Ford Ranger Starting Problems
i have a 94 ford ranger. my problem is sometimes when i have drive somewhere and turned veh off i go to start it again and it won't start. lots of juice but it won't start. it sometimes will be an hour before i can get it going again.most times soon as i call a tow it will turn over. i've had mechanics check it out and of course doesn't do it for them. any suggestions on what it might be???
SEE ALSO: This Video on How to Methodically Diagnose a Crank-But-No-Start Issue
First thing I would check/change would be the fuel pump relay.
Can you hear the fuel pump run when you first turn the key to ON. Without turning to START? When it is failing to start.
doesn't happen all the time, lately more so. but if you drive some where,turn it off then go to start it. it won't start so i sit and wait keep trying and eventually it will start. i have had two different mechanics look at it and of course it won't do it when they have the veh so they don't know what it is. i've had the truck since it was new in 1994 and never had a problem with it til now
The relays are in the underhood power distribution box - a box with fuses, curcruit breakers, and relays.
A relay is just a small cube that plugs into the box. There may be more than one. I don't know if they are marked as to what they control or not. I think a Ranger, if it has more than one, they are all the same. If there is more than one, change them around, wiggle them, press them in securely.
If you change out the fuel pump one, and it has been failing, it might cure the problem. Of course, you have now put the misbehaving one on some other circuit...
They don't cost too much. If you can ID the one for the fuel pump, I would just replace it and hope this fixes it.
joanne
Im having starting problems.I bought a new Starter relay.Where is the starter relay hidden?Im begining to think it doesent have one.Please help !!!
i replaced the fuel pump and it is working properly, what can be my problem?
Did you fix it? I'm having the same problem with my Windstar!
any luck yet?
My 99, 4.0 ranger has a hard time starting when its cold out and it has sit over night. I usally have to crank it twice until it will start and when it dose start it hesitates a little and then idles fine. I have replaced the idle air control and the fuel filter. The engine runs good and strong. Could bad plugs and wires cause hard starting? Any Ideas:
thanks,
mike
i'm guessing key chip sensor is faulty?
easy fix?
One thing to remember. When autozone tests your starter. Its a no load test. Meaning if you are having problems with bad bearings in your starter it wont show up there. I would pull the starter again, and hold the gear in the nose, and shake it. If you hear a clunking sound, its not a good sound. You need to replace that starter, the bearings have gone bad. You can also just look at the bearings in the nose and see if there is alot of play there as well.
One more thing. Is the positive cable getting warm to the touch when you are jumping the solenoid?
If so I would also do a touch inspection on the ENTIRE length of the battery-to-starter positive cable. If it has rubbed on the exhaust or frame in a hard to see place, you wont notice it, but it will ground out the starter every time.
Electricity chooses the path of least resistance, and that starter is a huge resistor when engaging the flywheel.
You need 100 amp hours to fully charge a completely discharged battery. So to figure out what you think you need, if you charge a battery at 2amps for 8 hours that is 16 amp hours. The faster you charge a battery the faster you wear it out. A fast charge (over 20amps) will cause the lead plates to vibrate and shake off material, and you risk overheating the battery and boiling out electrolyte.
If your solenoid is clicking, I would say you probably need atleast 10-20 amp hours. So if you take it to wally world, and have them charge it on slow charge (2A), leave it with them for atleast 5hrs or all day. Then have them test it for you with a load. Have them burn off the top charge though, otherwise it will test wrong. They can do that by connecting it to a car with jumper cables and turning the lights and fan on in the car for about 10-20sec.
Check your air filter... IAC might have a problem, can you pull the plugs and they are wet?
How bout checking compression? I put my finger in the plug hole and turned it over (it blows my finger out pretty good) )
Can it fill a quart jar in less than 30sec? Pressure release valve (fu le)under the hood you open it and gas comes out, it real good
-Adam
Hubbles
-Bad solonid. Aren't they separate on Fords? On the left inner fender?
I don't know if Autozone, etc can check a solonid...
THANKS 06GLIDE1
My truck will periodically not start after being driven short distances. It will turn over like nothing was ever wrong with it if it sits for 30min-1hr.
More frequently it has been also shutting off while I am driving. I will then have to sit for 15-30 Min before it will start again. Sometimes I'll be able to get where I am going after this, but other times it will shut off again in a mile or two.
I have replaced Solonoid, engine coil, had a tune up and a new starter put on the truck.
Nothing has fixed this problem, what else might it be?? :mad: :sick:
what the heck is it???????????
If not, the first thing to check is a fuel pressure relay. There are 2 or 3 relays by the main fuse box under the hood. If it is bad, the fuel pump will not work.
There is also a fuel cutoff switch just under the edge of the carpet, on the 'hump', on the passenger side. This switch is to sense a rollover situation and shut the fuel pump down. Sometimes these malfunction.
And, of course, the fuel pump itself inside the fuel tank.
I have a (94 ford ranger V-6 3.o automatic tranny
