How to replace power window regulator on a Buick Rendezvous?
Both front windows on my wife's SUV failed within the same week. The windows go down but do not go back up. I can here the motor working but the windows don't move. The dealer said it is the regulator on the power window motor and wanted to charge me $800 to repair both of them. We are out of warranty by 8000 mis. I would like to try and replace them by myself. Is it difficult to remove the door panels to get access to the window motor? Thx
Did you buy replacement parts? If so do you know the part numbers and what was included?
I am currently working on the passenger window of my 2003.
The trick is to pop the red lense off to get to the second screw.
Once both screws are removed then get a wide flat pry bar or large screw driver (wrap some making tape around it so as not to scratch the door) and work your way around the the panel prying it off.
Start from the lower outermost corner and work you way up towards the window then across the bottom of the door and up the other side.
Don't worry - it will snap back in.
In order to disconnect the cables for the window and speakers you need to use a screw driver to press in a latching tab on the connector BEFORE you try to pull it apart.
Good luck!
Pins are crimped onto the wire ends. These pins are inserted into the connector that the switch plugs into.
By wiggling the wires are you might have gotten them to make contact with the pins.
I am not sure if you can get that switch from an auto parts store. To remove the switch from the wires you will have to pry up on a little tab while pulling the switch from the connector. This little tab is used to latch the wire connector to the switch. Once you have the switch in hand try your local auto parts store 1st then a GM dealer.
As for the AC. Try to look for oily dirt around AC system fitting in the engine compartment. The Freon has oil in it. When the Freon leaks so does some of the oil. The oil will attract dirt and dust. Fixing it yourself is a long shot but maybe you can at least pinpoint the problem. Hopefully it's not the evaporator (inside the car) or the condenser (in front of the radiator).
Try these part numbers - not sure which is left or right. If one is cracked the other might be as well.
Clip - 15286776
Clip - 15286777
(Regulator - 10376803)
Good luck!
My regulator broke yesterday. as far as left and right i went to the dealership today and they show those two clips go on one window. and they work on either driver or passenger side. i havent taken the regulator out to verify but he said the computer says both are required. i need the 15256777 one. they charge 27 but ive seen them online for 15. thanks for the number they couldnt find one
Could you post site please.
I just had the same happen to me.
SUVs and Smart Shopper
I remember the passenger door was tough (double jointed fingers, wrists and elbows would have helped).
I might have run the window all the way up or down and noted where on the cable the clip went. The I might have set the widow in a mid-way position to get everything together.
I am very sorry - I'd have to do it again to answer your question.
The lie to you so you have to buy the regulator. Just give them the part #s.
BTW: they are real easy to replace.
Congratulations!!!
Now if you ever need help changing the wheel bearing in teh front (they wear very quickly and make a loud roaring noise as you pick up speed) let me know, that is a little harder, but also much more simple.
TG
Most dealers will not stock them, and have to order them. They will run about $53 for the pair. Don't let them tell you otherwise. As I have advised before, take soem time to study the clip once you go to install. there s a litle cube shaped chamber and a matching stop on the cable that goes in there. That is the key, make sure the cable side is sitting in that litle cube chamber before you clip the clip on the regulator
Please help.
I am going to order the 15286776 & 15286777 for my fiancee's 2003 Rendezvous. I hope this does the trick. They wanted to charge us $500. I may have to do it also on the driver's side passenger window too.
Thanks again.
Now for your questions:
I went to a technical school and have a diploma in automotive technology, so I feel very comfortable doing a lot of things. I also hate dealer service, because they overcharge more then they should (I was once also a service writer). That being said.
If I was you, I would replace the window clips yourself. There has been a lot written here and it is relatively straight forward if you take the time. Now on the wheel bearing, 5 months after mine started to whine, I received the letter stating according to GM that there might be an issue with premature wear. Considering my wife's Rende had over 70K miles on it, it seemed appropriate for the wear (still not a normal occurance) I essentially let it growl for over 10 months till it got real bad (dont recommend it, as all kinds of warning lights go off). The part cost me about approx $150-$180, it was an aftermarket part from an auto parts store. The unit comes with the ABS sensor ring.
