2007 Toyota Camry Problems and Repairs
15354565859106
  • patpat Member Posts: 10,421
    I didn't address my post only to you. ;)
  • kdhspyderkdhspyder Member Posts: 7,160
    I was too harsh and for that I apologize. I was as stated unfamiliar with CA DMV regulations which do seem to be different from other states so I was off base.
    The 28000 complaints to the NHTSA does seem to be an exageration given the facts though.
  • w9cww9cw Member Posts: 888
    In past years in CA, the plates always stayed with the car. Used car lots are perfect examples - all cars on the lots already have plates.
    CA has so many different laws, and types of plates, I'm not sure this is the case today, but most likely the OP is correct.
    I don't know, can't say, about other states but here in WA the plates and the registration/license period/fee remain with the vehicle even when sold UNLESS you have paid the personal plate fee and therefore have a specialty license plate.
    I hardly ever trade in a vehicle but personally I would NEVER trust the dealership to send in the sold/trade-in registration slip.
  • nmt001nmt001 Member Posts: 124
    I had a blew out Firestone tire before and survived so I will not buy any car with Firestone tires.
    Too bad I just bought a new car with Bridgestone tires and found out on your post that Bridgestone tires are no good, too.
    Anybody has information on the safety record of Bridgestone tires and how the two tire manufacturers are related? Is Bridgestone actually the Firestone company surviving under a different name? Do they use the same or similar process in their plants? I shall be grateful for any information provided.
    No bloggers working for or with family members working for Firestone or Bridgestone company, please.
    Pardon me for my lack of knowledge in the abrbreviation.
    What does TSB stand for?
    Technical Service Bulletin
    It's where the Manufacturer would document to the service garages, special instructions as to how to fix a certain problem.
  • daisy11daisy11 Member Posts: 1
    Leased a 2007 Camry SE (4 cyl) in late October. Have not had any transmission problems. Had traction control added as an option as I live in Michigan. Car has no traction what so ever. Car can't stop in snow, either. Took it to the dealer to have the traction control checked, they said it worked fine. Had the service manger come to my house to see if he could get the car out of my driveway. He had trouble, but got it done. He conceded that the car needed different tires. The original tires were not all season but performance tires. Could not get Toyota to spring for tires that should have come with the car to make it safe for Michigan drivers. Took it to Belle tire. They put tires on that work great...600 bucks later. At least now the car is safe to drive.
  • 07xle07xle Member Posts: 177
    They saw you coming with the warranty price.
    The easiest $800+ you can make is canceling that warranty, getting your money back and buy a 7 year/100,000 mile/zero deductible for $880 or less, from an online Toyota dealer.
    There are 3 or 4 dealers that will sell for that or less.
    Search the Camry extended warranty forum or even this forum awhile ago.
  • drjamesdrjames Member Posts: 274
    Bridgestone and Firestone are the same company... always have been.. just marketed differently to different buyers. They actually do make a good tire. Whether that whole Ford Explorer/bridgestone tire thing was all bridgestone's fault... I don't agree since it was happening only to Ford Explorers and on the same wheel. Anyways.. off topic.
    I do not know there is a Technical Service Bulletin for the 2007 Camry regarding acceleration hesitation.
    Wish I knew about it before I considered buying the 2007 Camry 4 cylinder.
    Did you read that some 2007 Camry owners complained about the acceleration and were told by the Toyota serviceman that the transmission is normal and that it was designed to perform like that?
    So what is the fact regarding the acceleration hesitation? Defect or design as intended? It appears that Toyota is not being honest and consistent with all the customers.
    Actually, when I first found out the acceleration hesitation on the surface street, I was trying to explain the problem away as I naively believed that Toyota would never produce a new model with serious problems.
    Since there was a very serious accident a few years ago in the farmer’s market in Santa Monica, CA, in which ten people were killed by a senior who mistook the accelerator for the brake. So I had the strange thought that may be Toyota is now aiming at the senior citizen market by re-designing the transmission of the 2007 Camry to make the acceleration hesitate for a few seconds, so that in case the senior drivers step hard on the gas pedal while thinking it is the brake, the acceleration hesitation may give them time to realize that they have made a mistake and to go back to the brake.
    However, when I went to the freeway in the 2007 Camry, I did not expect the hesitation to be so severe that it would be a real hazard. So even if my strange explanation turn out to be true, acceleration hesitation is not a good way to deal with that problem. It doesn’t make sense to overcome one problem with a solution that turns out to be also a serious problem.
