I went back to my dealer and had a "discussion" about this issue with the front end. Apparently Mitsubishi has known about this problem for quite some time. Here in Japan, the new design model Outlander has been available since about Sept 2006. They told me that this problem is common in the new Outlander. But they're not exactly sure what is causing it. One theory is that the front hub bearings have been fitted with the wrong kind if grease. Thus causing the bearings to temporarily seize. The solution, thus far, is to repack the bearings with a stronger more durable grease. I will bring my vehicle back this week to have this done. I will report back on whether it has worked or not.
As a side note, I let my salesman know how upset I was that Mitsubishi was aware of this problem before they sold me this car. Not a good thing for a company to do. Especially one that is trying to create a clean image after the recall scandal that surfaced a little while back.
More to come...
L
I thought the new Outlander went on sale in Japan fall 2005.
Looked at all of the car based SUVs. Being tall, I fit best in the Mitsubishi. I use the Bluetooth all of the time. Great feature. My smartphone loses connectivity to the system from time to time. Refreshing the settings on the smartphone seems to fix this. Stereo "surround" settings are better than trying to use the manual controls to setup the speaker system; bal/fade/etc.
I miss the overhead lights coming on when I get in. Old minivan had this. I prefer the harder seats then were in the minivan. Fastkey is interesting. Although my family doesn't like it too much as it does not open all of the doors at once. I used the Sportronic shifters a couple of times. Not my cup of tea. My father remembers something similar on his 58 chevy.
I haven't been able to figure out how to get the MPG to work for the entire tank of gas. Each time I turn the car on, the MPG resets for that trip. I have played with this while travelling at different speeds. It has the real time indicator for MPG that is on CRV that some people talk about.
There is additional wind noise as some of the reviews mentioned. As I listen to loud music, it doesn't bother me. Riding over coarse road transmits additional noise into the cabin as well. Driving on asphalt, it is smooth as silk.
I find myself having to move the steering wheel from side to side to unlock the ignition switch, when first starting, more often then I would have thought? I also hear the popping sound from the front left when parallel parking or making hard turns. Posts indicate this is a bearing assembly issue that Mitsu is aware of. I have not taken it back to the dealer yet.
The pedals and my big size 15s, are touchier than the old auto. Time and familiarity will fix this. I put on 600 miles during the first week.
Did you get to set the overhead cabin lights over at the 2nd row seats? Works the same way as for most cars/SUVs
More info on this on pages 3-150 to 3-153 of the manual. You could try the Manual Reset mode and see if it gets you to do a lot longer monitoring of your average fuel consumption. Manual math on the Gas Mileage is available on the very last page of the manual.
Talking about Bluetooth handsfree, it's really cool and very useful technology. This one always get the "wow" from friends when I demo and call their number. They didn't even know where my phone was, and the SUV has the "AI" factor to it when it reconfirms the number. The speech recognition is quite accurate too.
It should be a standard feature on all trims. If you get the XLS with Luxury package, you will get HID headlights, and in this package, the fog lights serves as daytime running lights.
And about the fog lights, I have yet to confirm this, but the manual says you can manually turn on/off the fog lights independently from headlights. The default function of the foglights are to illuminate together with the headlights on low beam mode, and as DRL in the Luxury package. When high beam is selected for the headlights, the fog lights go off, until you set the headlights back to low beam again.
Regarding the front end knock, the service guy said that as the model was so new, he hadn't heard of any bulletins, but he would take a look for me. Having said that, the car hasn't done it since.
Wind noise... I thought it was coming off the roof rail, but the service dept took it for a drive and said it was coming from the mirror. There is a gap around an inch and half between the body work and the mirror housing and the wind is whistling through there. The service chap noted that the service manager's Outlander also did the same thing.
The overhead light.. There is one over the rear view mirror, one in the middle of the cabin and one at the rear. When I first got the car, none of them came on, so I played with the switches and was able to set them up so that they come on when a door is opened and stay on for around 30 seconds before going off. (the time out is controlled from the Nav screen)
Fastkey.. again this setup can be controlled from the NAV screen. You can have the key open just the drivers door, or all doors, or you can disable it completely for the door locks and/or engine start. I have noticed that it will only unlock the particular door you are standing next to, but once that door is opened, I have it set up to unlock all other doors.
