm using the "hill holder" feature.
