2007 Toyota Camry Problems and Repairs
16465676970106
  • rugbymanrugbyman Member Posts: 8
    Here’s the readings on my car:
    LF 0.01 deg, RF -0.01 deg, Total toe 0.01 deg
    LR 0.23 deg, RR 0.26 deg, Total toe 0.49 deg
    The front is ok but the rear is too much toe out, I think, although the tech at the dealer insist it’s within spec.
    Rear is supposed to have just a little bit of toe-IN.
  • larsentlllarsentll Member Posts: 1
    I'm having the same problem.
    Passenger seat vibrates/shakes. My dealer lowered the tire pressure today to 30PSI (which looks like the recommended PSI) from 38-40 PSI (as driven off the showroom floor in Jan. 2007) but now the steering column and driver seat vibrate. My dealer keeps tell me that without a TSR they can't do a thing.
    I have been into my dealership now 3 times about this issue and am not getting valuable assistance.
    A vibration is most likely a tire out of balance (most likely), or a tire out of round (less likely). Get your tires spun balanced somewhere.
  • nagoya09nagoya09 Member Posts: 9
    thank you very much for give me detail the location. I am thinking the same think place the foam pad use for woodfloor. I am not sure do it myselft or let dealer do it.
    do you have the problem with the brake problem. my bother have us made camry, and the rear break have problem, the dealer said there are the defect of the break, but they won't repair it until you prove it. my wheel shake when I apply the brake slighty at 60mph, and stop when it below 50. I beleive the front rotor get whope
    spin balancing tires and rims is what traditional shops do.
    i think you want someone with a hunter "road force" balance machine to give it a go:
    http://www.hunter.com/pub/product/balancer/4159T/index.htm
    Well it doesn't seem like the dealership has done any of the basics yet. They 'just' got around to checking the tire pressure, which is what should have done for new vehicle delivery.
    I'd personally be dumping the dealer, and either take it to another dealer or independant. Three strikes and they are out.
    Not sure a hunter is needed at this point, but certainly an option if the basics don't fix it.
    ok, sorry. yeah i see the point you are driving at and agree with you. i'm thinking if they can't spin balance the tires and be successful, then i'd suspect a bad tire / tire mounting. however, it could also be an alignment issue as well.
    so yeah, there are a number of basic things to check before going the hunter route.
    agreed on dropping the dealership.
  • csmith99csmith99 Member Posts: 3
    I bought a Camry 2007 LE V4 05/06. The motor has limited power, and at cruise ctrl speeds on hills has major RPM spikes. I have read the same issue here, but Toyota thinks this is not a problem... My previous Camry ran great and there were no issues.
    Any thoughts on trading to V6? Thanks
    Any tips on trading in a purchased vehicle to then lease the next one?
  • stlpike07stlpike07 Member Posts: 229
    I hope my post was able to help you s far as the squeak/rattle goes.....it should definitely help.
    As far as the brakes, I do not have any problem with my brakes. They work great.
    csmith,
    Get your car back to the dealer, to put on this TSB. It will fix the cruise control downshifting problem, as well as improve performance. Car runs a LOT better.
    I4 Performance TSB
    To me it is beginning to appear that the newer, 07-08, cars have shift patterns that are much more tightly tuned to keeping the engine as low in RPM as is possible, right on the cusp between best FE and almost not having enough torque to move the car forward "at speed".
    So even the very slightest movement of the gas pedal or roadbed slope will result in a gear shift.
    Additionally the torque converter lockup clutches are now being made robust enough that they can be used in gear ratios below O/D. A modern day 6-speed will now have as many as 9 forward gearbox "ratios".
    Couple all of this with the apparent need to always upshift, QUICKLY upshift, on a full lift-throttle coastdown event to lower the potential for loss of control on a FWD vehicle should the roadbed happen to be slippery and you get a car with a lot of shifting going on.
    Match one of the 6(9) speed FWD transaxles with a low torque/HP I4 and you get a lot, a WHOLE lot, of shifting.
    All the result of modern day electronics technology. Can you imagine designing an analog, fluid powered, computer to properly and adequately manage all this shifting.
    NOT!