Headlights auto off... yes, on my car, they are set up to switch off after 3 minutes or so, again set up from the Nav screen. As for the fogs, I have the HID lights, so the fogs act as daylight running lights. With the HID option, there are only 3 positions and not 4 on the light stalk on the steering wheel, so I haven't figured out a way to have the fogs switch off and bypass the DLR setting.
Finally the NAV... Whilst driving, I was able to hit the home button and have the NAV system give me directions back to my house, without having to stop and put the car in park. I haven't really played with the NAV/GPS system much yet, so dont know what functionality gets disabled (apart from the DVD and Aux video inputs) whilst the car is in motion. As for caller id, yes the NAV display will show the number of the calling party, so it supports that functionality. However, the limiting factor here may be the phone. I have a RAZR V3 on the T-Mobile network and they place no restrictions on the data that can be passed via bluetooth. However, there are phone companies that 'cripple' some of the bluetooth functionality on their phones and therefore the number transfer will not work from their phone to the NAV system. Only the voice information is passed.
POL
Now, what I did not get from your answer is wether or not the Outlander has auto headlights. What I mean by that is if you can set the headlights on "Auto" so they come on when it gets dark without you having to turn them on manually. I understand that it has the headlights auto off functionality- they automatically turn of when, lets say, you turn off the engine.
I guess you can have it on DRL mode on the LS/ES with fog lights if it's standard. I just confirmed that on the XLS with Luxury package, we don't get the foglight switch. Foglights are run by the system.
Nope, you still have to turn them on manually.
Would have been nice... But again, hope the Canadian model will have it (?!). Same happened with my car; different features in CAN compared to US. I also wish for heated mirrors... They would be handy during the winter time.
Thanks again rcpax.
Okay, let me be the first to give my 2 cents worth on your query. The navi unit is very useful for me. I really like the big screen because it can display a lot of details (street names, POI). And I get to see well in advance if I need to make a turn on an intersection. That's the other half of the screen where I see the vehicle's position along a road. The other half gives me the next turn I'll make, and how far ahead. So this gives me a chance to move lanes when I'm like 0.5 to 1 mile before an exit or a turn. this is the visual part, and there is also the navi audio instructions so I can keep my eye on the road. For me, when traveling through unfamiliar routes, this is very important, because missing an exit could mean another 20-30 miles drive to the next exit. the big navi screen is important to me, and the navi system as a whole is indispensable. I'm glad I made the right decision. I am new to our current residence, and I rely much on the navi to find my way around. Regarding your Garmin unit, it would be pretty much up to you to decide, and I bet it's a little tough because the built-in navi costs a lot. I'd say if your happy with your current GPS, you can skip the navi. You can make changes to the navi while the vehicle is in motion, but it's not advisable for safety reasons. Among other things, it serves as the "monitor" for your car. You can set a lot of things on the car using the navi display. It actually is the console for the whole vehicle, and doubles as Navi, and DVD movie player too. You also get an RCA audio/video in if it was in a Luxury package, so you can hook your PS3, etc, and with the addition of a cheap camera you can actually make a DIY backup camera system if your crafty enough. It does display the calling number on the screen, but what I can't confirm as of this time is whether it will display the ID from your phone's phonebook. The navi unit does not use your phone's phonebook. You will actually need to build a new phonebook in the vehicle's system, and all names are voice recorded by you, so the car's computer will be able to do a voice recognition of the person's name you want to call, and all commands are given via voice.
Yep, but without removing the good ones already there. Usually we get less content for more money.
I can't wait until next Jan-Feb to see the Canadian prices and trims for the 07 Outlander.
I would like to have them all for less money. How is that?
Front end bearings were fine. The housing however had some microscopic roughness that was causing them to bind. Thus building tension and finally releasing with a thud. They replaced my bearings (at the manufacturing plant not the dealership) and fitted them with the refined housing. It's been three days and the sound has not come back. I suggest speaking to your dealer if you have this same problem.
