I just took a quick look around for that information and couldn't find it either. Maybe someone else with better luck or direct experience will be able to help out.
tidester
SUVs
http://www.cyu.com/2001_infiniti_qx4.htm
go there for other maintenance information.
Instructions from this site:
Changing the cabin microfilter is a bit complicated because the entire glove compartment
assembly must be removed to access the microfilters. The job should take about 30 minutes,
but worth the trouble. These filters trap small particles of dirt and pollen before it enters the
passenger cabin when the vent is open, essential for those with allergies. Start by removing the
two screws that hold the glove compartment latch and remove the latch. Remove the two screws
that hold the Infiniti molding, then remove the molding. You'll notice a screw that holds the glove
compartment that's been hidden from view unless the molding is removed. The Nissan directions
in the kit make no reference to this screw. Remove the two plastic hinge pins from the bottom of
the glove compartment. Remove the five screws that hold the glove compartment. Separate the
glove compartment light from the housing. Using a flat-head screwdriver, pop off the clip and
remove the dirty filters and replace with new clean ones, inserting the first one on the bottom and
pushing to the top. Follow with second filter and snap clip into place. Reverse directions until
every screw is tightened.
Infiniti scheduled service makes no mention about replacing this, but the filter kit says to replace
every 6 months or 7,500 miles. I would agree because I pulled mine after one year and 15,000
miles of use and it was filthy! The Nissan part number is B7200-0W010 ($35), and I would steer
clear of Infiniti dealers on this one because they want $60 for the same part. I noticed it was
available from various online Nissan shops for $28, but add shipping and it's back to $35 again.
Save yourself some hassle and money and buy it from a Nissan dealer.
mthomas3
mthomas3
tidester
SUVs
I am most worried about them scratching the interior with screw drivers each time they take it apart to replace a filter. And the subsequent rattles and mis-alignment of the door parts.
Thanks again.
After reading how hard it is to do the oil change, I plan to use the dealer for that. Dealer charges $19.95, and also sent me a ton of service coupons for $10 off.
Mthomas3
If you cannot get the filter off and punch a hole in it with a screwdriver, I have seen several cases where the filter collapses or the screwdriver just tears through the metal. Then think of what you have, a car that you cannot put oil back into to get it to a garage or to a parts store to get the proper tool. Where I have personally seen this happen, it resulted in the car hanging off of the back of my father's tow truck.
Do yourself a favor, get the right tool!!!!! There are several types of filter wrenches that will work.
I also do not have to remove a crossbar as mentioned, but I have a 1999.
It is a bit messy taking the filter off. Get a drain pan ($5.00 - $7.00) that has a large "drain tray".
The web site in the above post has good info, not trying to flame the guy. It is just a back-yard mechanic trick that can really backfire on you.
We ended up with a Titanium AWD QX4 with Premium, Sport, Roof, & deflector. We're both very happy with the truck. It's been great! In the end, drive all 3 and see which suits you best; they're all good vehicles. Good luck.
2002 QX4 Sand something in color
Prem Pkg
Sport Pkg
Sunroof
Towing Pkg
Gold Emblemming Pkg
Wind/bug deflector
Temporary permit (good for 10 days)
$45,609.00 Canadian dollars - excluding tax which I will get back from Canada
$28,684.90 US dollars ($1.59 exchange rate)
$763 US dollars duty tax
I still cannot believe the deal. Canada is definitely the way to go. If you want more info on getting the best rate, dealer info, and transferring the $ into the dealers account, email me at garthfan@mediaone.net
Diane
Diane
It must be a fantastic vehicle since you apparently didn't even notice those pothole-rich roads of Western New York!
tidester
SUVs
Congrats from here too. I hear back from people on this all the time, but you have now set the all-time record for amount saved by going to Canada! For those of you without the calculator handy, the total cost for that QX4 including everything is still under $30,000. This is why I like helping out on this - I just love to see happy people.
-Jon
Send me an email and I will send off all the info you'll need about buying in Canada along with the dealer info. I really don't want it to look like advertising here (and he's a manager and I don't think likes to see his name on the net). Since I bought from him I know of about thirty others who have also. For more success stories, scroll up here or over at the Pathfinder and Maxima boards. I have a count of 60 so far. Diane of course is the latest and she probably will have some good input too.
As far as other makes, you may not have much luck anymore. Most of the manufacturers have stopped allowing their Canadian dealers from selling to US customers. This includes Toyota, BMW, Honda/Acura, GM, Audi, Volkswagen, and more. I guess it keeps the prices higher here (and the US dealers happy).
-Jon
Diane
Sorry if this is off-topic, but it a boat was a factor in buying my QX4.
thanks,
I have looked at the suspension and the tie rod ends are nice and tight. Everything seems OK under the front. It appears to be some play in the steering box. I have wiggled the steering column where it goes into the steering box and there seems to be a little play there. (I know that some is normal)
Is this a "truck thing"? I am used to driving sport sedans, and am very sensative to things like this.
Is this normal steering play for a '99?
It is true. The QX4 has rear drum brakes. There is no option for rear discs.