    Later, I read that there is another explanation from the Toyota people. It says since Toyota cares about the environment so the Toyota technicians designed the transmission in the 2007 Camry with a drive by wire program which does not allow the driver to accelerate too fast, so less gas would be consumed in the gentle acceleration to the same speed and that would be good for the environment due to less carbon dioxide emission.
    So what is the next innovative step Toyota will take?
    Setting the top speed of all it’s new vehicles at 65mph even though the speedometer shows that the vehicles has the potential to go at a higher speed so that no matter how hard you press on the gas pedal, all new Toyota vehicles will never go over the speed limit on the freeway?
    Survey time. Who wants to buy such a “safety conscientious” vehicle?
    traction control is a system that derates engine output and possibly modulates the ABS brakes to stop wheel spin when starting out from zero speed. say for example, if you were starting out on slick pavement. above some speed, traction control does nothing.
    and as you've discovered, if there is no traction to be had, the traction control wont do much. there's no substitute for good winter tires for wintery conditions.
    hope it helps.
    When I bought a new Corolla in 1989, one of the Firestone tires deveoped a mango shaped bulge on the side of on tire after only two weeks on the road. Firestone says it was caused by hitting the curb and asked me to pay for the replacement tire. I protested and pointed out that I did not even touch the curb with the new car,let alone hitting the curb and that there were no scratches on the bulge. Firestone finally asked me to pay for labor only.
    Two years later, while the tire threads were still looked good, one of the Firestone tires burst(literally exploded, not just got flat) on a shallow pothole of only about two inches deep and one foot half in diameter. The wheel drum was also severely damaged and had to be replaced. I saw tens of other vehicle went over the same pothole without incident.
    I did not want to risk my life so I had all four tires replaced with medium price tire of anothe brand.The ride on the new tires of the other brand was much smoother as if I have installed an improved suspension.Of course, no more bulges and tire burst.
    One blogger on this website said that his new Camry came with Firestone tires, so he asked the dealer to replace the Firestone tire with another brand that he trust.
    Thank you drjames for your assurance that Bridgestone and Firestone do make good tires but I am not sure if the ones on my car are the good ones or the one that would explode like a ballon on a shallow pothole.
    Sorry, but if the wheel "drum" was severely damaged such that it had to be replaced why would you expect ANY tire to survive?
    And the Ford Exploder tire issue was absolutely positively Ford's fault. Their engineers recommended lowering the tire pressure in order to lower the center of gravity and thereby make the vehicle less subject to rollover.
    I guess they completely forgot that an under-inflated tire tends to overheat and explode when running with a heavy load and at high speed for long periods. Bottom line is that Ford's attorneys were better shysters than the tire company's.
  • dmathews3dmathews3 Member Posts: 1,739
    and most of what you have posted is a big laugh too. You will love your toyota no matter what anyone else says until yuo take off your blinders, so we may as well drop it and get back to the business of bashing the 07's. :lemon: :lemon:
    Ford's primary responsibility as noted. Firestone should never have agreed, they were the tire specialists. They knew what the consequences were and were afraid to lose Ford's business.
    After reading daisy11's post I came to realize why the 2007 Camry received lots of complaints about acceleration hesitation but still became Car of the Year in Canada.
    If you start driving a car in the snow in a cold country like Canada, your must never accelerate too fast or the tires would lose traction. So acceleration hesitation that limits the rate of the acceleration no matter how hard you step on the accelerator is a good thing if you drive in the snow.It reduces the possibility of skidding.
    But that good feature for driving in the snow would become a bad feature when you drive in Southern California or southern states with no snow but heavy traffic and aggressive drivers near you.
    A skillful driver may learn to accelerate gently in the snow without the automatic acceleration hesitation,but a skillful driver would still have a hard time if a freeway onramp is very short and the gaps between vehicles on the far right lane are relatively close together during rush hours.
    So I think acceleration hesitation should be an optional feature in countries that has snow and light traffic but not as a standard feature in all vehicles.
    I have experience many flat tires before since I am a professional driver. With good tires even when the tire is completely flat or burst when hitting a pothole, the tire is still strong enough to keep the wheel drum from touching the road surface, so one can still drive very slowly to a safe location to change tire. (I had experience a blowout on the freeway at high speed before, but the tire, which was not Firestone tire, was strong enough to support the van to let me drive slowly to exit without damaging the wheel drum.)
