Quick Links
Quick Links
Are you under 40 and think that you might not be able to afford a brand new vehicle when you purchase your next car? If so, a reporter would like to talk to you. Please reach out to [email protected] by 12/16 for more details.
Chevy Blazer Starting and Stalling Problems
I have a 1974 Blazer with a 305 in it, I just replaced spark plugs, cap, rotor, wires, fuel filter, some hoses and PCV valve. It starts up strong, runs fine for a bit - drive it around the neighborhood - then once I come to a stop it basically dies on me, sometimes it will start right back up again - sometimes it will just crank and crank.
What other things should I be looking at, fuel pump? Can a bad coil cause this??
I would appreciate any help, thank you.
Pressure test NOT normally done by auto stores but they may have a free reantal tester to use at home or take to a shop and they will do that and the filter plus analyze the problem so you don't throw too many parts at it.
The mileage is 124000 and the year is 1996
Changing the coil this morning.
Sounds like your emissions system isn't working properly or your fuel filter needs to be changed.
Is your service engine lite on ? If so have your dealer or mechanic check your codes to see where the problem may lie
Brian
First things first is maintenance schedule and until that is up to date even the shop will insist on a few parts to eliminate reasons.
1. Plugs, cap and rotor, plug wires, PCV (100k max miles) - most common reason for misfires, crossfires, bad running.
2. Air and fuel filters (30k normal by conditions)
After those there is the MAF sensor to spray clean, EGR possible carboned up, etc but do the above first. Plugs are easy to do thru the wheel well openings and only #3 has the steering shaft in the way and is a pain. Plug wires take awhile to snake around and don't pull hard on them and use dielectric grease in all ends and on drivers side watch order as its in cap 3-1-5 order (pass side is 2-4-6) and cap is marked - do not buy the cheapo stuff - if will fail - has on me and drives you crazy later. Cap has 2 torx screws holding on and you have to be careful and don't drop the screws in the dist! Rotor same thing.
Hope that helps and good luck - 176k is great. How is the Coolant doing - 3 years should be changed and 4.3s are known to have leaking lower intake gaskets by 100k normally so watch the level - new thermostat and Stant cap with the flush change is recommended to keep it going - another forgotten thing till it has problems.
SO BEFORE YOU SPEND NEEDLESS TIME AND MONEY, CHANGE THE PUMP. Gaurenteed to work!!!
This isn't to say new plugs and wires won't help, but trust me on this, it's the fuel pump!
Since October I have had no problems with the vehicle until December 18th. I went outside in the morning and attempted to start the truck and like before, it wouldn’t start. It turned over ok but would not ignite. After waiting still no joy. I had the vehicle towed to the dealerships garage and was told it was the fuel pump and would cost $425.00 to repair.
My issue is when I bought the truck it had the 60 day warrantee. I informed the dealer of this problem during the warrantee and was told it was a notorious problem with the anti-theft system and not to worry just to let it sit and it would start again. I told them this was the same problem as before and was told it wasn’t the fuel pump before because fuel pumps just don’t stop working then start working again.
I called a reputable Chevy dealership and was told the anti-theft system would not allow the truck to turn over and that furthermore it was possible for the fuel pump to malfunction and then begin functioning again.
My questions are...
1. Do you think it was indeed the fuel pump that was prohibiting the truck from starting?
2. Is it indeed possible for the pump to malfunction and then begin functioning again?
I am paying for the repairs however; I intend to file a complaint with the NYS Attorney General regarding my warrantee not covering the repairs. Any insight anyone could give would be appreciated.
Thanx Frustated Auto Guy
:confuse:
Thanks Frustrated Car Guy :shades:
It had been running just fine when one day I tried to start the vehicle and all it did was
turn over and over. I put some fuel down the throttle body and it started and ran momentarily.
I waited about a half hour and just for the hell of it I tried to start and vehicle again and it
started and ran for two months without another incident.
Once again 2 months later the same problem occurred and this time I took it to a dealer
and they replaced the mass air flow sensor, fuel filter and fuel pump. Vehicle ran fine
for 1 month but Friday, every time I stopped at a stop sign or tried to slow down to make
a turn, the engine would stall. I would crank it over and over and it would start again
but as I tried to get it back to the dealer the engine was starting harder each time
( meaning it would turn over and over more before it would start).
About 6 miles from the dealer, the engine stalled and would not start again. After about
20 minutes went by for some reason it fired up and has been running fine ever since.
The dealer put their Tech 2 code reader on it and there was a code shown something about
a loss of communication from the BCM but it had rechecked and passed sometime during the
last 20 miles of driving. I have no service engine light on at the present time.
Is my computer going bad?
Does anyone have any ideas?
on and goes off at will, usually when we are
driving down the road. Would this connector cause the vehicle to stall when slowing down or stopping?
Is this a part I can purchase somewhere
or do I need to pull one from a junker?