  • eroc69eroc69 Member Posts: 56
    I have a question about my LE V6 power seat. I am a pretty big guy but not huge, 6' 230lbs. My seat feels as if its stuffed with cotton balls{slight exaggeration}, meaning its got zero support and zero stablity when I make a turn. Especially a left turn or curve, I need to beace my right elbow area against the pass. seat so I dont fall out{NOT an exaggeration]
    I sat in a brand new Camry last week when mine was in for service, mine only has 4600 miles on it. The one in the service room had none and was noticeably and significantly firmer.
    Any ideas on how to complain about this totally uncomfortable seat?
    P.S. {dont tell me to lose 50 pounds, aint gonna happen :P }
  • lzclzc Member Posts: 483
    Politely point out the difference between your seat and a brand new one. Not likely, but maybe yours is defective. Otherwise, I doubt you'll get much satisfaction.
    One common complaint about Camrys from especially tall people is that its seat bottom is short and thigh support inadequate. I like my wife's hybrid Camry for mileage, but not comfort on long trips. Comfort is the one reason I swallowed hard and bought an SUV.
    Thanks LZC, I just took the kids out for dinner. A nice 3 mile trip in shorts. I thought the soft shorts would help me be more comfortable, NOPE. Its horrible. Every time I turn left I need to elbow the pass. seat so I dont fall out. Its that bad.
    I will politely BEG the service man to help me. I cant last 2-3 years like this.
  • gainesmbgainesmb Member Posts: 17
    Hello swong6,
    I am planning to purchase a 2007 Camry V6 this weekend that may have been assembled in the same plant and line as the one you bought and I also live in New York. The VIN # is 4T1BK46K97U045858. What has your experience with the new Camry been so far (e.g. parking damage, transmission flair, dashboard noise, etc)? Do you have the body side molding?
  • swong6swong6 Member Posts: 9
    Hi gainesmb,
    I've had my V6 LE a little less than two months and this past weekend I completed my first "long" trip from NYC to Leesburg, Virginia and back. I've accumulated a little more than a thousand miles on the odometer and while it is still too early to make the determination about the infamous 6-speed tranny 3rd gear to 4th gear "flare", the vehicle has performed pretty much as expected. While I have not parked on the ugly strrets of NYC I have driven the car into downtown Brooklyn but have parked at one of the park and lock open lots (Flatbush and Willoughby Streets). There are some creaks and squeeks coming from the front passenger seat I have eliminated this by putting the seat back in the extreme upright position which has completed eliminated any irritating noises.. I have purposesly not tracked city milesage but during the trip down to Leesburg I got over 30 miles per gallon and the trip back from Leesburg to NYC I got 31+mpg. The trick to getting the optimum milesage is to keep the vehicle going in 6th gear with a minimum of engine revs....for me this appears to be going a consistant 62 mph. The Toyota front brake pads produce horrible amounts of brake pad dust and it's a constant chore keeping the alloy wheels clean. On rainy days, the front drive wheels kick up a lot of sand and pebblestowards the rocker panels making it almost imperative you purchase mud flaps to protect the paint. The front clip has accumulated some paint chipping and it's apparent the front bumper and grill will be chipped quite a bit within a year or so. I've had the Camry up to 80mph on the NJ turnpike and it's apparent you will not even notice you are going this fast until you look down at the speedometer. So far my fears about this first year toyota 6-speed automatic transmission are unfounded.
    For those that have the flare (in the 6 speed transmission), it happens when the engine and transmission are cold.
    Enjoy your new vehicle and thank you for your quick and oh so important feedback. I am confident now that my experience will be similiar to yours and not as uncomfortable about buying a first year car as I was last week. It seems Toyota has resolved some of the earlier issues with the V6 LE...Are you using regular or premium gas to get your MPG readings? I read on one of the forums that premium is reccomended but regular is sufficient for the Camry V6 models. I would prefer to use regular because of the cost of premium.
    Thanks again!
    I burn regular gas and there is not pinging or detonation noticed at all. You didn't mention where you were looking to purchase your vehicle at. I purchased mine at Queensboro Toyota and it was a blast haggling with the dealership. I paid $22.6k for the V6 Camry LE with just alloy wheels as my only otion. With tax, licensing, and whatnot I ended up paying $24.6k "out the door". Be advised all the dealers are so use to negotiating they literally have it down to a science. I was prepared to just get pricing but as things turned out I ended up agreeing on the $24.6k...only thing I missed was color choice.
