2007 Toyota Camry Problems and Repairs
patpat Posts: 10,421
Seems like there are some issues with the new Camry - let's talk about them here.
«134567265
  • jwa120jwa120 Posts: 7
    I have reported the 3rd to 4th transmission problem to Toyota. I do plan on calling Toyota USA again since the service department finally acknowledge that there is a problem and that the service department has duplicated it. I also intend to write Toyota USA a formal letter.
  • pickles077pickles077 Posts: 30
    We have a new 2007 Camry. The vehicle is a nice car. I have noticed the brake pedal makes too much noise when you
    take you foot off the brake pedal, unless you remove your
    foot very slowly.
    I have also noticed at low speeds the vehicle really does not need
    to be allowed to shift into overdrive; the transmission seems to have difficulty with it. When I am driving 45mph or slower I usually drive with the transmission in fourth.
    P.
  • cwopete2cwopete2 Posts: 6
    Only woes seem to be the transmission issue on the first 160 cars built. Given Toyota builds about 2,000 Camry's a day, that's a pretty small issue and yet it was beaten into the ground in the transmission issues section. Overall the 2007 Camry's appear to be another quality Toyota product. Maybe I'm somewhat jaded because I haven't had any problems with my 2007 XLE V-6, but we've owned Toyota products for years and years and wouldn't own any other brand. :)
    I inferred that the woes section would include comments relative to problems, regardless of perception of size,
    that we felt we had. I did not think it would only refer to problems as severe as losing our dearest loved one.
    Our 2007 Camry on occasion seems to "stall" at low speeds
    because the transmission has not shifted down; that is,
    the transmission gear is too high and the rpms of the engine are too low for the speed the vehicle is traveling.
    It is similar to the feel in a vehicle with a straight-shift vehicle and you have the transmission engaged in a gear that is too high. With the Camry the "stall" feel
    is eliminated when the transmission lever is moved to cause the transmission to shift into position four. These are the facts as I know them.
  • 210delray210delray Posts: 4,722
    Why do we need a separate thread? There's already one entitled "Toyota Camry: Problems and Solutions."
  • patpat Posts: 10,421
    Because there is at least one issue that has been introduced with the new MY. I didn't see any reason to limit it to only that one, though. Other 2007 issues are welcome here.
    We're trying to have more granular discussions than we have in the past. :)
  • jrock65jrock65 Posts: 1,371
    Okay, I guess this is the correct thread to post this in.
    A couple of new ES350 owners have reported similar transmission issues.
    Since Camrys and Lexuses are built in different plants, that would indicate to me that the source of the problem is in the plant that manufactures the transmissions themselves.
    To my knowledge, the new transmissions are built by Aisin in Japan, in which case it may be difficult to pin down exactly what cars got the faulty transmission.
  • bayliebaylie Posts: 3
    I have noticed my 2007 camry making a loud "Thunk" noise :surprise: in the mornings when I first start off or the car has sat for a little while.
    I took it in to my dealer and the only solution we could determine was the VSC engages at about 10-12 mph or 20 feet. The rest of the time it is not that loud.
    Has anyone else heard this noise?
    I have also noticed like pickles007 that when I take my foot off the gas quickly the car seems to skip a gear and drastically slow down :confuse: . I do not notice it every time, but I am hoping as the car gets more miles this will get better or I will again be talking with my service department.
    Otherwise I love this Car :blush:
    Gertrude is a LOADED :shades: V6 / XLE.
    I love driving her and cannot wait to go on a road trip this weekend to see how she does on the open road.
  • kiawahkiawah Posts: 3,666
    I have a thunk as well, first thing in the morning. LE 4 cyl w/VSC, just over 800 miles. Was just starting to try and figure out where it was coming from. Appears to come from the drivers side front. Thought at first that it was first time the brakes were applied (like the caliper/brake pad was sticking), but don't think that is the case. I back out of the garage every morning, and was going to try backing in at night and just pulling straight out in Drive to see if the symptoms changed. The engine is idling fast since it's cold (about 1500), which potentially might be related as well. I suspect the idle speed will drop once the engine is completely broken in.
    Kiawah
    Sounds like the same noise.
    When I fill out my customer survey I will list this noise as something I think they can improve upon.
    Muffle the "THUNK" from the VSC.
  • ray_h1ray_h1 Posts: 1,134
    "...To my knowledge, the new transmissions are built by Aisin in Japan..."
    Has this been verified? Have previous Toyota A/Ts been produced by Aisen? (I was under the impression that Toyota designed and built their A/Ts in house - and even supplied Volvo at one time.)
  • alpha01alpha01 Posts: 4,747
    I don't think its the VSC, but rather, ABS. All vehicles equipped with ABS do a system self test within the first several dozen feet of vehicle travel. Its very noticeable on my Sentra, and I believe it may be what you are hearing with the Camry. Can non-VSC equipped Camry owners confirm?
    Is it really a "woe"? Geez.
    ~alpha
  • njeraldnjerald Posts: 688
    No, it isn't a woe.
    People just don't understand how things work.
    Well it may be as designed, but I've had and driven many cars all with ABS for years, and have never heard a clunk like this before from any ABS system. I'd personally be surprised if it turns out to be ABS related, but we'll do some more problem determination.
    I used to hear a noise when my ABS-equipped 1990 Mercury Sable's system did the self-test at startup.
    But my '97, '04, and '05 Camrys (all with ABS but no VSC) made/make no such noise (at least that I can hear).
    But check your owner's manual, because I think it mentions this for both ABS and VSC.
    About idle speeds, a cold start idle at 1500 rpm is nothing to be concerned about. That's pretty typical of fuel-injected cars these days.
  • blindmantooblindmantoo Posts: 139
    I can't remember exactly which system is causing it, but my Quest did it and my '05 Odyssey does it. The service managers at both dealerships assurred me that it was normal.
  • lmacmillmacmil Posts: 1,758
    Nor do my '04 Highlander or '05 Camry, both with VSC. Typical ABS self-check is the motor/pump coming on for a second or two, sounding more like a buzz. I'm not sure what would cause a "thunk."
    Read what it says under "Traction Control System" and "Vehicle Stabilty Control System".
    Yep, page 294 under the ABS section.
    "You may hear a click or motor sound in the engine compartment for a few seconds when the engine is started or just after the engine is started or just after the vehicle begins to move. This means that the anti-lock brake system is in the self-check mode, and does not indicate a malfunction."
    I backed the car in the garage, and will have the wife start it and pull out tomorrow morning while I watch/listen to the ABS pump. I'll confirm it's the ABS then.
    It's certainly louder than a "click", or maybe because the engine is soooo quiet it only sounds loud. In my case, it's a single loud clunk :)
    So they come here to learn. That's why we exist.
«134567265
