Thanks !!
Actuator Recirculation Motor (on the far right of the unit) - Moves the large recirculation door that I can see and feel by removing the recirculation fan on the passenger side.- mine operates properly by changing from a Max setting to any standard setting for the area desired to be heated or cooled (switch on the far right of the three climate control switches) I can actually view the door moving and it is intact.
Actuator Driver (second actuator motor from right side that operates two doors in unison) - Motor operates properly when selecting the middle climate control switch to either hotter or colder. The actuator rotates properly with switch movement. I disconnected the metal connector that operates the two flapper/blender doors in unison, and both doors appear to feel normal but I cannot visually see them.
Actuator Mode 1 - I was able to remove the actuator motor and it rotated properly when the correct console switch was moved (can't remember which one). By moving it with my hand, I was able to turn the white mechanism that the switch controls, and feel that the door seemed normal and that the limit stops were working properly. I could also determine, that by manually moving the door while the blower was on, the air would change direction to the correct area.
Actuator Mode 2 - I cannot access the motor to remove it since it is behind the metal framework that the repair video says would need to be cut out, but by looking into the floor area vents with a flashlight, both doors seem to move properly when going from floor selections to defrost selections on the middle console switch.
Both of the hoses to the heater core feel warm when I checked them from the engine compartment at the point they enter the firewall. There is also a proper level of radiator coolant/antifreeze and the Air Conditioning cools just fine on a hot day.
I still cannot determine why I would be getting warm air from the passenger side and cold air from the driver's side. Please help.
We usually don't use capital letters, no offense intended.
Corkscrew
Corkscrew
You would think an aftermarket company would come up with a better replacement part or system. I would certainly by it since I plan to keep the truck a long time.
Wish I could give you better news but $500 is about the norm.
Help my six months is almost up. What should I do?
fann
And sorry if someone else asked this, but it recommended 350 posts which I do not have time to read thru.
thanks again.
