I've owned this truck scince new, and i've gone up against a few other rangers of the same yr and same options...its alot faster when new you couldn't stop pedal down on dry pavement and get em to spin over or pull next to a 4.3 S-10 and spank em in such a way that they are left wondering if you dropped a V8 in the confines of the V6 engine bay..it idles like its been cammed its low end torque feels like its been cammed. my neighbor down the street has the excact truck same options with 4wheel drive and auto just like mine, he's driven it..now he wants his as fast...
Ok I see where your coming from now on the power issue now that you have explained it better. All you have had is an engine change so I doubt that the PCM has been modified with a power chip. There is a chance that some upgrade was done on that motor you now have. If it idles like it has a cam upgrade and now you have a comparison vehicle that has less power. You probably have a cam upgrade in your motor. To my knowledge, even though various years used the same engine, there isn't suppose to be any improvement in power in the newer stock engines. Hey, you lucked out....enjoy!
I have had the same problem for a while now. But now when i accelerate under load the engine stutters severely. The engine also stutters while in third gear at about 35mph.
Sounds like you have a bad TPS(throttle positioning sensor. Here is how you check it. KOEO key on engine off. Verify 5volt referance at sensor. Looking at the back of the 3 wire plug, this is what each wire is for. 5v TP signal PCM(-). Location is mounted on throttle body on the other side of you throttle linkage. As throttle linkage moves, it turns this potentiometer. Works similar to a dimmer switch. All this testing is done with the key on engine off.
This should be checked with a digital graphing meter but a DVM can be used. If you have your 5v referance, and ground, then check the middle wire for voltage while the throttle position is in idle position engine off. The voltage should be between .7volts to 1.1volts. While still conected move the throttle by hand smoothly. You should read a smooth increase in voltage at the middle wire (tp signal) When you reach WOT wide open throttle the voltage should be about 4.5volts. (engine off, key on) Understand that there is an allowable differance in referance voltage and ground of .2-.3 volts depending on the equipment being used. So if your referance voltage is 5.2 volts or 4.8 volts, thats still ok.
While in the idle position if your reading higher voltage than 1.1v, then your PCM thinks your demanding additional throttle. Some TPS are adjustable with slotted hold down screws, but most likely your tps is defective. Good luck, get back to me and repost.
Hey All! I have a little issue with :confuse: my idle. Here's whats happening; the engine starts just fine when cold, the idle is at around 1050 rpm's then after about 20 seconds or so it drops to around 750 r's this is normal. Now that the engine is warmed up, like after the ride to work (20 miles or so) shut it off and everything is fine until break time (2 hrs. later) start the engine and it returns to high idle and then about 2 seconds later the idle drops to about 100 rpm's (barely running!) but doesn't actually stall, this usually lasts about 2 to 3 seconds before correcting itself and returning to normal idle speed. This has been happening since around 90'000 mi. Truck now has 97000 on it. I'd appreciate any insight anyone has to offer on this annoying little "issue." Thank You.
Sounds like a bad IAC valve [idle air control valve]and or build up of carbon in the throttle body intake. If there are no trouble codes, this is what I would check first.
i have a 94 4wd 5-spd 4.0. i just replaced the spark plugs and wires and i saw a good jump in gas mileage. i was getting 15 mpg city before and now i am getting 18.5 city. not too shabby for a older 4wd.
I have a 95 4litre ranger and my oil has smelled like gas the last couple oil changes, its not starting hard so its not flooding itself just noticed the smell in the oil, anyone know how to troubleshoot this proble?
hi i have a 94 ford ranger splash that is overheating only when i stop and idle for awhile.it doesn't completely overheat the temp gauge goes way up.i have a feeling it is the water pump.anyone know a way to test it without changing it? :confuse:
If it is indeed the water pump you will probably notice a leak at the base of the fan and/or some noise coming from that area. Sounds more like you have a blockage somewhere or a radiator that needs replacing. Kind of hard to tell without looking.
