Mazda CX-7 Real World MPG
123578
  • nmknmk Member Posts: 111
    This morning, ambient temp mid twenties, exhaust was the color of my Darth Vader Galaxy Grey. After letting it warm up for a few minutes, as my wife drove away, the color hadn't changed much. Yet when she returned, the exhaust was faint and white looking.
    I wonder if the starting mixture is to rich and this may contribute to the lower gas mileage? :confuse:
    Any comments?
  • carlitos92carlitos92 Member Posts: 458
    Very unlikely. There are too many OBDII checks-and-balances to allow that to happen.
  • snowdownsnowdown Member Posts: 1
    when I picked up the cx7 from the dealer one month ago, I found there was some black powder at the end of the exhaust pipe even it was only 20 km on the odemeter. Anybody notice this on your car? Is there any relation between this and high gas consumption?
  • smogdungsmogdung Member Posts: 349
    Any problems with the engine ?
    I'm thinking about a MazdaSpeed3, with basically the same engine but 8-900 lbs lighter & a stick....it won't suck gas like the CX7....I'm used to 30+ in my Alero & 26.5 in our 2.4L HHR ....I'm no tree hugger & fairly well off....but, I don't think I could stand it getting such low MPG!!
    It's normal. It's mostly just a headache when you're hand-washing those exhaust tips! :cry:
    -c92
    So I'm anxious to put some serious mileage on since my return home, to see if there is any improvement in mileage. :blush:
    388miles.
    250 miles of NY Thruway at about 70mph.
    (much on cruise control)
    70 miles of country roads at about 50mph.
    68 miles of many stops, all very local errends.
    Put in 15gls and then 8gls = 23gls.
    23/388= 16.86 mpg. :mad:
    So what could it be? Cold weather, ambient temp high teens to mid 20's.
    Lousy gas, Mobil & Exxon in North East? :confuse:
    These were almost ideal road conditions, steady driving, no
    jackrabbit starts.
    Any ideas or comments?
    Darth Vader Grey GT w/nav AWD
    How many miles do you have on your car now?
  • cxrabbitcxrabbit Member Posts: 134
    I don't know for sure obviously, but I think I've been getting worse mileage since the last PCM update (the one that helps decrease turbo lag and makes shifting smoother). Last three tanks (and since update) have been pretty bad... 13.12 (all city driving), 13.03 (all city driving) and most recently, 15.8 with 60/40 city/highway.
    BUT, it's also been very cold here too, which could also account for the difference.
    Best mileage I saw was before the update, when it was still a bit warmer out (mild winter) back around Christmas... 18.18 mpg with 60/40 highway/city.
    Responding to carlitos92 & cxrabbits questions.
    2700 miles on odometer. Remember I was overseas for 3 months.
    I checked my past posts in this section of the forum and found the following:
    9/27 18.73 trip upto Mt. Whiteface
    10/4 17.97 local driving
    10/4 23.46 Country road pleasure trip :)
    10/24 21.20 some local but mostly Taconic State Parkway :)
    02/05 16.86 Some lacal but mostly NY State Thruway :mad:
    So, something is amiss. :confuse:
    Darth Vader Grey GT AWD w/Nav.
    Sounds similar to what I'm getting here in NY. I do think out winter gas is bad, but I'm suspicious of the last update :(
  • fonefixerfonefixer Member Posts: 247
    Last fill up in snowy and cold Minnesota brought 16.75 mpg (GT-AWD) all stop and go, so I don't think your mileage report is out of the norm for this time of year.
    I'm up to 8,700 or so. Small potatoes for some of the guys around here... :D
    I quit watching mileage closely, but it seems like I'm going about the same distance on a tank as I always have.
    -c92
    There is no mystery here....you guys have 4,000 pound 4x4s with automatic transmissions ....= POOR MPG.......
  • ssteigssssteigss Member Posts: 46
    Here is an interesting websight on the outside effects on gas mileage. Particularly the section on cold weather. This may help to answer why Mileage has been poor. Its been 5 degress the last 2 days in Boston. Some things that many don't consider includes the fact that if you have a short commute your mileage will be significantly worse. My wife only goes about 7 miles to work. By the time she gets there the car is probably at optimum operating temp for about 5% of her drive.(especially in freezing temps).
