The problem was never resolved. I went to two different dealerships and both said that they (and Toyota) were familiar with the issue and there was nothing Toyota could or would do. They attributed the problem to the 4 cylindar engine and said that it was normal, although my 4 cylindar Altima does not vibrate even with the AC on. I expect there is a problem with the engine mounts which should insulate the driver from the engine vibration. I have learned to live with the problem although it is annoying. Let me know if you ever get the problem resolved. Thanks
I hear a very intermittent whistle coming from the dashboard.
It can happen when starting the car, while driving, but mostly happens when stopped or right after the car is turned off.
It sounds just like a human whistle, one note, varied length, increasing in pitch. As if a gas is venting through a reed from the A/C.
I live on Maui and almost always have the A/C on. I took it to the Toyota Dealer here and they were unable to fix it and never heard it.
It's very intermittent and might only happen once a day or less.
Although my wife is enjoying the positive attention (the whistling) she's had enough. HELP please. Thanks.
I have a new 2009 2.5 liter sport with 500 miles on it.
Occasionally I hear a thud from the steering system when making 90 deg turns. I can also feel it through the steering wheel. It is next to impossible to reproduce, it just happens randomly when turning usually at slower speeds (under 10 mph).
Toyota service now has my vehicle and they just called to tell me they cannot reproduce the sound. The only other sign is a small hitch and release that I feel when turning the steering wheel while the car is turned off (keys out of the ignition, wheel is not locked). It feels like a small amount of resistance then release before the full resistance of turning the wheels while power steering is off.
I am very sensitive to noises especially from a new vehicle, and I fear that if Toyota does not find any signs I will have to live with it.
I have a similar problem on my 09. Did you feel anything through the steering wheel when the noise happened?
What was the source of the popping? My Toyota service is giving me the old " nothing is wrong with your vehicle"
Thanks i advance.
Tom
http://www.rav4world.com/tsb/2006/ST001-08.pdf
I picked up my vehicle from toyota service today (2009 sport 2.5liter). I mentioned the TSB to them and they stated that it does not apply to the 2009's and therefore nothing can be done at this time. They stated willingness to fix the problem if the noise was reproducible. Perhaps as more 09's are sold the problem will surface in other vehicles and lead to a TSB for the 09's. I wonder how long that would take to go into effect? Are the TSB's basically a recall?
"tendon twang" sounds like a description of what my Rav is doing during some slow turns. They (toyota) told me that the steering components have been redesigned since the 06's and therefore they could not act on the TSB. So you get it intermittently then? How often? Did you get used to it after a year? Im afraid I cant get use to something like that, but then again I may not have a choice...
Tom (sage3)
So how frequently do you hear the noise? Can you trigger it? Today again I tried another barrage of maneuvers to trigger the sound to no avail.
By the way the TSB Applicable Warranty*: reads as follows:
This repair is covered under the Toyota Comprehensive Warranty. This warranty is in
effect for 36 months or 36,000 miles, whichever occurs first, from the vehicle’s
in-service date.
I believe this means that once the repair is performed it is covered for 36 months or years.
Regards Tom
-K
I drove over 100 miles around the suburbs today with not one sound, but I am not getting my hopes up...
Let us know how the dealer responds to the TSB.
I think this should be a Toyota paid for recall. This is my second toyota and I was planning to purchase a third for my daughter but I think I'll shop Honda next time.
I am going to write to Toyota just to let them know how disappointed I am.
I agree canam1960, Toyota should post a recall since the flaw is in the design and even they admit it by posting the TSB. My noise started a few days after a brand new purchase. I currently own 2 toyota's, both purchased brand new, I also had a slightly used toyota highlander that I got rid of due to engine noise.
I will be purchasing a new vehicle for my wife within the next 2 years and I too will look to honda and/or subaru for our next vehicle.
Big question will be...are they going to say it is going to cost me ~$700?
I'll let you know.
-K
How many miles are on your Rav?
By the way my noise has diminished significantly over the last week. I may have heard a very small " twang" twice but if I was not looking for it I would have missed it. Go figure.
Cant wait to hear what happens with yours. When are you going in?
Tom
I have about 20K miles on my 2006 Rav4. I'm glad that you haven't been 'twangin' lately. Has the weather been warm? I've noticed that the sound happens much more frequently in colder weather. I have an appointment on October 27th to have the parts swapped. Wish me luck! I hope it doesn't make things worse...wouldn't that be a drag!
-K
The weather actually got colder so it's not reacting the way yours did.
Your mileage is low, if it has not been 3 years since your purchase you should still be covered by warranty for the fix.
And don't worry, now that they are doing something with it I doubt they will give you you're car in worse condition. \
Good luck anyway..
I don't think its the transmission because it doesn't seem to follow RPM's. Best guess is that something is heating up on the suspension causing front or rear calipers to paritialy stick then release?? Or hot rotor is warping??
I asked Mechanic to check CV joints and brakes but no luck.
Its driving me nuts - if its the tranny I need to start looking for a new car. I've heard the 2002 transmission/ECM has had many problems.
Any ideas on what the heck this noise could be appreciated.
As far as the large service interval charges, I totally agree. My dealership pushed for changing the air filter at 15k and showed me how dirty it was. Ditto on the cabin filter. Those were ahead of schedule You can do both of these yourself with little effort. I got a nasty look when I turned down the 30k service but did have them adjust the rear brakes. Now I am going in for a 40k service which is luckily only an oil change and tire rotation. I might bypass the 45k service at the dealer and take it to a quick lube and tune. I am trying to follow Toyota maintenance schedule in the book. I might do some of the fluid replacements at 60k. I haven't decided yet.
I have a 2006 and had the popping noise when I turned right or left at very slow speeds. In reading these posts, I appear lucky to have caught this before my warranty ran out. Other than that, I am happy with the vehicle.
Are you going to address it?
-K
I just wrote a 2 page letter regarding the 09 proplem to toyota. One is going to the customer experience center and I attached another to the post purchase survey that they sent to me.
Tom
-K
here is the link: http://www.rav4world.com/tsb/2006/ST001-08.pdf
I just overheard my service advisor talking to another service advisor. All I know for sure, and now I'm not sure of that, is that my 2006 RAV4 has a chain and not a belt.
Thanks in advance
Tom
I don't know what the whirring sound could be but if the light just means low tire pressure, that's an easy fix (assuming you don't have a screw in a tire like I did).
Check your owner's manual to double-check what the light means. If it looks sort of like this, then check your tires:
Sounds like your dealership didn't do their job. If I were you I would check all the fluids as well as the tire pressures.
Otherwise you might soon be involved in a rollover due to a partially deflated tire overheating and blowing out (think Ford Exploder).
Some, undoubtedly, will refer to the TPMS as being overly sensitive but I would much rather have the early warning of a potential tire problem.
Steve...you hit the proverbial nail on the head. That 'icon' you inserted is EXACTLY what the light is. After I posted, I called the gentleman at the dealership who goes over the features, etc. before you take the new car off the lot and he said it was the tire pressure. He even said it could be in the spare (that makes no sense to me). As the other repliers stated, I AM glad it came on to alert me, but it still infuriates me that I haven't had that car two weeks and am going on a long trip in two days, so I have to find someone to check/fill all tires. But, that is better than having a flat or worse, an accident. I'm sorry for the others who're experiencing this and worse. Steve, I'm so glad you resolved your problem before something happened to you...I had the same problem in a rental once; needless to say, I ended up renting it at no cost. ;-)
Again, thanks so much for the invaluable help. I feel much better, y'all. jude