I have a 98 ranger 4.0L with 130,000 miles. It recentley started making a squeeking sound while at idle,almost sounds like a belt slipping,Well it seems I have located the noise I traced the noise with a stethoscope to the back top of the intake is there anything back there that could be making this sound..Any ideas will help ..Thanks
ive recently started having problems with my 2000 ford ranger it is idling eratically, hard to start, isnt accelerating like it should, is runnin rich, and occasionaly tries to die on me ive done a tune up replaced all my filters, plugs, oil, tps, O2 sensors and my thermostat due to a coolant leak havent found the leak yet but it doesnt appear to be seeping into my oil yet no milky color and the truck only smokes when i first crank it up after it warms up she seems to run fine except at an idle im thinkin either my eec or my egr but would love some feedback
I bet the smoke when you first start it up is black or dark brown. If so, there is too much fuel entering the engine. A leaking or stuck open fuel injecter or a vaccum leak in the fuel pressure regulator diaphram will introduce excessive fuel into the engine. The easiest thing to check is the fuel pressure regulator. Pull the vac line off and look for evidence of raw fuel inside the vac line and or diaphram. Is there a check engine light on? Unfortunately, the most common is a leaking fuel injecter. To check for this you need a fuel pressure gauge. You have to pinch off or block the return fuel line. Hook up the guage and turn the key to on (run position). See if the pressure bleeds off. The pressure should be arround 35-40psi. Good luck.
O.K. O.K. YER NOT GONNA BELIEVE THIS 1...I posted #130 "LOW POWER ALSO" .......That the B2300 4 cylinder 5 Speed Overdrive 2WD would only go 80 @ about 3000 RPM....That was about a month after I bought it.. Where I live the top speed limit is 45..... So last week on Monday the 19 of March I drove down to Washington. DC....A cool clear day with a North-Westerly flow maybe 10 or 15 MPH. There was alota traffic so I didn't really get to run, until the second hour on the road in Eastern Rhode Island which is a little hilly. On one of the hills I am going 75 as I start to climb and as I go up the hill , it is slowly gaining a bit almost to 80, going downI am up to 90 and as it levels off I am still gaining 91, 92, 93-94!! slowly it crept up to 95 on the flat and I ran for a couple of miles in the 93-95 range B4 I chicken out....and let her drop down to a safer 75.....in the 65 zone I was in...And on the way back I had quite a bit of acceleration (for a 4) from 80 to 85 and was able to run at 95 for six miles---------------One more thing, The steering & handling were just as good at 100 as at 60..... That stuff about bad steering in the 90s seems 2B wrong!!! WHAT DID I DO TO IT------to get 15 MPH more on top-end??? The ONLY things that were different from "floored at 80" ....were......Change the cap from a Leer (with a sag in the roof) to an A.R.E., ditched the bedliner........and put 37 Lbs, of air in the tires, up from 30...Nothing more!! I know, I know......That could not be it....Yeah I agree, Was it Clara on the Psychics network and her over the phone Ouija Tune Up?? Naw, I don't think so..............I think that the catalytic converter was a little clogged up and the bumpy roads on the Island & the 10% Brazilian alcohol in the Extra Mart gas I use cleaned our the carbon......But I'm open 4 suggestions WTF!! Now the truck is perfect for me.........Great gas mileage, comfortable to sleep in the nice tinted windows A.R.E. cap and keeps up with 95% of the traffic...for $1500. What a deal.. My drive to DC and back--NO problems--between 75 & 95 the whole way-except cross Bronx...What do you think??? Tom
i have a 99 ranger and when i put it into drive it seems like it wants to stall and i wont let me gas it up to get it moveing. it will roll and eventually get up to 50 or what ever speed but on start offs it doesnt wanna move it almost feels like its going to stall. and when i put it in to reverse it like slams into it and wants to go. has anyone had this problem? i have it at a local shop and they are stumped.