For my troubles, the dealer scored me some Jaos fog lamps to go with my already attatched front skid bar. The idea of course came from me.
S
It was a good thing I canceled my appointment. The service guy would have found nothing wrong if he dismantled the steering mechanism and the CV joint. I doubt he would noticed that microscopic roughness. Now I wonder how they would deal with US customers because we don't have a manufacturing plant here. Nearest is in Normal, IL which is some 150mi away.
Did you happen to ask if they didn't change the housing, if it will cause damage? Right now I'm thinking this is something that will wear out over time as you use the vehicle. It will be annoying having the "knock", but I hope it's nothing serious. I would rather have it wore down over time than have the service guy dismantle a new car, and tell me he can't find anything wrong with it.
At this point I hope we can have your particulars since your case is the first documented case. Maybe the name of the your dealership, your Vehicle Identification number, what particular manufacturing plant serviced your vehicle (was it in Mizushima?) and what parts are affected and replaced. Then perhaps I can write a snail mail to Mitsu North America regarding this problem and I can cite your case in the letter so they know that this case is not isolated. If you don't want to reveal these info in this public forum, you can find my email in my profile. I really would like to have this issue brought to the attention of MMNA. Thanks in advance.
Wow, your dealers there in Japan are generous. I have been searching for a while now for a Ralli-Art store there that will be willing to ship the merchandise to the US. But so far, most of them doesn't have an online ordering system, or if they do, it's for domestic market only. I wonder if we can buy a Mt. Fuji grille from the factory, just like the ones for the Australian and Euro market (pic below). I like it more.
Heck, I'm still wondering why we can't get the backup camera system like they have in Japan. :confuse:
Considering that Mitsubishi has treated me well from the beginning concerning this problem, I am not willing to give out any specific details as to dealer names and so on. However, if I find that Mitsubishi is shirking in their responsibilty to take care of this issue, I will be more than willing to give out more information in regards to my specific case.
As I said before, if you have this problem, bring it to the attention of your dealer. So far I am giving Mitsu the benefit of the doubt and a chance to do the right thing.
L
So far its been the lone disappointment I have had with my 07 Outlander. (Ok the doors not locking when I shift out of park bugs me as well and why the heck can't the CD drive burn files from an MP3 disk? Also does anyone else find that they accidentally turn on their hazard lights alot while messing with the radio?) Even with those minor problems I still love the suv.
I live in TX though and don't think there is a factory anywhere near to fix the knocking problem. Can't they ship the parts to the dealer though? Seems strange if they can't.
Two other minor points that, while minor, do annoy me:
1. No auto-dimming rearview mirror.
2. No heated side view mirrors (in NY this is quite helpful).
It's just surprising that they'd put so much technology into the vehicle and leave out some relatively minor items that seem to have become fairly standard offerings - especially in the upper end of any model.
This bugs me too! I haven't used music CDs for years. Every CD I have, has already been stored digitally on a lan server, iPod, or MP3 disks. Now if I want to copy a CD to the Music server, I have to dig out the original music disk from wherever I stashed it all those years ago! At first, I dug out a few 'must have' CDs and spent an afternoon running up and down stairs every 15 minutes to change the CD in the car. I then had an issue with the Nav system that the dealer thought would end up in a complete replacement of the head unit, hard drive and all!!! I don't want to spend hours and hours ripping CDs to the Music server, only to have to do it all over again. Luckily, the dealer was able to fix the Nav issue, so I still have the original unit.
Another quirk/issue, is that the radio on the Nav system does NOT display RDS info, yet the vanilla radio that comes with the 6 disk changer does display RDS info. What's up with that? I guess they figure that as the upgraded unit comes with Sat radio, you can pony up for a subscription in order to see station, artist and track info.
Apart from the above and a few other small issues, like no Homelink, no auto dimming mirror and no memory seats, I'm still more than satisfied with the new car. At least on random all play, hitting 'next' on the unit gives the next random track and not simply the next track on the disk. That really bugs me on my wife's G35 Coupe, especially when it lands on one of her disks in the car!!!!
Sun & Sound
Navigation
Luxury