    I have also seen many complain that they are doing 70MPH all highway so they should be getting great Mileage.. The article points out that doing 70MPH vs 55Mph will reduce you MPG by at least 12%
    Lots more info at the site.
    http://www.artsautomotive.com/Mileage.htm
    "There is no mystery here....you guys have 4,000 pound 4x4s with automatic transmissions ....= POOR MPG....... "
    Boy... I wish it were that simple. I'd counter by saying we also have some of the most (potentially) efficient engines and automatic transmissions on the planet.
    Besides... "4x4" is a stretch. Not everyone has an AWD version, but even so, the AWDs usually operate in FWD mode and only add a couple hundred pounds of weight.
    As long as there are other 4,000 pound unibody vehicles getting mpg in the mid-20's, it IS a mystery...
  • bdymentbdyment Member Posts: 573
    I believe the poor mileage is a combination of weight and an over worked 4 cyl. engine with a turbo. I'll bet the SUV would get better mileage with a 3+ liter V6 normally aspirated. The new Acura RDX is not that great on gas either. Also a relatively small engine with a turbo.
  • wjbushsrwjbushsr Member Posts: 135
    Uh... No.
    The Ford Edge has that line up and gets worse gas mileage than the CX-7.
    Besides, I'd rather have a four in this car, the weight and balance ratio to me is spot on. A six in this configuration might make the car plow in a curve.
  • vbbuiltvbbuilt Member Posts: 498
    Wouldn't it be interesting to have been a "fly on the wall", in the Mazda design studio and watch how the design engineers put together the CX-7 on the drawing boards? Who decided that a turbo 4 cylinder vice v-6, was the preferred engine? What was the criteria? What were the trade-offs? Would a six, in fact, make the "car plow in a curve"? If a six had been chosen, how would the engineers have changed the design?
    Sorry about the O/T, just rambling on. :P
    Vince.
  • sssfegysssfegy Member Posts: 132
    I don't think they would change the design, but suspension would be the major adjusment. I love this car with the turbo, just like the A4T vs A4 v6, the V6 you can feel it's weight in corners, and gets horrible gas mileage for intown driving. I guess more laid back vs sporty.
  • portly_gnomeportly_gnome Member Posts: 15
    I'm fine with the 17 mpg in town. It's never going over 19mpg on the flat, straight, Iowa interstate with a 4 cyl that rarely ever kicks in the turbo that kills me. I drove 212 miles this morning starting with a FULL (past where the nozzel shuts off on its own)tank of gas. Ended with a hair over empty. All highway, going about 72 mph. Haven't filled up yet to calculate, but this is much worse than normal. Could be that it's 6 deg F outside.
    Oh, and it turns out that I do need a new gas cap. And the check engine light went on this weekend. Then off. Then on again today. :mad: This will make the 13th (I believe) time I've had this vehicle to the dealer in the 11,000 I've owned it.The dealer is now on my cellphone quick dial. I seem to call them more than I do my wife.
    Responding to smogdung, please check my original posting #211 and you will see that your suggestion of AWD and nearly 4k of weight just doesn't hold up.
    The mileage on the Taconic State Parkway included 1/2 hour of stop and go for road repair and 1/2 hour on the Van Wyke Expway for 2 fires.
    The Thruway experience was all go on cruise control with about 20 miles of light city traffic.
    The milage difference was Taconic mileage = 21.20mpg. :)
    NY State Thruway = 16.86mpg :(
    Difference = 4.34mpg
    This represents about a 20% drop in efficiency with a difference in temp of 35 degrees.
    And yet, for its size, it is a glorious vehicle to drive. ;)
    Darth Vader Grey GT AWD w/Tech Package.
    I had a 2001 RAV4 (2.0L I think)4x4, it only weighed about 3,000 lbs ..4 sp automatic.....ave @ 22-23 MPG ....I suppose a 4,000 pounder should be expected to get 18-19??
    The RAV was the biggest nightmare I've ever owned....$6000 worth of waranty work during the first 2-3 years!!! On the other hand the brand new '95 Sunfire & 2000 Z24 Cavalier that I bought my son & daughter ...have never been in the shop for ANYTHING (ever)!!! & they are still driving both of them after all these years!!! Those are the 2 cheapest cars GM sells!!! Go figure?
