I drive about 100 miles to work, and a 100 back. I get a monster headache that lasts the entire week. I can't keep putting up with this. I can't trade in an 06 with almost 80k miles on it and expect anything for it. In this economy, I sure as heck can't afford it.
I know crap about cars, unfortunately, but someone told me about engine harmonizers. One tech guy at the dealer said they're not real mechanics anymore. If they can't visually identify or pinpoint the issue, they can't take things apart to find it. For them to look into the harmonizer thing, is probably gonna be about $300 minimum.
I am not making this vibration thing up either. Driving this much, I'm gonna have a pretty darn good feel about my car and know what's normal and not. This is certainly not.
Does anyone have any suggestions I can do to resolve this?
Much thanks...
The vibration is being caused by the uneven wear on the tires. At least in my car it was, rear tires were excessively being worn on the inside edge of tires. Check your tires to see they show uneven wear, inside or outside edge or even look lick bumps or not smooth.
Hope this provides you with additional info on what else to look into!
Anyone else have any ideas about this? Thanks.
The Sandman
The dealers techs haven't been able to find the issue, though they have acknowledged there is certainly something wrong. If they can't find it, then what? My car is just an 2006 with 75k highway miles on it. It's out of warranty. I find it hard to swallow that there isn't any consumer protection with respects to something like this. Honda acknowledges the problem, yet they can't find it. What can I do?
I went to the dealer as a result of a discussion in another blog about handling problems on slippery pavement. Mine was so bad I had started looking at buying a new//different car.
The dealer will replace the rear upper control arms which (originally) were designed to "tilt" the wheels allowing for better handling. Only problem with this great idea is that it causes uneven tire wear (a prerequisite to having the dealer replace the parts and to do an alignment on Honda) and lack of control on slippery pavement.
Mine was fixed yesterday. My fingers and toes are crossed cause I love this little car and want to keep it.
Also, on my '06 Civic I've been hearing a strange noise coming from the right rear end over certain bumps lately and with two in the back it gets worse. Already have had the rear control arms replaced under warranty. Any idea as to what the noise could be from? Rear struts perhaps?
i>The Sandman :confuse:
1. Has anyone had such excessive brake pad wear in a Civic? At what mileage do front brake pads usually need to be replaced in the new Civics?
2. I'd like to upgrade: What brake pads do you recommend? What rotors?
Thanks greatly for the advice.
I was advised by my mechanic who I have know for 15+ years that it's not uncommon these days for brake pads to need replacing in the 15K + or - range. He says they uses cheaper materials and smaller pads, etc etc.
12K seems a tad early but not far from when I had to change mine.
My wife's 05 corolla needed front pads at around 17K and she drives the car very lightly so it seems to reason, brake pads just don't last as long as they used to.
I have read similar complaints about the brakes on the 2006 Civic so there possibly could be a problem with some of the break calipers on this model causing premature wear.
Search this message board for at least one excellent post on aftermarket pad and rotor options sent in by a Canadian Civic owner a few months ago. Good Luck.
NOTE: It's message # 1023
PS My major gripe with my car are all the annoying little rattle sounds that must result from the hard interior materials. My EX has a subwoofer which causes constant vib rattle that is very hard to locate.
I have 24000 on my 2007 civic coupe, and was just told that I need 2 new tires and new brakes. I have had both front struts replaced and the rear control arms replaced too. I have read online that bad struts put extra strain on the tires, and cause extra wear, but Honda is telling me that it is normal to need new tires at 28000. I have NEVER needed new tires that fast on any of my cars, and I don't think that I have ever replaced brakes before 60000 miles.
Any suggestions?
To describe the issue, when your car is off, and you manually lock your steering wheel it's locked into place...imagine turning your car on and you get the same feeling, luckily my first thought was to turn it off and turn it on again,,some times I have to do it a few times until it feels normal again.. Weird and scary..
Any suggestions? Advice
Its weird..we'll see..
I have never had this problem on another vehicle, including the two other Hondas I have. Anyone else had this problem and had it corrected? What would cause the interior of the door assembly to get wet and dirty?