    However, with the Firestone tire that hit the shallow pothole, half of the tire near the ground burst open completely. The burst Firestone tire could not support the weight of the car so the rim of the wheel drum hit hard on the road surface and buckled. That's what I meant by severely damaged because once it is buckled at the rim, it can no longer be used. I didn't mean the whole wheel drum is completely destroyed like crashes on the freeway.
    I do agree with you that under-inflated tires are more likely to overheat and explode and I see that Ford was also to blame for the death of the 42 people in the accidents. But Firestone should have initiated an investigation why its tire would blow out on the Ford Explorer right after the first blowout instead of engaging in the blame game after 42 people died.
    You see, once the reputation of a product is damaged by death of a large number of consumers, it is very difficult to restore the image of that product. That's why I advice Toyota to take the complaint of acceleration hesitation seriously and to solve the problem before its too late.
  • 210delray210delray Member Posts: 4,721
    Your dealer sold you short at the time of purchase. The SE comes with performance tires standard (makes sense because it is the performance variant of the Camry line). However, all-season tires are a no-cost option, and in Michigan of all places, the saleperson should have asked you about your preferences.
    Still, all-season tires are nowhere near as good as dedicated winter tires for driving in snow.
  • stlpike07stlpike07 Member Posts: 229
    You can't be serious with your post, are you?
    I drive my Dad's Saab frequently and I also drive my Mom's BMW all the time. Both are new cars and if I "stomp on the gas" there is a short delay with them too, depending on the speed I am going. If I am going 40+ mph and step on it there is a delay.
    I have a 2007 Camry LE I-4 5sp. AT and just had TSB EG056-06 performed to help with the hard downshift and shifting. The problem wasn't huge before, but the TSB improved how the transmission handled.
    If you want to be able to "stomp" on the gas and take off right away you should get a new Corvette. Most cars have a delay.
    If people are honestly having a 3-second delay, then there is a problem. I have never had any problems accelerating on the highway. I step on the gas and watch the rpm's go up as I accelerate.
    Just my two cents.
    I have read a few posts in which people talk about 3-second delays before the car accelerates. Is this true or are people exaggerating?
    I've read through discussion boards on other websites for the Camry, Accord, Ford 500, kias, hyundais, and so forth and it seems like everyone has something to complain about. Some people are not as forth coming because they do not want to talk badly about a car they own.
    Both Saab and BMW are cars that emphasis speed and performace. You admit that there is only a "short" delay with the two cars. Of course, I understand the how short that delay can be.
    If you think the 2007 Camry LE V4 5sp AT has no problem at all, why did you need to have TSB EG056-06 performed? So after you have improved your Camry, you turn around and heckle the one who have experienced unacceptable acceleration hesitation in their unserviced Camry.
    Are you tauting or just being smug?
    nmt001, it's unfortunate that you had such a poor experience with your I4 5A Camry, however, that prolonged "hesitation" which you experienced was addressed by Toyota last September, and those but a few who had the TSB performed are no longer complaining.
    Toyota is not being honest and consistent with all its customers.
    You claim that Toyota has addressed the problem of acceleration hesitation since last September.
    How come even in the year 2007, there are still 2007 Camry owner reporting that the Toyota dealership tell them the acceleration hesitation is normal when they complained about the problem?
    Read the following messages #2738,2784,2847,2946,2997 posted in the year 2007 or search under the word "normal".
    How can Toyota insists that the hesistation is normal to some customers who become dissatified but provide techical service to the others who may turn out to jeer at those who are refused the service?
    Toyota should clean up its act and behave like a real Japanese company like it used to?
  • anmranmr Member Posts: 6
    I have a 3 months old Camry 2007 and I found the engine and surrounding areas are now full covered with dust and mud and I used to go for full wash every month in Car wash centre but engine compartment is not washed yet. I used to wash my honda once in 2 months. Is it advisable to wash the Engine in carwash centers?, if so how often?. Appreciate someonebody's reply.
    Matthew
    Maybe you can't distinguish between Toyota and Toyota dealers???????????
    I don't care what company it is, independent dealers, their service and sales are just that - independent.
    Get off the tirade crusade.............
    You say, "The dealers do not have the solutions to most of these "problems" unless directed by Toyota."