    I wish you were in CO. I would ask you to bring in the Cx7 to inspect...but I honestly would not worry about it till the weather gets warmer..getting that low mileage on the highway could be due to tire pressure? allignment? Wet roads that you drive on? Gas quality? Having that many gas caps..I would be very upset at the dealer that did that job..it's obviously not the problem and they never found it to start, and could be relating to the poor gas mileage. Good luck I hope you get your CX7 tuned correctly by the dealer.
    I wish you were in CO. I would ask you to bring in the Cx7 to inspect...but I honestly would not worry about it till the weather gets warmer..getting that low mileage on the highway could be due to tire pressure? allignment?...
    I'm getting the same type of poor mileage in NY. 13 MPG around-town... and it's only been recently it's been THIS poor. CEL came on last night for the first time so it's going back to the dealer Friday (my dealer has been excellent).
    Knowing of this potential IMRC Valve "issue" that the dealerships seem to admit to seeing a lot of, I wonder if that has something to do with the poor mileage. I read something online (not related to Mazda specifically) that I thought was interesting...
    "The IMRC is a device on the intake manifold that increases the velocity of the air going into the cylinder at low speeds. Increasing air velocity helps in the proper air-fuel ratios.
    "'The issue is that the system also creates a lot of pumping losses, which reduce fuel mileage. By opening up the IMRC a lot earlier to reduce pumping losses, fuel mileage was increased.'"
  • cs2ics2i Member Posts: 9
    hi
    i am one of those that has been frustrated with the poor gas mileage i've been getting, but after reading this forum, have learned i am not alone nor is it an unexplainable phenomenon.
    i recently read about this in the NYTimes, business section- scangauge.com. essentially works as the "missing" a trip computer that i would think would have been easy/smart to have been included in the "tech package" or any other trim level for that matter.
    anyone familiar with this? one would have to figure out where the OBDII port is located and plug it in.
    on reading the gauges included in this unit, one that's missing is a turbo output gauge. can someone educate me and explain if it would be helpful, and why, to instal one?
    thanks, cs
  • rex10rex10 Member Posts: 24
    This car doesn't like short trips. I did a partial tank of gas with 100% "city" driving and tried to keep the RPM's down (below 2500), thinking that would help, but I still only got 15.7 MPG - same or worse than my old SUV.
    On the other hand, driving up to Tahoe with about 25% city driving on that tank I still got 21.8 MPG, which was a pleasant surprise. That's what I was hoping for- much better driving experience than my previous SUV and better mileage to boot.
    Overall it looks like I'm getting 2MPG worse than the EPA rating. Not too bad, but I'd be happier hitting those numbers or exceeding them as has been my experience with other cars.
    3000 miles on an AWD touring model (with factory roof rack).
    You are getting close to what I'm achieving here in cold, (but not snowy) Minnesota. 16.30 MPG in all city driving an AWD GT. Before the weather got real cold, was getting 17~18 MPG in Oct-Nov., so the ambient outside temp does make a difference.
    My valve is sticking as well. Took it in, worked for a while, then the check engine light came back on. There's no reason our MPG should be so bad, other than por engineering and EPA deceptive rating techniques. Whaddya all say... class action lawsuit? ;) Although... this is costing me hundreds of extra dollars, time lost taking the vehicle back to the dealer (up to 13 times in 12,000 miles so far), extra fuel costs, etc. Hmmm....
    That's why the states have lemon laws. If you're car is defective, then you can pursue that route.
    As for suing because you're getting bad gas milage. Not a chance. You made the choice, knowing up front, that the car had less-than-optimum MPG. Everyone knows this and everyone gripes about it. If you really don't like the CX-7, recommend you sell it and find something else. :shades:
    Vince.
  • defreitasmdefreitasm Member Posts: 152
    This weekend I took a mostly highway trip of apx. 200 miles and I achieved 21 MPG. It was a combination of thruway, parkway and state route travel. On the thruway I drove an average of 75 MPH, parkway an average of 65 MPH and state routes 50MPH with some stop and go and twisty, hilly mountain roads. I don't baby it so I probably could have gotten close to the EPA rating if I had kept my speed down to the posted limits and not driven as aggressively as I normaly do. I have 3000 miles on the vehicle and my CEL was on most of the time but I assume it didn't affect the mileage since 21 MPG is pretty good in my book. I have been only able to get between 16 and 17 MPH during my normal daily commute with a mix of highway and city driving.
