I have a 1999 Ford F-250 with a Power stroke Diesel, manual 6 speed, 4x4 manual hubs and only has 75,000 miles on it. I am having trouble with the clutch. The resivore is full of fluid. I don't have much clutch pedal (approx. 2-3" off floor when it engages) and when I am pulling anything I can't get it into low gear or reverse without turning the motor off first. Is there an adjustment on these clutches and if it is where is it located? If not what do I need to do? :sick:
My guess is it is an electical problem, but not sure were to look or what to look for, any ideas?
P1000 OBD11 System checks incomplete
P117 ECT Sensor Intermittents
P0125 Coolant Temp too low/closed loop
P1289 Cylinder head temp sensor high input
P0741 Torque CONU clutch sys stuck off
P0782-2-3 Shift ERROR
P1744 TCC System problem
The truck does not select gear in time and it does climb hills. could it be ECU problem or gear box problem?
It will not shift into low or reverse.
Any solutions?
A friend suggested that I change out the fuel filter before I spend $2,000.00 to $3,000.00 on a new transmission. Anyone have any suggestions?
I know we have talked about this before in here and this forum and others are usually a great source to help people that want to do their own work like myself but there are some things most people and myself just dont have the tools to see whats wrong but the worst thing one can do is to just start throwing parts at a Vehicle without knowing for sure it will fix it.
My 1997 ford F150 has a 5 speed and I can use 1st, 2nd and 5th gear but all of a sudden I cannot get to go into 3rd or 4th gear it is like they are not there.
Anyone ever heard of an issue like this. This happened driving along the hi-way. When I stopped I could not get into the 3rd or 4th gear. Never heard any noise B4 it happened.
Thanks for any help on htis.
at the bottom of the 2-4 servo ! But it has to be removed from under the
valve body ! Valve body has to be removed, if that's your problem !
And if it needs adjusted it says to put the vehicle in drive with some wieght holding the shifter in the drive position, then on the cable where it clips in the bracket on the transmission there's a clip that slides off, but not all the way, then you can move the end that clips on the lever inline with the lever. If it still has play and won't go in either park or 1st then there is probaly peices broke in the column. Good luck. or as I did have someone hold the shifter in the drive position and click the lever all the way towar the front of the vehicle, then three clicks toward the back and that is drive.
I just changed the master cyl.,slave cyl.,clutch pressure plate,and I have about half the clutch it takes to be able to engage the gears.I need help with bleeding.I have taken the trans.out 3 times,still no clutch.Let me know if that helped ya any.Jeff..
help????????
