remove your glove box door and you will see an grid opening in the upper right hand corner. reach your fingers in there and see if you can feel the recirc door laying there . If so then it broke. You can remove your blower motor. It has 3 screws holding it. You can use a flat blade screw driver, or a T20 torx. reach your hand up inside and twist and pull the broken door out. Your air flow will be improved. That will get you by until you can get the housing replaced.
remove your glove box door and you will see an grid opening in the upper right hand corner. reach your fingers in there and see if you can feel the recirc door laying there . If so then it broke. You can remove your blower motor. It has 3 screws holding it. You can use a flat blade screw driver, or a T20 torx. reach your hand up inside and twist and pull the broken door out. Your air flow will be improved. That will get you by until you can take it into a shop or take the entire dashboard out to replace the recirc door housing.
The system is built to choose between either external or internal air, never both. With the door removed, both the external intake port and internal intake port will be open. At highway speeds, air will flow into the external intake vent and directly out of the internal intake vent...like having a window rolled down all the time at 70mph. You will feel a strong air flow coming in under the dash and this will kill any heating or AC efficiency. The door has to be replaced to get back to optimal performance.
http://www.heatertreater.net/
What I usually do is remove the forward screw of the blend door motor and carefully pull it off and swing it out of the way pivoting on the other screw. It is difficult to remove the other screw due to how close it is to the floor. Once the blend motor is out of the way you can use a pair of needle nose pliers and pull the plastic coupler out. if it cracked replace it and reassemble.
I have the "wild vents" syndrome where my vents at throttle switch to defrost.
I have done the following to locate/fix the problem but have some questions to get me further....
1. checked ALL vacuum lines with a vacuum pump. ALL lines hold vacuum except for the very thin vacuum line that goes through the firewall behind the glove box into the heater core housing area. This line holds vacuum for no appreciable time. Line does not seem to be damaged going into the firewall.
2. Installed the ram TSB fix for "wild vents" A 35mm cannister looking check valve/vacuum reservoir at the line before it enters into the firewall.....This helped the problem and allowed me to accelerate mildly before I lost enough vacuum to switch to defrost. It also recovered a little quicker but did not fix the problem anywhere close to acceptable.
3. disconnected the GREEN vacuum line that goes to fresh air door vacuum controlled pump behind the glove box. (it was the only easily accessible vacuum line I could get to. while I can see/feel the vacuum line coming into the firewall from the engine compartment, I cannot get to it easily to trouble shoot it.) I observed the following..
-While my vacuum tester is connected to the green tube with the ignition switch to on but engine not running, AND the defrost/vent switch on max a/c; I get a quick vacuum loss until about 4" of vacuum, then a pretty good hold for about 30 seconds. Then I lose all vacuum and it switches to defrost.
- With the engine running, I get normal vacuum at idle on the green vacuum line under max a/c, but a loss of vacuum on this line on every other switch setting and it goes to defrost.
-switching the defrost/vent switch while the engine is running to different settings seems sluggish but it does switch.
My question are (sorry for so many):
A. should I expect vacuum hold on the line going into the firewall to the climate control system?
B. How can I test the defrost/vent vacuum switch? I tried to pull off one of the colored connectors, but it seemed like I was going to rip the tubing in half so I stopped. Can I unscrew the two nuts on the back of the switch to disconnect the connector and isolate/test each port? If so, what am I looking for? This step is VERY important to me because it keeps me from ripping my dash apart further if necessary.
C. If my testing of the defrost/vent switch turns out that the vacuum problem is somewhere else, where/how do you recommend I look/test?
D. could my problem be corrected by installing another check valve/vacuum reservoir inline or make-shifting my own much larger vacuum reservoir?
Thank you for your help with this issue. I hope my trouble shooting makes it easier for you to give me an accurate diagnosis.
I got in it to leave, put the A/C on, and heard the low rumbling ubstructed air sound and got very limited A/C from the vents. I left the truck right where they parked it, and went back in and gave them the keys and asked to have A/C repaired.
Three years old, 19,600 miles!!! Three year, 36,000 mile warranty. What was this? A used car?
Please help.......Should I look at a new/used blower motor, or try the resistor 1st - at Autozone, the resistor costs more than a blower motor??????
What say anyone with a solution? THANKS MUCH............../ Don
Corkscrew
Thats a good video.. would you be able to make one for a 2001 second generation 2500 diesel .. the Blend door in ours is either in the all the way Hot or Cold.. no adjustments inbetween, except for me in the passenger seat turning it on and off... also wonder if our air conditioners leak is under the dash there too, cause we can't locate that in the engine compartment.
Those Dash's are complicated to pull... and we would like to be able to fix it without tearing the dash out. Is that possible? anyway..Figure we'll fix it after we replace the tranny that just went with only 58,000 miles on it!!! Brother it's always something, this ones been a beast, bought it used and it's been nothing but trouble. :sick:
I've posted our problems before in this forum.. But you made a very nice video there. Hope you can make some more. Its Very helpful to see how its done~ Thanks~~:)
If the motor is good and the blend doors work properly and are not broken there is a reason the computer can't find a stop point and it goes into limp mode. Most problems occur due to problems with the limit pins or the doors. Check the switch just to rule it in or out.
Jim
I am working on a heater blower that quit. I have gained access to the rear of the blower switch.
I don't have voltage at the blower switch or the motor connectors. The common terminal at the switch connector is good.
I suspect a relay or a fuse.
I checked the motor. it runs with a direct connect to the battey.
I check the resistor. It has continuity across each of the three circuits.
I need to know if there is supposed to be + voltage at the switch or is it at the motor connector and where it comes from. ie. a relay or fuse or both. Where are they found to check them?
I just bought an 02 "cream puff" 1500 SLT v-8. So far the only problem I've noticed is that the two vents on the driver's side are blowing cold air while the other three vents are either blowing hot or outside air. Any ideas?
Bud
kcram - Pickups/Wagons Host
Since last winter, the heater does not put out very hot air, warm at best. The fan is blowing and appears to work in all various speeds as air volume increases and decreases as expected. Vents and air distribution seems to work properly as air blows from defrost vents when set on defrost, floor when set on floor, dash when set to dash, combinations, etc.
At the max heat setting, the air being expelled is luke warm regardless of outlet setting. Not pleasant when it is minus 20F in the middle of winter. Thermostat is good. Heater lines feel hot. No coolant leaks inside or outside.
Any ideas? I have read about a blend door problem door that seems common to this era of RAM truck, but most sound like they pertain to dual zone climate controls. Does this sound like to the case here also? Or something else maybe?
/Don
I did read through many of the entries in this thread, but none were exactly as mine. Yes, they were similar, but not the same. The most similar previous entries mentioned problems with cold air coming out both sides or one side when heat was desired. I have warm air coming out both sides, not cold air. And I do not have dual zone, which the others all had. Maybe that is not important and makes no difference??
I am gonna guess that I have a problem related to others that are similar, even if slightly different, and it appears that the blend door is the culprit.
Thanks for the information....I did what was indicated and sure enough the door was broken and I removed it...Can you tell me what the purpose of that door is? Will it hurt the vehicle to NOT replace the door?---Buddyruff