    Maybe you're able to absorb the cost of driving it off the lot, but most people aren't. So telling us to "sell it and find something else" really isn't an option. Complaining is. :P
    "Maybe you're able to absorb the cost of driving it off the lot, but most people aren't. So telling us to "sell it and find something else" really isn't an option. Complaining is."
    Agreed. But potential owners need to make those decisions BEFORE they step foot into the show rooms. Seems kind of lame to sign on the dotted line then discover they just bought a gas guzzler.
    That's why I can't understand why people complain about the MPG. Well, golly gee, you KNEW beforehand, before you purchased the vehicle, what you were getting into. Complaining about it in this forum isn't going to fix anything. As the adage goes, "You made your bed, now go lie in it".
    Just another rant! :shades:
    Vince.
    "Agreed. But potential owners need to make those decisions BEFORE they step foot into the show rooms. Seems kind of lame to sign on the dotted line then discover they just bought a gas guzzler.
    Just another rant!
    Vince."
    Reminds me of the "callgirl princpal" LOL
    Perhaps it is time to gather some statistics comparing mileage and brand of tires.
    My thoughts are that if someone would design a spreadsheet or database chart that we could all enter our data to, we then might see if it is worth changing brands of tires.
    Price of gas in Northeast = $ 2.60 / Gal. average?
    Cost per mile 17 mpg. = $ .153
    Tire replacement cost (4) = $400.00 (H value 130 mph)
    Mileage needed to break even for
    one mpg gain (if proven) = 2615 miles
    Formula: 17pmg. / $2.60 = $ .153 cost of gas per mile
    4 tires @ $100.00 per set / $0.153 = 2615 miles
    Here is my concept:
    Bridge- Good- Other
    stone year Brand Tire size MPG Miles Driven
    By comparing brands, we then may be able to determine if it pays to change brands.
    "callgirl princpal" ???
    :confuse:
    If you gather enough data I suppose you might establish some trends but I think that the results are going to be largely skewed by driving habits and demographics. In any event, I'm going to buy tires based on handling performance, ride and past experiance but I'll be happy to plug in my info into whatever database someone creates.
    Re: Msg #238.
    Yes I quite agree, except for buying tires based on past experience may not be the way to go, because each vehicle has a particular set of dynamics and tires have improved dramatically in recent years.
    I meant buying based on past experiance mostly for the quality aspects of the tire.
    Wow... apparently I should have given you a call before I signed on that dotted line.
    Could I have maybe done a little more digging into the gas mileage before I bought the CX-7? Well... I guess... maybe... but until I bought it and discovered that instead of getting 19-24 it gets 14-18 in perfect "real life" conditions, I didn't know to research that particular aspect, now did I? Perhaps I should have researched the reliability of the remote start systems as well. But again, I didn't know mine wouldn't work properly until it STOPPED working properly. Nor did I know about the fuel cap, faulty satellite radio, faulty key, faulty windows, mis-aligned headlights, lack of wiper fluid sensor, wipers that won't work when its under 15deg, etc., etc., etc..
    My mistake, obviously, was looking at the window sticker and then unbelieveably, I READ the sticker. I'll never forgive myself for that. My next unforgiveable sin (my family will live in shame for several generations... I should really fall on my sword for this one) was to *gasp* BELIEVE some of those bits of text. I know... I know... hindsight is 20/20. Its obvious to me now that I needed to hire a research company to launch a campaign - no - a private detective agency to delve into the deep, dark depths of the Mazda Engineering enclave to unearth the "real" stats and specs they keep hidden from the unsuspecting public. Perhaps THEN I would have uncovered the conspiracy that makes me appear such an idiotic consumer, and you such the savvy, worldly, omniscient consumer that you are. I'm jealous. :P
    Your sarcasm is to be feared and respected. Awesome. :shades:
    Agree completely on the MPG issues. In my own defense, I use the fact that there wasn't much MPG info on the forums in late July when I bought mine.