I am trying to figure out who I believe on this one...my daughter's 2006 Honda Civic was in an accident back in September 08, and was repaired (including a replaced radiator). Feb 27th 09 it overheats and we're told it's got a blown head gasket.
Now the insurance company is claiming that the mechanic improperly bled the coolant system, causing an air bubble that eventually caused this massive failure. They don't want to pay, and Honda doesn't want to fix it under warranty because they think it's faulty repair. The mechnic says it's crazy...why would it take that long for the car to fail?
Who to believe? Does this seem likely? What should my next steps be?
Thanks in advance...
John
Let us know how it turns out
Last Thursday I came to the conclusion you did and walked in to my mechanic and said, "looks like you guys blew this one." He agreed to do the tear-down for free, fix it free if it was his fault, and give me the labor free in any case. We were going to call back the insurance adjuster if he found cause, and (btw) there was an outside chance Jiffy Lube had something to do with the problem...HOWEVER...my ex called me two hours later and said, "I don't want that guy touching this car!"
Her idea was to pay the dealer who diagnosed the blown headgasket to do the teardown ($1500--ack!), have it fixed by Honda so they'd be on the hook, and somehow sue my mechanic. I still like my guy--he's been jake for 12 years--and I thought he ought to be on the hook for it. I thought her plan was impractical (and I don't share her devotion to that warranty), she thought I was crazy for letting the mechanic at it again. I threw up my hands, and she started talking to lawyers and other mechanics.
The upshot is that she had it towed to ANOTHER Honda dealer and that one diagnosed the ill-fitting clamp. That should have been visible...right? My daughter says that there was some pressure test that had to be done and that it couldn't be seen, but if you've got leaking coolant it's going to leave some stain. Upshot: it seems likely that my mechnic didn't handle the clamp right...but Honda dealership #1 was WAAAAY off base. What the ex was going to plonk down $3-5k for turned out to be a $100 repair.
Here's one thing I still can't figure out: we keep going over the issue of the "aftermarket radiator." I'm not sure I even know what that word means any more...my mechanic showed me the order from State Farm with the part number, the order system he used to buy that part, and the part # on the receipt from the parts warehouse. There were two versions of the part: one from Japan, and one from the US...he said he thought the 2006 Honda was too new to have an aftermarket radiator on the market at this point in any case...but the dealer claims that a radiator should have some Honda stamp on it if it's "genuine." I'm not sure what to believe about that...or even if I should CARE at this point! Any advice on that would be gratefully received.
Per another respondent here...I have my daughter watching the gauges like a hawk. Thanks, again, to the posters here...
Did spend some time sitting in a '09 Fit Sport and the seats hug one better than the Civic's but don't like the dash layout at all...the Civic's is far superior to me. It did have a carbon fiber add-on kit which helped the dash overall look, would look very nice on the Civic dash also. Might check into that at my local auto accessories guy. Just gave the dash a more polished, finished look.
Probably silly to spend the $ on such an item but loved the custom look. Also have been toying around with a front strut brace for the car. Would it really improve the car's handling characteristics or is it really a waste. Will check out that dash kit tomorrow though.
The Sandman :shades:
2023 Hyundai Kona Limited AWD (wife) / 2015 Golf TSI (me) / 2019 Chevrolet Cruze Premier RS (daughter #1) / 2020 Hyundai Accent SE (daughter #2) / 2023 Subaru Impreza Base (son)
Also, in the same article, note TSB 09-007 for replacement of "drive belt tensioner pivot bolt and a rerouted drive belt" for some 2006 Civics. Honda will sent out a notification letter and the repair will be free.
Way cool!
Just love my Honda and they've got a customer for life I suspect.
I try to keep track of miles per gallon achieved by my car, and to that I've observed that car drives about 375 to 400 miles in one tank of gas, so I reset the trip-meter to zero on each fill-up and get the gas again before trip meter gets to 400 miles. I use this primarily to keep track of cars miles per gallon, but it has also made me less dependent on the 'need fuel' indicator light.