This was a matter of concern for me when looking at QX4s, however, I read several reviews that mentioned this and also stated that it was unnoticable.
Well, I bought a QX4 (99) and I would agree. The braking seems fine for a vehicle of its weight.
I would have to agree that it is a poor choice on Infiniti's part. I personally would be willing to pay more for 4W discs if it were available as an option. As far as I know, all of the other SUVs in this quality class have 4W discs.
I drive a 2000 PF and have not been unhappy with braking performance. Nonetheless, it would be interesting to see a comparison of mid-size SUV's on braking performance ...
320cobra
they seem to be equivalent in pricing. does the money give you comparable options/amenities. and anyone know about the reliability of dicovery compared to the qx4?
thanks...
I found the Discovery's driver compartment to be extremely cramped. I am 6' 1' 198 lbs, so a little bigger than average, but not really big. I do have big feet though (14) and that may have been part of my problem.
With the seat all the way down and back I could not get my foot on the brake pedal without having my thigh HARD against the steering wheel. I mean to the point that when I went for the brakes, I turned the wheel to the right. That immediately knocked it out of contention for me.
I also found the ergonomics to be pretty bad. Especially the layout of the center console. This may be part of the fact that I just did not fit well in the vehicle. This will be a personal thing so I recommend that you sit in both vehicles and do some shifting around like you would during a long trip. See if it fits you.
On the plus side, it had very good head room. I also liked the "safari" styling.
Check the Consumer Reports Used Car Buying Guide. It will give you reliability ratings.
I have a chrysler with 4 wheel disks and ABS. in 97 they were optional. I was surprised when I rented an identical car with drums, and the drums stopped better. I had dealer replace pads and resurface disks on mine, but it did not help much.
On that car, I wish I had the drums.
-Jon
I contacted an Infiniti dealer in Vancouver and they were adamant about not selling a new vehilce bound directly to the US. Said Infiniti has asked them not to do this practice. I tried another Infiniti dealer just outside Vancouver and they stated that they do it quite often but need a broker to handle all the paperwork (etc...) even if I physically came up and picked it up. The funny thing is that they could not recommend anyone.
Oh well, here are some open questions I have about purchasing in Canada:
1) Are there any problems (or extra procedures required) having service done under warranty at an Infiniti dealer here in the US?
2) What about resale values, will they be lower even if sold in the US years down the road since the vehicle was purchased outside the country?
3) Where do you go to get the speedometer/odometer fixed so they read in miles? Approximately how much does it cost to adjust everything to miles instead of kilometers?
4) How much is Canada's sales tax? I know it is refunded but just want to get an idea...
Jeff
I don't know what mail client you are using but I find that with the one I use mail bounces if I don't manually remove the "mail to:" prefix that gets inserted when you copy the mail address link.
You might try removing the prefix in your emailings and see if that makes a difference.
tidester
SUVs
320cobra
1. No problem with the warranty work in the US. You get the warranty transfered over.
2. Resale should be the same - it's the same vehicle. Many of the used cars in the Seattle area are coming from Canada.
3. The speedo is in km and miles; the odo in miles. You don't have to change them. But they can be changed by any speedometer shop. Figure around $300.
4. The Canada national GST sales tax is 7%, but it gets refunded when you bring the vehicle to the US.
I still don't understand why a number of the Canadian Infiniti dealers are so clueless about selling cars to US people. I'll send you the name of the manager at the one in Vancouver that everyone uses - over twenty at that place alone. No, you don't need a broker to bring the QX4 to the US.
-Jon
I have a 2001 QX4, now with nearly 2000 miles. I noticed some strange shifting before it warmed up in first 3 miles of driving. At about 1100 miles, I changed transmission fluid. This made a major improvement. There is a drain fitting on the transmission pan that makes it easy.
I refilled with Mobil 1 synthetic ATF (Dexron III). This runs about $5 per quart. Trans holds a total of 9 quarts, however, the drain will remove only 5 quarts plus 7 ounces. I noticed that the old fluid was dark and stinky, which surprised me due to the low milage and easy break in driving. This made an immediate improvement. I did a second change out a week later to get more of the old stuff out.
I think that Nissan uses a strange fluid, but manual lists Dexron III as acceptable. Synthetic works much better cold, and has better high temp operation also.
Transmission now shifts just fine, no shudder or anything unusual. Hope this helps.
The service manager looked at mine yesterday, and checked the strut part numbers as well as the VIN. It appears that mine was either corrected at the factory or the dealer before delivery as I already had the new version parts. He said that a few QX4s that did get recall notices had already been updated, so they check every one when they come in to save time.
Guess I should not have worried about it.
ace
eircgr - You are exactly right, a QX4 is NOT a car and should not be driven like one. There is extra weight and a higher center or gravity. The AWD is a great safety feature that should be used.
ace - The clunk (a bit unnerving at first), is the electronic clutch in the center differential disengaging and is normal. I have seen posts where people say "Auto" is the same as 2WD unless a wheel slips. Obviously not, since the clutch is engaged as soon as Auto is selected.
Enjoy your QX4s - took mine into the mountains yesterday for a day trip. A little bit of snow, very sure footed.
Patti
