its also a pretty cheap way to fix it .. as well .. the bearings are not terribly expensive ..
tt
2002 silverado.
My major problem with the Silverado brakes is in the emergency brake which has never worked right and now doesn't work at all. What a hokey design!
the brake pedal goes to the floor
does anyone know or experince this problem thx donnie
We all bought a really nice looking plastic truck, we should be proud to own a Chevrolet, besides, they are made in America, (Well, thats not exactly correct, most of them are made in Canada).
Maybe we need to give them another "Stimulus" to help them deal with all the defective brake lines, and other defective parts. Buy AMERICAN, yeah- right!!
I will continue to post my fact based accounts of my actual events so that future accidents can be prevented and lives hopefully saved. I would appreciate it if GM contacted my directly, compensated me for the thousands of dollars in premature fluid line replacements and provide suitably engineered replacements to the trucks that are on the road today. At this point, a 35 year GM customer is no longer, as well as family. Dear GM Customer Service, this problem started under warranty and some lines were replaced at that time so this IS a design problem. Further, I am on the second round of replacements, proving it is not just a one off manufacturing defect. I would be happy to assist your engineering department if they are struggling to reproduce this in their labs. I know you have salt spray test labs and required life tests for your products, because I have personally worked in one of your facilities. I strongly suggest you bring this problem to your engineering department, and stop simply referring customers back to the dealer. If you drive a smaller car and have children in the back seat, ask yourself next time you see a GM truck close behind - does that truck have a brake line that is about to burst? Is the driver following to close, worse, is he towing a 10,000 lb load?
I have already submitted a complaint to the NHTSA with little more than an automated response. The ODI # is 10414892. Attached are the pictures of my brake lines that failed due to extreme corrosion on my 2004 Siverado 2500HD. The current mileage is 63491. VIN #1GCHK23UX4F230932. I cannot understand why, with all the complaints, that your current investigation stops at 2003. This is NOT a normal failure. I have vehicles with over 200,000 miles on them that show no such corrosion on the brake lines. This is obviously an engineering failure.
As an aircraft mechanic I know that all government safety standards are written in blood. Thank god my families was not spilled, but I know that someones will have to be to get the government to act! I was, as so many are, completely unaware of this issue until I had to look up the replacement parts. Low and behold, countless forum's erupted as a result my Google search for my truck model's brake lines. Why don't you put out at least a TSB? I'll tell you...no one wants to tarnish General Motors' reputation any further. Instead your division of government is satisfied to turn a blind eye ("Investigating" for 3 years) until someone is killed in a wreck caused by this failure. Then it will be, "This is a travesty, how could this have happened?" and the headlines will continue. These trucks weigh 9400 Lbs and routinely are towing something, so most likely, MORE THAN ONE FATALITY WILL BE INVOLVED! One of these trucks is most likely is behind you and your family every day.
I know your hands are tied by beauracracy, but I implore you to do what is right. At minimum, force a TSB so people are not oblivious to this DEADLY defect. I refuse to believe that any human being could knowingly ignore the possibility of preventing even one fatality.
I hope you understand that I am writing you this to ensure this stops happening, and that you expand the year models involved. Look at the forums. This is a widespead problem, further forward than 2003.
Thank you for your attention to this matter.
My truck is a 2005 Silverado 2500HD with 22,000 miles. My regular mechanic said that they have seen this at least 20 times. Same rusted lines at the ABS unit under the driver’s door. I don't plow, it's obviously not my daily driver, and it has always been parked on a paved driveway.
My nephew was using it to move firewood and I am so glad that he called me when he felt it wasn't stopping right instead of continuing. My mechanic is going to replace all the lines with a nickel/copper alloy product as well as the hoses and the calipers because the bleeders rusted completely off. $1500.00 estimate. There goes the vacation. I will start contacting the dealer, GM, and NHTSB tomorrow. I'm going to tell everyone I know.
On a side note, my dad has a 2007 Silverado 1500 with 3 times the mileage. He lives 2 miles up the street, on top of a hill that gets extra "salt" in the winter and after a quick look under his truck I could see no rust; neither does my 2003 Camry which has over 115,000 miles and is my daily driver in most snow storms. (Fuel economy)
Thanks for listening
I apologize for the problems you are experiencing with your vehicle. Are you having the issue fixed by a GM dealership or an independent shop? Please keep me posted.
Thank you,
Caron, GM Customer Service
The ABS engages at about 5-7 mph just before it comes to a stop. It still stops ok since ABS only affects the front and fresh brake disc pads all fours, plus new front rotors and emergency shoes at 193k. But this is really bugging me. If I hit the brakes HARD it doesn't do it, just when stopping normally or even very gently.
I just had the ignition switch replaced which was causing power loss to the fuse box on specific circuits that caused the blower motor to quit, ABS light, brake light, and service 4wd message, and no 4wd. That was that way for a few months since nobody local wanted to mess with it and the dealer is 45 minutes.
All that is fixed, but now that the abs is working it is engaging incorrectly. I have driven over 150 miles and still doing it. I had a wheel bearing clicking after long highway runs at 165K so I replaced both hub assemblies without changing wheel speed sensors. Then got a abs light last year and I changed a wheel speed sensor to fix that. I am getting no codes or lights.
From all the posts, it sounds like I should clean my wheel speed indicators and the mounting on the hub, then check hubs for wear/slop, then check vehicle speed sensor in transmission. Anything I should add?
As for service, it all depends on the dealer and their mechanics. Some are amazing and some are as dumb and helpful as a box of rocks. Just sayin'.