    That is good to hear. I will use regular when I finally make my purchase.
    Go to this link on the Prices Paid and Experience site Message # 5343 to see the price I was quoted by Fitzmall in Maryland. I chose them because they could get a Camry LE V6 with the JBL radio upgrade and in NY/NJ it is not an option unless you upgrade to the SE or XLE. This deal may fall through because of some of their requirements, that I was unaware of and refuse to comply with, so I will go to a local dealer on Long Island Saturday if it does. The JBL radio is not that important.
    Gainesmb,
    What are 'some of Fitzmall's requirements that you were unaware of and refuse to comply with'.
    I came very close to using them when I bought my last Toyota and didn't have any issues with the initial discussions.
    Hi Kiawah,
    The initial discussions went well and the three persons I spoke with were very pleasant. The price is right as well. The problem began late last night via email a few hours after the purchase order discussions done by phone where concluded. Let me be clear that I choose not to comply with some of their requirements.
    Requirement 1) Must fill out the "Online Credit Application". I choose not to fill it out because I have financing through my credit union. They explained to me via email that my filling out the credit application will protect them because of the reported activities of straw buyers and the like who have been known to sell misappropriated vehicles on the Black Market. This explanation does not change my mind.
    Requirement 2) Have the funds wired directly to their account from my credit union if I do not fill out the "Online Credit Application". As you can see, this is not going well anymore so I am getting off this ride while I can still get off. I have nothing against Fitzmall and their procedures. I was just unaware of a few things that I will not comply with is all.
  • dmathews3dmathews3 Member Posts: 1,739
    sounds kind of fishy to me.
    Oh okay, thanks.
    I personally wouldn't have a problem with that. The dealers down here do that down here as well, even if paying cash, in case the check doesn't clear the bank.
  • teamtboteamtbo Member Posts: 78
    I also financed a portion of my Camry through my credit union. My dealer gave me 10 days to get them the check and had me fill out the credit application. If I don't show up with a check in 10 days, then Toyota will need to finance the remaining 1/3 of the cost since they no longer possess the car. Remember, I did drive off the lot owing them around $10,000. I think requirement #1 just protects them in case you don't show up with the money.
    Requirement #2 does seem fishy. I don't understand why the dealer will forego the Online Credit App if you wire the money from the credit union. Anyway, I agree and I wouldn't wire the money. I wouldn't think the CU would even do this either.
    Could you just bring the cashier's check with you when you pick up the car?
    Actually #2 makes perfect sense to me.
    If you fail to sign the credit application (which is their protection if you and/or your credit union doesn't deliver on the money), then you have the vehicle and they have no financial recourse but to sue you.
    So if you don't sign the credit, then a way to alleviate the need for that credit application is for them to have a bank to bank transfer. If their bank confirms that they have received the money and "it has cleared" (as a bank transfer does immediately do), then you wouldn't have a need for the credit application anymore.
    Everything seems perfectly up and up to me.
    I bet you'll have a similar requirement from any dealership you decide to buy from. Good luck with whatever you decide to do.
    Back to "Problems & Repairs" before we get booted to the "Prices Paid" forum.
  • imidazol97imidazol97 Member Posts: 27,838
    I've always paid with a check on a checking account or money fund. I've never had to fill out a credit application.
    I appreciate this discussion but it is in the wrong place and I don't want to annoy the host since I am a new user and all, so let's not beat this bush any further. That being said, it is a personal choice to pay for automobiles using non-dealer financing, which has worked for the last 27 years that I have been buying cars, and I choose not to change my ways now. Remember that I am not accusing anyone of any improprieties. The lesson learned for me is "Better to play in your own back yard where you know the rules".