The check engine light came on it was a cylinder 3 misfire, so I changed plugs and wires. Now it is fine on flat ground but still throws the code on inclines. Ant suggestions 2003 ranger 3.0
I have a 1999 Madza 6cyl. auto 4x4. I replaced the engine with a salvage motor with 50,000 miles on it. Everything is working great. Except I have a high idle all the time. Seems like the automatic choke is on and I can't pedal it down. Even after warm up its still high. When I brake you can feel the truck trying to surge ahead. My repair guy said I need a new computer chip of some kind. The cost would be about $85. Any guess what kind of chip and could I do it myself for a cheaper price?
i've heard that the newer models have an idle control chip but i wouldn't know anything about them. i have a 94 ranger that had the same problem but the idle speed control on it was a screw on the throttle body that was easily accessible and easy to adjust. check for that and if you don't have it then i don't know anything about the chips
I have a 2003 ranger 4 cly 5 speed about 65,000. 1. about once a month after driving i go to start it and it will kinda start. Engine shakes like crazy and can not keep it running. First time it did it a friend of mine who has a Mech shop put it on computer showed everything ok. Ran great again for a little over a month. Then did it again missed work had it towed to ford dealership still would only shake on starting. I wiated at dealership a couple of hours they came out and said its running fine now they did not do anything and computer showed again nothing amiss. Ford people said maybe fuel pump maybe $650 for a maybe i said no. It did it again about a month after that but this time i let it sit for about 30 minutes and cycled key on and off a few times and it started and ran fine. I am going to replace fuel filter probably not it but a place to start. Any other suggestions. 2. I have a rattled coming from left front wheel area driving me up a wall. I hear it on normal bumps in road. When i jack up front end and hit things with a rubber mallet nothing. Any help. Other than that it is a great truck i get between 25 and 28 mpg on highway. Thanks Paul
hi my name is jarrett and i have a 1998 ford ranger with 138,000 miles on it and just yesterday got the oil changed and now its making a really loud rattling noise that goes away at like 1500 rpm but at idle u can hear it really loud and clear i don't know what it is i have no warning lights and full oil pressure so i have no clue what it is and its worrying me badly i drive almost 30 miles a day and i need this truck please tell me whats wrong
Ok, once upon a time I read another Ranger forum, a really good one, with a lot of postings.
For 4 Liter Rangers of about your age, there was a wide-spread problem of 'marbles in a tin can' rattle noise. But most of these were occuring at much lower milage. Some on almost new trucks, with just a few thousand miles. And some of them did seem to occur, or get worse, after an oil change.
As far as I know, there was never much of an actual determination of what caused this. Loose wrist pins, piston apron slap, etc, etc, were talked about, but nothing was ever pinned down as the cause. Ford did not want to do much about it either, calling it 'normal'. A few people did get Ford to replace engines, and some of the replacements had the noise come back.
The last I read about it, most people were just driving the truck, and the noise was not causeing much of a problem.
With your somewhat high milage, I'm not sure if you have run into the same thing. About the only thing I could tell you is to stick your head under the hood and see if you can narrow down where the noise is coming from. The 'marbles in a can' noise came from deep inside the motor, the 'bottom end', such as the crank.
You didn't put some strange oil into the truck? Did you get the correct filter?
I have a 98 ranger, 4 cyl, manual. A month ago my check engine light came on. About a week or two later the engine wouldn't return to idle speed when I pushed in on the clutch. When I push the clutch the engine hangs at about 1800 rpm for 10-15 seconds, revs a little higher, then returns to proper idle speed. It only does it on a warm day after I have been driving for a while. Otherwise the truck seems to run pretty good.
-Get the 'codes' pulled to see why your check engine light is on. -Look for a floor mat on top of you accelerator pedal. -Clean the thottle body. There may be so much crap there that the throttle valve will not close. -The Idle Speed Valve may be gunked up. -The throttle cable may be binding.
I have an '03 Ranger , 3.0 V6 w/ air. I replaced the tensioner pully and now I can't get the new belt back on. It is the correct belt for this engine, I have pulled the tensioner all the way back and it just won't slip over the pully. Is there a trick to this? It just seems the belt is to short by an inch or so!