    Do you mean Toyota directs some Toyota dealerships to tell the customers that the acceleration hesitation is normal but directs others to provide sevice to solve the same problem?
    Since it appears to be the case,I was right to critize Toyota(the Headquarters)by saying that"Toyota is not being honest and consistent with all its customers."
    My post #3009 is clearly aimed at criticizing the Toyota Headquarters.The only paragraph mentioning the Toyota dealership is in a question asking why some dealerships would tell the complaining customer that the acceleration is normal. It is not a statement critizing the dealership with regard to this matter.
    The paragraph in my last post says, "Toyota should clean up its act and behave like a real Japanese company like it used to?" It is clearly a statement criticizing the Japanese Toyota Headquarters.
    It is apparent that you are the one who fail to realize that I did distinguish between Toyota and Toyota dealers.
    If you are from the Toyota dealer, you should work hard on pressing the Toyota Headquarters to provide a consistent policy to help the complaining customers instead of asking people not to complain.
    Let's get back to specific Camry difficulties and take conversation about Toyota the manufacturer to an appropriate discussion on the Automotive News & Views board.
    Can anyone offer some advice to Matthew anmr, "2007 Toyota Camry Problems and Repairs" #3010, 31 Jan 2007 9:04 pm?
    Well I know that water and electrical components usually don't play well together.....and could get very costly. I would hand wipe the engine down if necessary, as opposed to power spraying of any sort. I have used degreaser and spray on old big block V-8's, by just covering the distributor cap, alternator, and carb with a plastic bag and avoiding the electrical wires. That was prior to all the computer controls and relays, though.
    I'm sure others will have different opinions.
    I'd say no, it's not a good idea to clean any engine compartment using the high pressure hoses of a self-service car wash. For dust and mud, you won't need a degreaser either.
    I do it the following way: take the nozzle off your garden hose, and only let a small stream of water come out. Use regular car wash soap, sponge (and bucket if necessary) to wash off the exposed sheet metal, radiator, and numerous plastic covers inside the engine compartment. The engine should be cool when you do this.
    Do not spray any water on electrical connections to the extent possible, and keep water off the brake fluid container as well (there's a little vent hole on top).
    You can use a damp sponge to wipe off areas that shouldn't be doused with water. Use the hose to rinse off the other parts.
    I am not taunting or being smug. Most new cars have a delay.....I am asking if people are being serious or over exaggerating.
    If I had a three second delay I would be pretty upset. I had the TSB performed because the car would downshift hard sometimes when I would come to a stop around 25-35mph. Now this hard shift is gone. I didn't even really think it was a "problem" until I read through some discussion boards.
    I am not heckling anyone. That was not my intention and I didn't want my message to be interpreted that way. All I am saying is that if you slam on the gas in most cars that there is a delay. Thats all.
    I have never had any acceleration problems, especially getting onto the highway, SO, I am empathetic to those people. A dealer shouldn't refuse to do the TSB. I printed the stuff out and gave it to them and there was no problem.
    Apparently the delay/hesitation has to do with a procedure wherein the gas pedal is fully released followed quickly by a re-application of foot pressure to the gas pedal.
    When the gas pedal is fully released the transaxle begins an upshift sequence to extend your coasting distance to improve FE or to prevent engine braking from resulting in loss of control. Your choice, one or the other or both.
    Now you re-apply enough pressure to the gas pedal that a downshift is required and the "wait" begins. First, the previously commanded upshift must complete and only then can the command to downshift be issued. The problem is that the upshift will exhaust all of ATF pressure/flow and with the engine now at idle it will take a second or two to restore the pressure/flow to a level in which the downshift can be completed successfully.
    So DBW is used to delay the onset of engine torque until the downshift is completed.
  • ski7304ski7304 Member Posts: 16
    Ok...I know I used your TSB link about a week ago and it took me right into Toyota's TSB site. But now, when I click the link it brings me to Alldata's home website and I can't find the Toyota TSB's. Can you please help me?
    Assuming the new shift pattern upshift technique is to help alleviate accidents due to loss of directional control arising for engine braking, why not just have a SNOW mode that can be activated by the driver, by a rain sensor, or if the OAT hovers around or below freezing.
    Upon a full lift-throttle event in SNOW mode the transaxle would remain in the same gear ratio (ready to SURGE forward on command) but the engine RPM, via DBW, would not be allowed to fall enough to provide a significant level of engine braking to the driven wheels, front, rear, or ALL.
