i'm going later tomorrow to autozone to see if i can get it
There could be a bad or dirty fuel injector.
Could have a weak ignition coil.
Dusty
I have a '98 dodge ram 1500 that does something VERY simmilar to what you are describing. I was traveling about 55+/- mph going up a slight incline. The check engine light came on, and the truck started to tremble almost as if i were driving over railroad tracks. It only stays that way for a moment then returns to normal. For me the $3.00 fix was when I filled the tank from almost empty was to put 2 bottles of fuel injector cleaner in the tank, and keep the tank full PLEASE post a response to let me know if this works for you too...
i am looking at purchasing a 1996 ram 3500 with 106k miles. what kind of fuel mileage could i expect with a continuous payload of 1k, and how many miles would i expect before major engine or transmission problems, provided it has had good servicing, 2-wheel dr.
thanks booger
Any sugestions?
Joe
Thanks RyanT
The truck is brand new 8v 4.7 2008 and recently after being on the road for about 1 hour at about 70 mph the truck started to make loud noises (seemed like something broke) at this point it would not accelerate at all, then white smoke started to come out of the exhaust, it seemed like it would just die right there. The condition persisted for about another hour.
When i took it to the dealership they couldnt find anything wrong.
About one week later i did the same trip again and the same thing happened at about the same location, just that this time the noise was louder and more smoke came out.
This time when i took it to the dealership they said something was wrong but they refused to give explanations, im now going for the third week driving a rented grand caravan because the truck still isnt ready.
Anybody had this issue?
Is the Hemi model showing issues as well?
Dodge 1500 v8 Mag reg cab 4x4) warms up. Also I have noticed that when on highway I can watch the tack rise as much as 500rpm or drop 3-400rpm for no reason while driving and I can feel what I thing is the trannie making a noise when rpm rises.. I am no mechanic.. I am a disabled vet and I have been wanting a good 4x4 for years. Hoping this is it.
Any ideas??
Corkscrew
1 Inner rotor thickness= .5876 to .5886
2 Outer rotor thickness= .5876 min.
3 Outer rotor dia.= 3.246 min
4 Clearance between rotor tips= .023 max
5 Place a straightedge across inner surface of cover & rotors. If .003 feeler gage fits, replace cover.
6 Clearance between cover and outer rotor= .006 max