    I think that maybe, just maybe, with a K&N-type air filter and 40 psi in the tires, I could hit those EPA numbers downhill, with the wind. That's how the gubment tests them, right? :P
    -c92
    " think that maybe, just maybe, with a K&N-type air filter"
    I confess to being ignorant (OMG, that's a new one for me!) :P But what is a K&N-type air filter? How is that better than the stock CX-7 filter? You infer that it might help MPG? If so, how?
    Vince.
  • rethwilmrethwilm Member Posts: 24
    A K&N filter has less impedence internally and thus allows the more air to flow into the engine. More air, more power while giving 8-10% better mileage. I know that some "hotrods" use them. I used one on my Maxima and it seemed to help. There are several different brands, but I think K&N is the most recognized. Most auto parts stores carry them, but I was not sure that they had one for the CX-7. If someone can let me know if they do, then I will most definitley buy one.
    BTW, buy the "cleaning" kit that is sold separately. The air filter has a lifetime garauntee, but needs cleaning every 10K miles in normal conditions.
    I remember googling "CX-7 performance parts" or such when I first bought mine, and somebody was already selling a CAI. (Cold-air intake, Vince ;) ) I believe that had a new filter included because they had videos on the site of how much "better" the CX-7 sounded with their product sucking in lots and lots of air. Sorry I cannot point to whatever site that was specifically.
  • qbrozenqbrozen Member Posts: 33,892
    Reality and the hype don't agree.
    Do you honestly think that the auto manufacturers wouldn't use K&N from the factory if it meant 10% better mileage? Thereby improving their CAFE numbers, lowering their fines, and increasing sales? Trust me, there is no improvement in mileage to be had from an air cleaner (unless the one you are replacing is REALLY clogged).
    Not necessarily. There is an optimum amount of air to produce complete burn. Too little oxygen obviously means incomplete burn but you can't burn more fuel than is available by adding more than the optimal amount of oxygen.
    SUVs and Smart Shopper
  • carguy58carguy58 Member Posts: 2,303
    what I reccomend is take a look at what Consumer Reports recieved for gas miledadge on the CX-7. I think gas miledadge on vehicles that Consumer Reports tests are more in-line maybe with real world gas mileadge than the gas mileadge the EPA would get for a vehicle. Usually hate to say it but the gas mileadge that CR would get on a vehicle is usually worse than the EPA ratings.
    BTW, EPA ratings for gas mileadge I heard are up for revisions soon on vehicles.
  • texasestexases Member Posts: 11,275
    Math alert - you calculated how many miles you could drive on $400 worth of $2.60/gallon gas while getting 17 mpg. To save $400 by increasing your mileage from 17 to 18, you would have to drive 47,077 miles, more than you'd probably get out of a set of tires.
    Hmmm. I'm sure there is a thread for the fabric filter media debate, perhaps like there is for the synthetic oil debate, but I've always understood that an engine should be thought of as "an air pump." No, you can't improve the oxygen content of the air molecules, nor can you burn more fuel just by putting more air in the intake - but you sure can improve pumping losses and make air travel to the cylinder more efficient.
    My guess is that car manufacturers use paper filters because consumers (and even dealers) would balk if they HAD to pull the filter out and clean the fabric and re-oil it, no matter what the interval. The serpentine intake tubes and resonators in front of the filter are mostly if not completely for sound control, and in the cars where people don't care about intake roar (Corvette, Viper) these contraptions don't exist like they do on a CUV or family sedan. Get rid of all that junk, and assuming you aren't pulling hot engine compartment air, you will offset any lost tract tuning benefits with increased efficiency.
    The debate rages on! Check out K&N Air Filters, bolt-on power?.
    Of course, but it still does not follow that simply increasing air flow will get you there. And, if there were simple cheap solutions, I still have to wonder why the car companies wouldn't adopt them. :)
    A few (ok, many) years back VW&Porche (now European Car) was trying to hop up a GTI through intake mods. They wondered why all the expensive new throttle plates and larger air flow meters weren't helping, so they took the head, air-flow tested it, with the manifold in place, then cut off most of the manifold - no change! It was the airflow in the ports that was limiting flow, and no amount of work 'upstream' of that would have made a difference. This is a (very) long way to say that just putting on a lower resistance filter won't necessarily help, if it's not the 'weak link' in the system.