2002 Chevy 4x4 pick up,
ABOUT 2 weeks later, the mechanic got up, and went to get in to work, and guess what?? That was finally fixed, but some things never change.
GM DOESNT HAVE A CLUE!! I like what you said about there being "NO ACTUAL CERTAIN FIX", cause thats EXACTLY correct. They cant fix it, cause they dont know what the problem is, just like my "Service 4wd" light. After changing BOTH MOTORS, AND THE SELECTOR SWITCH, I Finally got that fixed, but Chevy couldnt find anything wrong with THAT EITHER. GO FIGURE!!
GMCustSERV --here is one last clue--Upset customers that call to complain are much better than customers that never call again. Pick up the PHONE!
Over the span of 32 years, i have had 5 Silverados, (but the 2000, and the 2001 are the only ones that have given me any problems). I've been a DIE-HARD Chevy man all my life!!, but- AND THATS A REALLY BIG BUT-- With the "Stimulus" we gave GM, on top of the cost of their new trucks, then add on the " I DONT CARE" ATTITUDE you get from GM, and the in-ability to ADMIT that there's a problem ( or un-willingness to admit that theres a problem), not to mention that when you take your truck in there, they try to make you look and feel STUPID- Add all that together, and what i come up with is- I'M DONE WITH GM. I wont even buy a USED chevy from now on. Ford didnt take ANY stimulus, my next truck may just have to be a USED FORD.
Thanks so much!!!
ones are available in a two piece design so you don't have to pull the axle to replace them, at least for 1500's) Why GM doesn't use better grade material is, well that's just GMC. Mine only has 50k miles and is garaged etc. All that aside it drives great and really is more of a car than a truck.
The problems I've encountered are: ABS failure nearly resulting in rear ending another vehicle; Parking brake design (premature wearout) is a joke and typical of GM engineering(they are not smart enough to correct it so they went back to drum brakes (rear) in'05. Spongy brake system even after repeated flushing; intake manifold gasket failure. (new aftermarket fixed that). The roof on the extended cab is flexy (newer ones have stress ridges in it). If you fix up the '99 You may want to remove the fender flares and see if there is rust under there.
So even after correcting all the problems on your '99 it could drop the crank sensor (99's did that) and if I had waited until Toyota came out with a full size p/u I'd never have a GMC. And I'll never buy another. A GMC/Chevy mechanic (small town) tells me that the Trucks are nothing compared to the new smaller SUV's. They get at least 10 a day in for problems.
Oh yes my Sierra has Mexican springs and Chinese tail gate cables. Lord knows what's lurking up under the dash. Good luck to you. Hope you get two new Toyota's!!!!!! jaxtix
The pedel squishes to the floor. I've replaced the master cylinder, rotors, & pads & ABS module... and they are only slightly better. It's been properly bled several times. There are no leaks. The wheels are OEM. The tires aren't over-sized. It's like the master cylinder isn't pushing enough fluid to the calipers. Is there a master cyilinder that pushes a larger volume of fluid?
Any ideas for me?
Chris
Did you ever get yours figured out?
Thanks Pat
I apologize for the problems you are experiencing with your vehicle. Unfortunately, I am unable to assist customers outside of the United States. I would encourage you to contact GM of Canada directly at 1-800-263-3777. Hours: M-F 7:30am - 11:30pm, Sat 7:30am - 6:00 EST.
Thank you,
PS. I've also had replaced
- Throttle Control Valve and Gas pedal
- Power steering rack
- Front & Back bumpers replaced do to rust
- Front rotors and pads
- Rear drums turned(machined) x 3
- rear shoes replaced x 8
- rear drums replaced x 6
- all tires rebalanced shortly after purchase
- All windows re-adjusted due to looseness.
- Rear main seal on the back of the engine leaking, transmission has to be removed for this repair. (Scheduled to be repaired Sept. 28/2011)
- I'm now 6000 miles over warranty.
There is more but it was minor.
This is my first GM ! Nobody wants to fix the real problem.
My 19 year old nephew has a 1997 GMC Sierra 2WD Extended cab pickup. It's got over 100,000 miles on it and for the most part he has had nothing go wrong with it until now. Over the past couple of weeks he has begun to experience the ABS and BRAKE lights coming on...when they do...the truck lurches as if it's wanting to die....but doesn't. However occasionally when he pulls to a stop at a stoplight it will die. We took it to a mechanic who put it on a diagnostic and found nothing. They checked the master cylinder and brake lines and found nothing either. I think it might be the fuel filter or fuel pump causing the very intermittent stalling. I had him fill the tank with gas and put a bottle of fuel injector cleaner in it...he says it runs better and hasn't stalled, but the ABS/BRAKE lights still come on occasionally and the truck lurches.
Anyone have any ideas?
I just don't want my nephew getting stranded and not knowing what to do.
Thanks for your help.
Again...thanks so much for your advice, etc.
Patti
I am sorry to hear about your experience. Did you ever have a case with customer assistance regarding your concern. We would be happy to look into this for you with more information. Please feel free to contact Christina by email. Thank you.
Tricia, GM Customer Service.
How would we go about contacting GM Customer service to be compensated for the early brake line failures? I had two rusted out lines in one particular area, but the entire lines severely corroded on a 2003, first within 4.5 years. My expenses to replace all lines was approximately $1300. Luckily, I was able to avoid 2 collisions, but it is was close. It would be helpful. to say the least, if GM did compensate us for this. How do we go about it? I have receipts, pictures and some of my old lines.
Ed
Thank you for your post. Can you please email me your complete contact information including mailing address, VIN, current mileage, and involved dealer? I look forward to your response. Enjoy your weekend!
Christina
GM Customer Service