New to the forum here. 02 4.0 auto trans 2by. had the truck since new 54000 easy miles. in november of 06 had the oil changed at a local shop cause i was out of time. noticed after this a slight bottem end rattle til oil pressure came up if the truck had set for a couple days. when I changed the oil myself 4months latter the filter came off with out spilling a drop. this truck ALWAYS pukes a bunch out of the filter when you unscrew it. I know what the did. they used a filter with a crappy anti drain back valve or a filter that just didn.t have one. when I went back to my regular filter never heard the noise again until just a couple days ago. we had a heat wave here in havasu ( heat wave for may at least 115 degrees.) been using 5-30 like ford recomends. been thinking of going to 10-30. would think if the crappy filter caused any damage it would have reared its ugly head by now. heard a lot about 4.0 and 4.6's/5.4's having a rattle at start sometimes. I know these engines( 4.0 / V8"s) share no DNA but they both use 5-30. ford does not recomend 10-30 even in the heat of arizona. My thinking is the 10-30 won't siphon out of the bottom end as easy when the engine sits for a day or two when nothing ever cools down below 90-100 degrees at night. Any desert boys out there got some thoughts??
just got off the phone with a buddy that has an 03 xf4 4.0 . He has heard the same from his truck at times and addressed the dealer about it at a visit. dealer said it was the timing chains making noise until the tensioners got pressure. Beleivable I guess when you consider this motor has a chain from the crank to the "jackshaft" (old cam location) and then a chain on each end of the jackshaft to drive the cams on each of the heads (front drives the left cam and rear drives the right cam) and then (!)one from the crank to the oil pump. 4 chains in total. How much noise can a chain make? times 3? don't think the oil pump chain has a tensioner.
ALL YOUR OEM REPAIR MANUALS ON CD-ROM IF IT'S GOT A MOTOR, WE GOT THE CD FOR IT/DIY SAVE BIG $$$$$ THIS IS NOT GENERIC REPAIR INFORMATION! IT IS VEHICLE SPECIFIC.THIS IS THE EXACT SAME MANUAL USED BY TECHNICIANS AT THE DEALERSHIPS TO MAINTAIN,SERVICE,DIAGNOSE AND REPAIR YOUR VEHICLE. COMPLETE STEP-BY-STEP INSTRUCTIONS, DIAGRAM'S, ILLUSTRATION'S, WIRING SCHEMATICS, AND SPECIFICATIONS TO COMPLETELY REPAIR YOUR VEHICLE WITH EASE! YOU GET EVERYTHING YOU EVER NEED ON ONE EASY-TO-USE CD-MANUAL. NO MORE FLIPPING THROUGH BOOKS TO FIND WHAT YOU NEED. PRINT ONLY THE PAGES AND DIAGRAMS YOU NEED. NO MORE GREASY PAGES OR TORN LOST PAPER MANUALS AGAIN. ALL PAGES ARE PRINTABLE, SO RUN OFF WHAT YOU NEED & TAKE IT WITH YOU TO THE VEHICLE OR WORKSHOP. YOU CAN BLOW-UP IMAGES AND THEN PRINT OFF ENLARGED COPIES! THE CD CONTAINS ALL FORD SERVICE& REPAIR PROCEDURES. THE INFORMATION ON THE CD IS CONSIDERABLY MORE DETAILED AND ACCURATE THAN OTHER AVAILABLE MANUALS. THE CD CONTAINS THE FOLLOWING INFORMATION: A/C-HEATER SYSTEM - BRAKE SYSTEM - DRIVE TRAIN - ELECTRICAL SYSTEM - ENGINE SYSTEMS - EXHAUST SYSTEM - STEERING - SUSPENSION - ENGINE/VIN ID - A/C DIAGNOSIS - A/C COMPRESSOR SERVICING - A/C SYSTEM GENERAL SERVICING - A/C SYSTEM SPECIFICATIONS - A/C -HEATING SYSTEM - AIR BAG RESTRAINT SYSTEM - AUTO TRANS DIAGNOSIS - CLUTCH - COOLING SYSTEM SPECIFICATIONS - ENGINE COOLING FANS - CRUISE CONTROL SYSTEM - DEFOGGER- REAR WINDOW AND MIRROR - DOOR LOCKS -POWER - DRIVE AXELS FRONT - ELECTRICAL COMPONENT LOCATOR - ELECTROSTATIC DISCHARGE - WARNING-BASIC INFORMATION - EMISSION CONTROL - INSPECTION PROCEEDURES - ENGINE OVERHAUL PROCEEDURES - GENERAL COOLING SYSTEM SERVICING - MIRRORS-POWER - EXPLAINATION AND TEST PROCEEDURES - POWER WINDOWS - SHIFT LOCK SYSTEM - STARTER - STEERING AND ALIGNMENT - SUNROOF- POWER - SUSPENSION-FRONT - SUSPENSION-REAR - SYSTEM WIRING DIAGRAMS - TRANSMISSION REMOVAL AND INSTALLATION - TRANSMISSION SERVICING - TROUBLESHOOTING - WHEEL ALIGNMENT SPECS - ALIGNMENT