  • kevin5674kevin5674 Member Posts: 3
    Noticed alot of discussions about a vibration in the new Camry. I bought a 2007 Camry in January. Had the tires rotated at around 7200 miles. Since then the car has a vibration at highway speeds. Had it into the dealer five times and Bridgestone twice. Toyota has re-balanced the tires three times and then I asked Bridgestone to replace them. Toyota then replaced the rims and it's still there. Right now I'm waiting for the regional Toyota rep to drive it to see if he can feel it. The vibration is felt in the gas peddle, steering wheel and seat. When driving you can look over and watch the passenger seat vibrate.
    Has anyone actually gotten this problem fixed?
    Do a search in this forum for "road force balance". It is a different method of balancing which puts a load on the tire while it is being balanced. It seems to work well on the more difficult to balance tires.
    Thanks for the info, I read about that earlier here. But, the dealer had that done the third time I took it in. Unless I should have them try it again on the new tires and rims. I'm beginning to think it's something mechanical.
    Have someone drive the bouncing car down the interstate, about 50-60 during low traffic volume period. You follow behind in another car, and then sight up both sides of the car. Drive around and sight on the left, and look at the left tires. Drive around and sight on the right, and look at the right tires. See if you can figure out which tires (or possibly multiple tires) aren't tracking true and smooth.
    Thanks again for the info Kiawah. Will give it a try this week sometime.
  • kenleekenlee Member Posts: 2
    After waiting for a year for toyota and Sirius to get their act with the sirius radio, we finally had it installed. We have constant cut outs with the reception. Dealer says heavy tree cover and overpasses will cut the signal. However, ours cuts out with clear skies. Anyone else having this trouble?
    Ken Lee
    Don't know about Sirius but XM was having that problem for about a week due to them uploading new software to their sats. But all is well now.
  • daveturnerdaveturner Member Posts: 25
    I've had my Camry LE since October 2006 and all of the sudden I can't open the trunk using the trunk release lever next to the driver's seat--it just pulls up and nothing happens. I can still open the trunk using the button on my key or the trunk lock. I looked at the manual and there is a method to disable the trunk release lever--but i did not do that procedure and the manual doesn't say how to re-enable the trunk release lever. Has anyone else had this problem? Well, fortunately my Camry is still under warranty but it will be a hassle to go to the dealer to get it fixed...
    Dave, so, are you saying that your trunk key hole opening is in the vertical position (|) but the trunk release lever will still not work?
    Yes, there is a way to lock the trunk release lever. However, when this is feature is enabled, the trunk key hole opening is in the horizontal position
    (-). If your trunk key hole is in the vertical position but the lever won't work, it appears you may need to bring your car to the dealer...unless someone else can shed some light on this.
    I was able to lock my trunk release lever by inserting my key in the vertical position (|) and moved it counter clockwise 90 degrees (-). I was able to disable it by inserting my master key (-) and rotating it clockwise 90 degrees back to the vertical position (|).
    teamtbo, yup, the trunk key hole opening was in the vertical position but the release lever doesn't work--it worked fine since I got the car back in Oct. 06....but it just stopped working all of the sudden--I speculate that the cable/wire connecting from the trunk release lever to the trunk is loose or broken...
  • cameo41cameo41 Member Posts: 10
    I WOULD GIVE ANYTHING TO GET RID OF MY 2007 CAMRY XLE 4CYL! HAVE HAD TOYOTAS SINCE 1973. THEY SURE SCREWED UP WITH THIS NEW 2007. THEY NEED A COMPLETELY NEW COMPUTER SYSTEM. SURGES, HESITATION, VERY POOR GAS MILAGE (14 MPG), RATTLES,BRAKING, IDLES TOO FAST, TO NAME A FEW PROBLEMS. WENT THRU ARBITRATION - FINAL RESULT WAS "WORKING ACCORDING TO TOYOTA SPECIFICATIONS/DESIGNED!" THEN TOYOTA BETTER GET SOME BETTER SPECIFICATIONS OR DESIGN BETTER! I TELL EVERYONE I SEE IN A PARKING LOT, STORE, WHEREVER - DON'T BUY A 2007 TOYOTA!! WHEN A FRIEND ASKED THE DEALERSHIP IF I HAD PURCHASED CAR FROM THEM, THEY LIED AND SAID THEY THOUGHT I PURCHASED IT FROM ANOTHER DEALER.
