good luck!!!!
. My truck is a 2009 double cab V-6 TRD off road. with only 6952 miles on it. I bought the truck brand new in Feb, 2009
GOOD LUCK!!
http://www.alldata.com/tsb/Toyota/1257235200000_1257840000000_SB0373-09/index.ht- ml
The work order quotes a different TSB.
"Condition : Complaint of erratic transmission shift. Seems to take awhile to shift into proper gear.
Cause: Comfirmed complaint. TSB 3111 applies, ECU requires re-flash.
Correction: Re-flashed ECU and re-checked. Okay now "
It is interesting that everyone I spoke to claimed they have never heard about the issue, but yet an update to the transmission came out? They knew about it.
These forums are important and I hope everyone continues to post issues they encounter with any company they deal with. Whether its auto related or other.
Now I just have to wait till Toyota figures out my radio issue. As it has shorted out since I bought it back in January. This is the vehicles 2nd radio to do this..
Thanks everyone!
Although the radios are supposedly on 'back order', make sure you get the issue logged under warranty.
Does anyone know if same TSB applies to 2010 or if there is already a new TSB avail for 2010 model?
Hopefully, he'll reply otherwise, I'll take your advice -- print the four pages and give them a visit.
Are these problems in a 2 Wheel drive or only in 4x4s?
I was getting ready to buy a 2010 Tacoma with the Off Road package and 4x4 when I read these posts. Now I will check out the Honda Ridgeline. I still would rather the Tacoma but don't want the headaches. Has anyone narrowed this down to which trucks or trucks coming out of certain states etc.? Thank you. Mel
For those who need to fill out the survey from the dealer, don't wait too long. I waited and now the survey is no longer available.
Has anyone ever tried to get their truck replaced?
Hopefully something positive will come out of this...I will keep you posted.
