Caravan/Town & Country Electrical Problems
My wife's 2005 T&C has been acting up. All of the dash warning lights will come on and all of the gages will stop working, even the temperature readout and cruise control will stop working even though the car is still running fine. Last night was the third time into the garage. It just came out of the garage which they said a module in the computer had to be replaced. They had the car for four days. Yesterday, the same thing happened so we brought it back.
When you turn the car off and start it back up, everything's okay for a while and then the lights come on again.
Anybody else experiencing this problem and are there any suggestions?
I replaced the crankshaft position sensor, located on the bell housing, with a $35 part from NAPA and that fixed it.
You can do a search over on the Caravan boards and find more info.
1] We will be driving down the highway and the van just turns off.
2] We can be driving and the guages lose all power, there are no lights on in the dash, and the engine light goes on and the alarm set button turns on.
3] We turn the van on and it stays on for about 3 seconds and dies. At the same time there is no power to the guages and there are no lights on in the dash. This can happen anywhere -- at a rest stop, a grocery store, a national park, and we are stranded, sometimes for hours, until, miraculously, we start it and it stays on.
Our last trip to the service center, they had it for a week and they could not find the problem. It is an undriveable and dangerous vehicle. Do we have no recourse?
This guy is a lawyer!!!!!!!!!!! He doesn't solve your problem, he's not a mechanic He will share your problem with the world and try to make money of it!!
Just go to your mechanic or Chrysler dealer and have it fixed!!
Willem
Also, the driver's powered window stopped working. The control switch was acting up before and then it stopped working all together. Please advise.
A year ago you wrote " I like to do some basic maintenance myself such as oil and oil filter changes.
Basically I see that every other oil change I should be also changing the air conditioning filter.
What is the cheapest quality filter that I can use?
For example, I do NOT buy a Mopar oil filter and I use the Supertech oil filter sold at Wal-Mart.
Since this a/c filter needs to be changed fairly regularly, I assume that some of you should be able to quickly answer this question."
I couldn't find a way to reply to that message; however, I have the same question. Did you ever find a source for reasonably priced AC filters?
Patrick/phhill3
2. If you have this kind of filter for a T&C Van, do you also have it for a Pontiac Vibe 2003? If yes, for how much and what would shipping cost me for the two filters?
Patrick
I went to town this morning and the cooling fan stopped running altogether. It got hot and I had to wait for it to cool down before I could get it home. It is a 1996 and has 213,000 miles on it. It's been a great vehicle; I need something smaller because my kids are 17 and 19 now.
Regards
Any one who has experienced a similar situation to this. I have a 2005 town and country with 49,000 miles. Recently, the interior lights on the passenger side middle and back row will come on while driving for no reason and then shut off after a short period??? Any help would be appreciated.
Is there an in-line circuit breaker? Everything else works & cannot find blown fuse.
HELP!
coakleysr
After the weather cools down to 50F, all 3 of them click (unlock), but don't slide.
Sliding manually is working.
After this initial problem, power sliding works OK in both directions.
If a minivan is first warmed up, there is no problem.
A dealer mechanic suggested there could be some door switch contacts oxidizing overnight or sticking. If this is true, where would I find it? Could it be on 3 doors at the same time?
Please share your experinence!
:sick:
In any case, Chrysler is not taking responsibility and I'm very disappointed at this car, at me buying this car, and I just do not want any1 else to suffer the same problem(s)
Thanks Reply With Quote
Also with the key removed from the ignition, the piezo beeper stays on even if the interior lights are turned off at the switch. It does go off when the door is closed.
I do not have the diagram of the interior fuse box so I can't tell what relay goes to what.
Me wife and I lve in Holland, for a few months back we"ve bought a T&C from 96 LXI its a great car, butt now i"ve got a lillte problem with the head lights. Only the lillte lights are burning,(switch in the first pos.)
Switch in pos 2 does nothing, also the great lights is dead.
is there anybuddy who can help me out??
grtzzzz Peet
I went to start the van and it clicked a couple of times and all of a sudden the starter motor started turning the engine over and never stoped until the battery ran down. Now when you jump the battery the starter just starts again.
Can anyone help me here with an idea of how to fix this.
Since there is an electrical interlock with "Park" & "Neutral" on the shift lever I have shifted out of "P" or "N" and the starter shut down.
In your case try securing the emergency brakes and have someone step on the brakes and have the shift lever in a position other than "P" or "D" and momentarily jump the battery and see if the starter engages. If it does not then the problem is the ignition switch. As a final test place the shift lever back in "P" and momentarily jump the battery and see if the starter engages again.
*****With engine on set blower motor to high, set mode position knob to panel (i.e. full left), open all A/C outlets, set temperature to cold (both levers if so equipped). Now press the wash and rear wiper buttons on the A/C panel simultaneously for 5 seconds (until all LED's light). This should get the test started. Assorted lights on this panel will flash as different tests are run. Eventually if the tests are passed the rear wiper LED should be the only light flashing. Push the rear wiper button to exit test mode and you should be home free