THEORY/OPERATION - WIPER/WASHER SYSTEM - EVTM- WIRING DIAGRAMS: CONTAINS ALL WIRING AND VACCUM SCHEMATICS - POWERTRAIN CONTROL/EMISSION DIAGNOSTICS MANUALS ALL ELECTRONIC IGNITION CONTROLS AND HOW TO DIAGNOSE AND TROUBLESHOOT THE SYSTEM, COVERS CHECK ENGINE LIGHT DIAGNOSIS, PINPOINT TEST AND REPAIR PROCEEDURES. SERVICE MANUAL SECTION: POWERTRAIN, DRIVETRAIN GROUP 2 - 10 FRAME MOUNTING ALL AVAILABLE ENGINES DRIVELINE ALL AVAILABLE TRANSMISSIONS CLUTCH SYSTEM/ MUCH MORE WWW.REPAIRMANUALSTORE.COM, FOR THE PRICE OF AN OIL CHANGE, DIY AND SAVE LOT'S OF MONEY, ALSO MANUALS FOR ATVS, MOTORCYCLES, BOATS, SNOWMOBILES, CARS, 4X4S, NISSANS, VOVOS, BMWS,F-150,F-250,F-350, MANY MORE. www.repairmanualstore.com">link title
i have a 2001 3.0 and i changed the plugs and wires and it returned to normal. The engine light came off after a few miles. Now the engine light came back on the problem starting all over. I cant figure it out. I was wondering if you had fixed the problem yet? Theres a couple different people on this site with the same problem but I dont see an answer.
I've been having an occasional hard start and constant rough idle on my 2002 3.0L Ranger Edge for about a year. I changed plugs, fuel filters, cleaned injectors, etc. but no change. Finally took it in to a good mechanic. He checked it out to confirm what he had already suspected: exhaust valve. My mechanic said Ford is having a problem with 3.0L's from around this year.
My vehicle is a 2002 Ford Ranger with a 2.3L 16 valve dohc and it's an LEV (Low Emissions Vehicle). The vehicle starts without any problem hot or cold. First start in the morning the idle speed is at about 1200 to 1300 rpm and then slowly return to its normal idle at about 8 to 900 rpm. the idle is smooth as silk and the engine performance is good for a 4 banger. After the vehicle reaches operating temp the idle begins to lope. Some times heavy enough to rock the vehicle but mostly just enough to aggravate the %$@# out of you and the engine performance poor. When at a stop the while loping the idle will smooth out and some times engine performance is good or bad. I have inspected the exhaust pipe and there is no soot evident so I suspect the vehicle is running lean. Incidentally it just passed the emissions test. I have cleaned the MAF, IAC and replaced the MAP. I have found no vacuum leaks. My brake booster was replaced due to a leak,; however, it did not correct the loping issue. No diagnostic codes have been tripped. I wish there was a way to test the complete system under load measuring components resistance will not tell you what it does under load also I am not a big fan of Diagnostic Codes on vehicles because there at too many variables in diagnosing the problem and could make some technicians lazy and not think beyond the codes. Please that is not an indictment of all technicians only the few and very far between that are out there Does any body have any suggestions, other than a can of gas and a match, on possible component failures or diagnostic techniques to locate a problem like this.
Thanks in advance to every one sharing their knowledge and expertise.
i dont know i had valvoline change it for me cuz me working i drive a truck for a living and i repair cars sometime and i dont have time to work on my own car i have heard that valvoline is [non-permissible content removed] when it comes to that i was told that it could be my cam chain theres 4 chains in the engine one for oil pump and two for the cam and one for something else but i guess they come lose until they get oil to tighten.. another question wile i have ur attetion i was told about putting synthetic oil on my truck but yet i was also told that u cant run synthetic if u dint break the engine in on synthetic my friend told me that when he did it to his car the car never made a sound even after he sold it so is it safe for me to put a synthetic oil in after i drain what i have in it out ???
