As far as temp goes, it depends on the inside temp in the vehicle. Hot air will only come out if the set temp is above the temp in the vehicle. The exception is all the way to the hot forces max heating regardless of the inside temperature, All the way to the cool forces max cooling. If yours does not work as described, bring it back for service.
As for the heating, your description is pretty accurate. I guess I'll have to deal with it. Thanks.
In my mind, that is how an automatic climate control should work. It is trying to get the vehicle to a certain temperature. This is so you can set it and not have to adjust it much. The gradual change from cold to hot is for a manual climate control (or an automatic control around the inside vehicle temperature).
Steve
The only way for you to really be sure is to bring the two car seats and try them in the truck you're looking at. It may look kind of silly carrying the car seats into the showroom, but that's the only way to tell. We did and it's really work out well.
2001 model 15,000 miles
I have found that holding the flipper in the flash to pass position illuminates both the low and high beams together....sort of a pain to hold it while driving but works great for driving in areas where you want much more light but may have on coming traffic intermittently.(curvy, winding roads at night.)
Thanks to jammon1 for the lead on the rear climate control. I noticed it seems to run a bit chilly and takes a long time to come up in temp...I'm going to have the service dept check all the sensors and calibration before I drop off warranty.(2001 Denali with 28k so far troubke free miles)
Actually, I think that this is done behind the scenes when most dealer's prep the Denali's. I have seen on multiple "fresh off the truck" delivered Denali's that the running boards are enclosed in a box (located in the back of the vehicle) and then the dealership installs them when they inspect/pre-prep the vehicles. The same applies to the Chevy Avalanche too! They are shipped with running boards (if selected as an option) that have to be installed by the dealership once the vehicle hits the ground.
I don't know exactly why they do this (probably for ease of loading on the delivery trucks) but I guess it's more of a protection measure if anything. If you don't believe me, i would suggest that you contact your local GMC or Chevy dealer and inquire, but I have seen these vehicles shipped this way and without the running boards both in Ohio and Michigan.
IExplore2000@aol.com
Unfortunately, they attributed the rear wiper "jump" when turning on the fog lights to the battery problem -- I guess I'll have to print out the TSB from the message above and bring it in with me next time.
However, GM just can't get the quality control right. I have had many "little" problems with the fit and finish,as i would bet most of you have, plus, as i reported in an earlier post, the leaky battery.
GM should include more useful gadgets on a vehicle in this price range. I would like to see a door ajar indicator and backup sensors. Maybe these items are on the 2003"s?
GM has a LONG way to go before i would give them high marks for Quality.
Would i buy another Denali? Absolutely...Maybe this attitude is why GM doesn't try harder..
Larry
http://www.performanceproducts.com
http://www.stylinconcepts.com
Steve
Just be careful and make sure u don't remove the paint along with the emblem..
I agree with you on the JUNK Delco battery, but what led you to buy the Optima over the Sears Diehard? I had a 99 Tahoe with the same problem. The battery failed right after the warranty ran out.
I wonder if GM will ever get it right?? My guess is NO
Steve
I absolutely cannot understand why, when GM has battery problems for what appears to be years, they can't get it fixed??? It's really frustrating. I would suggest New Suppliers in certain areas. But of course, who are we?
I am not sure who produces the Die Hard for Sears - my guess is who ever meets the spec and has the lowest price. The same is true for tires -and many other products.
I also just read that GM and Ford are planning to develop a new 5 speed automatic tranny. Who woulld have every thought GM and Ford working together to save each other $. The article claimed it would save over $300,000,000.
This is not new for GM - they partner with many other companies - they already for example provide a tranny to BMW that is used in the 5 series.
Has anyone else done same and noticed any change in the ride?