Once you jack and properly support truck on a flat surface, remove affected wheel. remove brake caliper, and mounting bracket, remove rotor. You will have to get a 24mm socket(? not quite sure of size, as I am not home so cant see what socket size is) and remove hub to axle bolt. I had use of an electric impact gun which made it easy, Otherwise a large breaker bar and a pipe over it (for leverage) should do it. Now look behind the hub, take something and mark the hub (yellow tire pencil or some white out, just mark so you can realign gasket and strut assembly), the metal gasket position (Gasket goes in one way, and if you put back incorrectly it will grind against rotor)
Now turn your attention to behind the assembly there are 3 bolts, one is really easy to remove, one is somewhat easy (can be a little tight) and one is a royal pain (but not hard) I recommend you go to Sears and invest in good sockets because if they are worn it can make this task a little hard) the bolt in question is at a 12:00 o'clock position, but it is tight against the bottom of strut and axle. You have to put a small extension on it. If it does not turn with reasonable force, you may have to have somebody hold a small propane torch (the plumbing kind) and heat the area from the outside (facing out side) for about 7-10 minutes and then try removing it again (it should come out easy, my bolt was frozen) disconnect the ABS sensor ring (and I believe there is a bracket you have to unscrew as well holding the sensor ring pig tail). The hub is unbolted, now the fun stuff. Take a hammer and tap (a little hard) around the outside of hub assemble ( it is triangular in shape) till you see it starting to separate. Do not try and pry, you do not want to nick the machined surfaces. Keep hammering. Better yet is to use a slide hammer to remove it.
Once hub is removed inspect where hub goes into strut/spindle, clean it out. Take new assembly feed the sensor ring pig tail through, make sure gasket is aligned properly with marks you made earlier and insert hub in. It should go in tight. and just use a hammer and a block of wood to tap it back in. Get very flush and all aligned. Now bolt in the back. After that is done, bolt the axle bolt back in. Make sure to plug the sensor ring connector in and make sure everything is re attached. Put the rotor back on, and then, the mounting brackets and the brake caliper. Put the wheel back on and tighten lug nuts, lower truck back on to ground, start truck AND PUMP BRAKES ABOUT 6 to 10 TIMES TO MAKE SURE THE BRAKES ARE SEATED PROPERLY. BRAKE PEDAL SHOULD APPEAR FIRM.
Take for test drive, whining noise should be gone, test brakes to makes sure they are ok. After test drive recheck wheel lug nuts to make sure they are tight.
I hope this page helps anyone in the future as i had no clue how the clips even attached to the regulator before i took it out and studied it.
Here ya go....
Buick Rendezvous Window Regulator Installation Page
I added the part numbers and links at the bottom of the page.
Have Fun!
I think in the future I may do that, so I can help some one else.
KUDOS !!
heck, i registered just to thank you guys. i also have a jeep wrangler, but i have part #s, and repair books - but for buicks, i cant find them.
anyone have a copy of a buick rendezvous parts cd?
Great information for the front windows.
I have a rear window on a 2003 Buick Rendevous that is not working. I am trying to take the panels off the drivers side door, but they do not remove as easily as the front panels. Is there an easy way to get the panels off without tearing the panels up in the process?
I have all the bolts removed that I can find and it looks like the clips holding the panels are teh issue. Started using a screwdriver, but wanted to ask for advice before, I potentially damaged something in the process!
Thaanks in advance!
Sorry not much, but I hope it helps.
I have a 2002 Rendezvous. The window clips broke on my driver's side door. Of course, I did not know that was the issue, until I took the door apart. Being the girl that I am, I still did not know what was wrong. So, I took the door panel off the front passenger door. Then, I saw that all the plastic parts were supposed to be only 2 plastic parts. I pieced the broken parts together and my husband took them to several auto parts stores, looking for new ones.--- no luck
Then, he sent me to the dealership and they told me that I needed a new regulator ($175 plus labor). They even showed me a new one. The clips on the new one were not plastic!!! In fact, they did not look like they could be removed from the regulator. So a new regulator comes with better clips.
So I went home, duct taped my window in the "Up" position--- yes, I said duct tape--- then but the door back together to hide all the tape.
3 months later---yes the tape held for 3 months--- the window slips down about 4-5" while driving.
Now, thanks to this forum, I am going to surprise my husband by fixing the window!!!
I took off the panel and am looking at the broken plastic clip. So why can't I just replace them?