    Absent being in SNOW mode the shift pattern could be the same as it was pre-2000, NO upshifting on full lift-throttle events.
    That is weird. I just tried the links I bookmarked and it takes me to the homepage too. I'm not sure why that is happening.
    I'm pretty sure the dealer held onto my copy or I filed it somewhere. I will look for it......
    In the TSB paperwork, it says that if the TSB has been performed already there will be a sticker undernear your hood with the TSB# and info on it. The sticker is about 2-3 inches long and should be on the lower right side somewhere.
    I'll keep looking and get back to you.
  • kyrptokyrpto Member Posts: 216
    Perhaps shifting into 2nd or 3rd [or 4th - never had a 5 sp. auto] to stay in best range? I speced the excellent VSC/Traction Control Option for our Camry. The VDIM/Traction system on our Highlander Hybrid i4WD is even better in snow than the '02 Highlander we had. West VA can get lots of snow and 1 resort is ON TOP of a 4800' mountain. I've spent a lot of time in the Allegheny snowbelt [180" per avg. over 10 years].
  • mvperez4jesusmvperez4jesus Member Posts: 231
    Thanks for your reply, i am just probably wait to see if toyota will ever fix this issue with the camry. to be very honest i really want that camry so bad, i just like it. No other camry has come as close to this one. however i know for fact that the honda accord is the best for your buck. you can read any classifieds for used cars. and just compare to similar trims between the accord/camry/nissan, etc. and they will pay over 1000 more for the accord without asking u a question, and any dealer will give a better/fair price. Hopefully i don't get stock waiting. I wouldn't wait more than this october. if i buy the accord it will be sooner, but let's cross our fingers.
    Ski7304.......I found the copy I pronted out of TSB EG 056-06. I will scan it into my computer and can email to you if you would like.
    I'd say it would be easiest to make a new email account and give me the address, then I can email the info to you......rather than putting your "real" email on here.
    Will that work?
    You each have a carspace email, go to mailbox, upper right hand corner. You could also paste it as a jpg on your carspace alblum, and others can retrieve it and print it.
    Thank you kiawah for the advice.
    I made a carspace album and added the TSB info to it.
    ANYONE FEEL FREE TO LOOK AT MY PROFILE AND PRINT OUT THE TSB
    I hope this helps everyone!!!
    Thanks stlpike07! I looked at the TSB but it states it is for the V6 5 speed and mine is a 6 speed so I am not sure if that would apply to me. I just find it odd that a week ago that link was able to give me all of Toyota's TSB's for 2006 & 2007 and now it is gone. Does Toyota not want us to access that site? Host Pat, could you possibly know why this is occurring??
    Thanks also to kiawah for the email info.
    The TSB is actually for the LE I-4 5sp. AT.
    There were TSB's for the V6 engine on the alldata webstie too when I looked....however, it is very strange that you cannot view the TSB's anymore. I checked again today and the link took me to the main page of the website.
    Check the V6 discussion thread and see if someone there printed out the info.
    Ski7304......to access the website you have to be a member. Most dealers and independent shops are members, so any dealer "should" have the info.
    I know there were TSB's for the V6. If you are having trouble with one dealer I would suggest trying another one. Any Toyota dealer can perform warranty work.
    TSBs are not available to the general public, so someone must have put up a "back door" to access them, which subsequently must have been discovered (and closed).
    There was another such back door a few months back through a small-town public library (in Iowa, IIRC). I told a co-worker and he downloaded all of the TSBs for any employee at my workplace that was interested. Undoubtedly, that door has been closed now also.
  • chuck28chuck28 Member Posts: 259
    Hello Wwest. you never answered my question concerning why toyota is replacing transmissions if what you say they are performing by design? Also, I ask if you work for Toyota?
    Thank you so much for your advise. So better clean the engine compartment by ourself.
  • kul2kul2 Member Posts: 9
    I just bought a 2007 camry XLE V6. I noticed that VSC light does not turn on momentarily when the ignition is turned on. The user manual indicates that it should. Does any one know if this is normal?
    Does your car have the VSC option?
    Not part of any normal trim package....it's an option. Would have to show as a line item on the original Window sticker, approx $650 MSRP option.
    Yes, I paid for it! The VSC is on original window sticker.
    It should light. I have an LE w/VSC, and the indicator light is car w/squiggley tire marks, lower right hand corner of the display. See pages 172-3 of owners manual.