  • sandman46sandman46 Member Posts: 1,798
    Too hard to read your post with all caps...many will skip right by. Tone it down a bit...PLEASE!
    Sorry to hear about your problems though...sounds like you got a :lemon:. Hope it all works out for you with Toyota.
    The Sandman :)
  • nmt001nmt001 Member Posts: 124
    I got rid of my 2007 Camry LE 4 cyl after I had been tormented for months between keeping it and worry about the hesitation problem or trade it in for another auto manufacturer at huge lost of money. I do not regret having got rid of it.
    I am surprised to see that some 2007 Camry 4 cyl owners are still complaining about the hesitation problem because some people say Toyota has already fix the problem with new computer program download. Perhaps that's just another 'misinformation'.
    The first shock I had when I owned the 2007 Camry was the acceleration hesitation when I tried to merge into the heavy freeway traffic. Then I was told on the internet that some dealerships told the customers the hesitation was working as designed.
    The second shock was that the gearshift knob can be taken off from the shaft by a five year old by spinning it like a toy leaving a thin shaft with nothing to hold onto. When I complained, I was told by a Toyota salesperson that it was not a defect. It was designed like that.
    The third shock had was that an alarm suddenly sounded when I was driving. It came on and off and I was worried sick if something was wrong that would jeopardize my life. I had to park the car and found out that it was the two heavy files that I put on the passenger seat that caused the alarm when the seatbelt was not in use. The car that I bought after trading in the Camry has advanced passenger airbag too but it never gives any false alarm and the alarm for warning that the seatbelt should be used would come on when the engine has started, not after I have been driving for a while. Guess I don't need to ask Toyota to get the answer that it was no defect and it worked as designed.
    So I agree with you that Toyota should have designed the 2007 Camry better and thoroughly tested the car themselves instead of rushing it into the market and uses its former and new customers as guinea pigs.
    Looks like your 2007 Carmy has even more problems than the one that I previously owned. If you go way back on the posts, you would find that one 2007 Camry owner actually won the Lemon case against Toyota. I think he won probably because he hired a good attorney instead of going through arbitration.
    Just like you did. When my neighbors and friends asked me about the 2007 Camry since they were considering buying one, I told them about my bad experience and advised them not to buy it. But I told them not to take my words for it. Go on the internet and read the complaints from other 2007 Camry owners. Thanks for the internet. They didn't buy the 2007 Camry.
  • palpakpalpak Member Posts: 21
    I challenge edmunds.com to testdrive the 4cyl LE and find out if the 5spd a/t design and software is really what toyota says it is.
    Other car companies can take advantage of this too, they can make a TV commercial of the camry's transmission flaws.
    nmt001,
    You traded your camry for what kind of car?
    "People who live in glass houses shouldn't throw stones.."
    It is highly likely that all manufacturers of FWD or front toque biased AWD vehicles have been or will be required to adopt the new shift pattern/shedule which results in upshifting the transaxle upon any full lift-throttle event.
    People who assume the root cause of the problem should not jump into conclusions.
    I traded in my Camry for 2007 Nissan Sentra with CVT.
    Good acceleration but not as smooth as the Camry.
    I don't know if the roughness is caused by the Bridgestone tires or because the suspension is not good enough.
    I am considering replacing the Bridgestone tires with other another brand. I used to have a Corolla with Firestone tires, the ride was very rough until I changed all tires to another brand. Altima could be a better choice than Sentra if smoothness is what people are after.
    I have had my wife drive my 07 V6 Camry for the past few weeks While Ive been using her CR-V. I took it today and was so unimpressed at the ride. When I brake moderately hard the tranny shakes when slowing and even has a slight flare when downshifting.
    The seat still feels as soft as a bean bag and is sooo uncomfortable.
    The car still has a shake in it on the highway.
    While in traffic I tried to switch lanes, one car finally let me in and I gunned the engine to switch lanes and it literally took 3-4 seconds before the thing moved properly.
    I mean it didnt just sit there but I accelerated to get out of her way and it took 3-4 seconds b4 I got moving up to speed.
    Frustrating. :cry:
  • cheema22cheema22 Member Posts: 7
    So what happened to the noise in the seatbelt now, was it fixed?
