I dont think I should be charge since this problem wasnt because I didnt take care of my truck but due to their faulty transmission and they have a recall on it. I was wondering if any of you who had the same issue did any of you have to pay for the repairs. Can you guys let me know asap before I go pick it up and hopefully the truck will not stall on me again. I hate having to ask for rides to go to work and/or pick up my kids from school. Single mom here that needs all the help she can get.
thanks.
HELP!! :confuse:
I wish you no bad luck but I am willing to bet the Pacifica will stall again. BTW Consumer Legal just settled my case.
Good Luck
Signed No More Stalling
Stopping episodes I could not take it anymore. I drive too many miles to work and did not want to take a chance on getting stranded.
Angela Thompson
after putting it in to park and turning the key to off then turning it back on it run just fine
i more in like will have to send it in so maybe about a week i will post again
VERIFICATION
Place gearshift lever in gated park (P).
Attempt to move vehicle by rocking back and forth on level ground. If vehicle does not move, attempt to start engine. If engine starts, the park position is correct.
Set parking brake.
Turn key to on/run and depress brake pedal. Place gearshift lever in neutral (N).
Attempt to start engine. If engine starts in both neutral (N) or park (P), gearshift cable is adjusted properly. No adjustment is required.
If engine does not start in either park (P) or neutral (N), perform adjustment procedure.
>>ADJUSTMENT
Park the vehicle on level ground and set the parking brake.
Place the gearshift lever in gated park (P) and remove ignition key.
Loosen the cable adjustment screw at the transaxle manual valve lever (Gearshift Cable Adjustment).
Pull the gearshift lever fully forward to the park detent position.
Release the park brake, then rock the vehicle to assure it is in park. Reset the park brake.
Tighten the cable adjustment screw to 8 N·m (70 in. lbs.). Gearshift cable should now be properly adjusted.
Verify adjustment by using the verification procedure
Recall Number: 06V432000
Dates Manufactured: JUL 2004 to NOV 2005
Number of Vehicles Affected: 127928
Date Owners Notified On: NOV 2006
ON CERTAIN PASSENGER VEHICLES, THE FUEL PUMP MODULE AND THE POWER TRAIN CONTROL MODULE (PCM) SOFTWARE MAY ALLOW THE ENGINE TO STALL UNDER CERTAIN OPERATING CONDITIONS.
Consequence of Defect:
THIS COULD CAUSE A CRASH TO OCCUR WITHOUT PRIOR WARNING.
Corrective Action:
DEALERS WILL REPROGRAM THE POWER TRAIN CONTROL MODULE. THE FUEL PUMP MODULE WILL ALSO BE REPLACED ON VEHICLES BUILT FROM AUGUST 1, 2004 THROUGH SEPTEMBER 30, 2004. THE RECALL BEGAN ON NOVEMBER 21, 2006. OWNERS MAY CONTACT DAIMLER CHRYSLER AT 1-800-853-1403.
there is also another recall just to let people know
Recall Number: 05V066000
Dates Manufactured: JUL 2004 to JAN 2005
Number of Vehicles Affected: 43180
Date Owners Notified On: MAR 2005
CERTAIN SPORT UTILITY VEHICLES EQUIPPED WITH HALOGEN HEADLAMPS MAY EXPERIENCE AN INTERMITTENT AND EVENTUAL TOTAL LOSS OF HEADLAMP FUNCTION.
THE HEAD LIGHTS MAY NOT OPERATE PROPERLY WHICH COULD RESULT IN INTERMITTENT OR NO HEADLIGHT FUNCTION. THIS COULD IMPAIR A DRIVER'S VISIBILITY, INCREASING THE RISK OF A CRASH.
Corrective Action:
DEALERS WILL INSPECT, AND REPLACE IF NECESSARY, THE WIRING HARNESS AND LOW BEAM BULB ON BOTH HEADLAMP ASSEMBLIES FREE OF CHARGE. THE RECALL BEGAN ON MARCH 28, 2005. OWNERS MAY CONTACT DAIMLER CHRYSLER AT 1-800-853-1403.
You are not alone with the problems with your 07 Pacifica. Mine has been intermittently stalling for over a year now. Three separate Chrysler dealerships and Chrysler themselves know about my particular problem. Many sleepless nights and hundreds of phone calls later, this is my last weekend owning a Chrysler. I think what broke the camel's back was an incident last month where I was traveling at 50mph and stalled in front of a packed elementary school bus. Simply because these problems cannot be duplicated, I have been spoken to and treated as if I am the one in the wrong. My Chrysler case manager recently told me that Chrysler can do nothing about my problems. So you are not alone. We all feel the pain.
When the temperature is hot outside, my car will not turn over - at all. No clicking, no noise, complete silence. I turn the key in the ignition switch all the way to the right, and I have to either apply so much pressure to get a response that my key may break (it is already bent) or I have to open all the windows and doors and allow the inside of the car to "cool down" before trying again. This can take anywhere between 15 minutes and a half hour. In winter it isn't as bad, and I can get it started better if I park the car under shade or inside a covered garage area, but even it is getting worse.
How would inside car temperature affect the ability to turn over the engine? Is it my ignition switch?
Something in the switch mechanism may be damaged just enough to not allow proper operation during that heat expansion.
kcram - Pickups/Wagons/Vans+Minivans Host
1) Under the tire well above the dog bone for suspension is a Negative or ground cable bolted to the transmission this sometimes comes loose and will prevent your car from starting or even turning over.. There is also a harness that passes over this bolt which will rub out on the back side in time.. This will cause problems in the egr, i.a.c., t.p.s and Ats.... Fix the wire fix the problem
2) if you open your hood under your battery not directly but down low youll see your solenoid packs and other transmission sensors follow these to the thicker wire harness down to wear it almost touches the frame and meets other wire harnesses... The back side of this "crossroad" rubs up against some kind of flange on the transmission with bolt holes in it.. This is the problem with transmission issues in the 2004 Chrysler Pacifica 3.5l.. Fix the wire fix the problem!!! I spent alot of money on parts to figure out this simple easy cheap fix.. Make sure to reinforce protection in the back of theose wires during fix.. Hope i save dyou some