People say a lot of strange, INCORRECT things about synthetic oil. In my opinion, you can put synthetic in at any time. Synthetic gives you better cold start protection and longer life (miles) between changes, compared to 'regular' oil.
For a 1998 Ranger 4 Liter, I'm not sure you even have an over-head cam, which would require a cam chain. I was thinking they changed to the overhead cam in about 1999 or 2000. You might have a chain driving a pushrod motor, but I'm not sure you even have a cam chain.
I've run Valvoline oil and thought it was ok. The problem with giving a vehicle to one of these oil change places, which I think is what you are saying you did, is you really don't know what they did unless you make a great point of telling them what you specifically want. They probably used 'bulk' oil, and who know what weight they used. If they ran out of 10-30, or whatever you should have in that truck, they might load you up with 20-50 if they had some lying around.
TIMING CHAINS BECOME LOOSE DUE TO THE TENSIONERS, THEY ARE MADE OF A PLATIC/NYLON MATERIAL AND WEAR OUT AROUND 100,000 MILES, YOU SHOULD REPLACE THEM A.S.A.P. BEST REGARD'S, REPAIR MANUALSTORE.COM
In reply to message 153 I am having the same problem on mine, same year, same engine, Off-Road version 99 Ranger, 4.OL OHV. I am getting a miss every once in awhile, I have changed my plugs, cleaned the mas, but still issue continues. I have also noticed a lack of power which I am wondering if I have a injector issue ? I have noticed that plug #4 seems to be always get black film around the outside.
One thing when switching to syn at high mileage is to watch for any oil consumption. If there is any above what was normal, I suggest you switch back to regular dino.
I have a 1994 ranger 2.3l engine, there is no spark at the 2 and 3 position on the coil I have t of them this one is the main one. I replaced the coil but still have the same problem. Any suggestions
Which side of the passenger side or driver? also when you get in and turn key to on position, the check engine light should be on, and when you start to crank it 1 sec later it should go off to verify your Crankshaft Position Sensor is working properly. coils for the left side is primary, ECM control driver side spark on and off at ramdom. everytime you do any replacement on truck please erase memory,or your still be running in memory code. I don't check this site much please let me know if you got this problem solve. Bill, Repairmanualstore.com
SINCE YOUR RANGER IS A 94, YOU WILL NEED TO FIND A FRIEND OR SHOP THAT HAS A OBD1 TO ERASE THE MEMORY. I AM NOT SAYING THIS WILL FIX YOUR ORINGAL PROBLEM, IT COULD BE YOUR CAM. REGARD'S, BILL
You didn't state year or mileage. A common problem is a bad distributor or bad ignition control modual for that symptom. Recomend troubleshooting when it dies and find out if you have spark, and injection pulse. Unlikely that it is a fuel pressure issue, but you can check it anyway. After warm up feel the distributor housing and see if it is hot to the touch. It should only be warm, not real hot. Check this and then re post with what you found. I'll tell ya how to troubleshoot it from there.
Hi, the engine is making lifter noise. We adjusted the valves according to the manual and it still ticks. Does this mean cam and lifter change? It uses water once a week w/ no visible leaks. Has fuel injection and a bardall solution in the fuel tank to help clean em. The plugs are new and gapped at .044 thou...Occationally it stays in 1st gear too long upon take off. Any input will be appreciated. AL Note: I am the 2nd. owner and have kept the oil changes regular, many thanks.
Still looking for answers myself.
Live with it or move up to mid-grade or premium gas.
At 65,000 miles, if you have the orginial plugs and wires, it's time to replace both.
Thanks for any help,
Rick
Ed in havasu
GROUP 2 - 10
FRAME MOUNTING
DRIVELINE
Any suggestions ?
But if/when the computer 'sees' an out of range reading on a sensor, it will turn the light back on.
AL
