So I picked up my car last night (as mentioned above). Everything was great, car started great even though it was -2 below out. Car started great this morning even though it was -9 below this morning. Less than a mile down the road on my way to work the check engine light came on. It's going back to the dealer a third time tomorrow. AGAIN, I will keep you posted. :mad:
So my car went back to the dealer last Friday morning. They called me that afternoon and said the cam tensioner gasket/seal needed to be replaced and that they would order the part but because they had to pull the header off it wouldn't be ready before Tuesday the 29th. I got a call today that they pulled the header ready to change the gasket and saw their was more than normal condensation in or on the pcv valve and that it needed to be replaced as it was not working and was a manufacturer defect. AGAIN, they would order the part and call me when the car was ready. Can you say :lemon: ?
In hopes this helps others who have had this sort of problem: My 2010 Jetta TDI manual has been hesitating since I purchased it new. It was rare at first and never missed when the VW mechanic drove it. As the 3 year warranty ran out the hesitation had become frequent. After leaving it with VW for a week, a "code" occasionally advised replacing #3 fuel injector for code P020C. Haven't had any hesitation in 150 miles driven since it was replaced. VW didn't charge me for this as it was covered under the 5 yr engine and drive train warranty. I am very pleased with VW and my car. :shades:
I have a 2002 Jetta 11 years old now. No major issues other than your wear and tear.
So today I am at the gas station filling up. I start the car and it stalls on me. The EPC light, battery light, and I think engine light all turned on.
Called AAA, they didn't know what was wrong with it so they called in their tow service. Car sat there for over an hour while waiting for the tow truck to come. tower comes tries to start the car and same thing. But then while he's loading it on the truck, he reaches down in front of the car, bangs something w/ his tool, starts the car and it works now, it actually starts and I drove it home which was only 1-2 miles away. He tells me bad fuel pump.
Now car is here at home but I am afraid it may not start to get it to the shop tomorrow.
But based on what i wrote, do you experts think it is only fuel pump problem? it was weird that right after I filled up the car this occurred, never occurred before too. and the whole EPC / BATTERY LIGHT coming on I thought the engine had had it.
I have a 99 VW Jetta Wolfsburg Edition. Ever since I have had it it's always had issues starting, but nothing more than that. After 6 months of having it it shut off randomly and did not want to start so we replaced the starter, it still had troubles starting up but was fine. Now this past two months it has started shutting off on me while driving, NUMEROUS times now. It doesn't seem to have a pattern, just at random, a few times it felt like a skipping sensation before it died, but not every time. We have had the battery replaced, spark plugs, fuel pump replaced, replaced distributor, temp sensor, and now recently the crank sensor. Hoping the crank sensor would do the trick, but it once again shut off on me while driving. Every time it shuts off the lights on the dash all come up then go away once I turn the key off. It takes a few minutes to maybe an hour or so to get it to start back up. Other than now looking to see if it's throttle body, does anyone have input on what could be going on?
It could be two things: 1. throttle body is bad 2. engine management system is bad (it is the computer in your car that runs all of the different fuel injection components)
Best bet is to get a mechanic to drive the car with a scanner connected to it to see what codes pop up.
Thanks for the reply. I had the mechanic do that exactly, all the codes were reading perfectly fine. We drove it around for a little bit before he finally got it to die down on him. When it did, he looked at the scanner and it said it could not connect. He suggested throttle body and or possibly the computer. Hopefully its one of the two.
I am having the same issue. I am certain it is the fuel filter, because the engine light is not on and if I use gas additives it kinda helps. Let me know what you did to your car to get it fixed!
Mine never got fixed! I gave up and traded the 2010 in and the 2012 does it too! I am totally disappointed in VW. Story now is it is a "software issue" and that the NTSB has to bless the update before I can get the car to quit stalling in intersections... been about a year not, waiting... not happy!
Well the problem had progressively gotten worse, it had gotten to where just sitting in park for about 10-15min it would die. So we went ahead and changed out the computer. So far it runs without dying on me, but now I have to change either the alternator or volt. regulator.
COOLANT LEAK MIGRATION MAY BE CAUSING TONS OS ELECTRICAL/misc. ISSUES!!-I have been scouring the Internet looking for answers to my recently purchased used 2001 vw new beetle which intermittently stalls while driving... On the freeway or surface streets, it doesn't matter but it is very intermittent. After looking through the glovebox into all the repairs done in the paperwork, it looks like it has been an issue from the beginning of this car! Unfortunately we bought it "as is" from a private seller so there's nothing we can do about it. Anyways, we have taken it to a few different highly recommended mechanics specializing in foreign cars and even specifically VWs all to no avail. They even were able to reproduce the issue which scared them half to death when it stalled on them on the freeway. They too, reviewed all the previous repairs done changing everything from the throttle body to the mass air flow sensor and much more multiple times! They were unable to find any definitive answer and did not charge a penny due to being unable to diagnose and suggested taking to a vw dealer to hook up to their computer. Today after scouring the Internet for possible answers I came across one thing that finally sounds like a possible answer.... A coolant leak migration that can migrate as far as back to the tail lights! It supposedly is due to the reservoir design up to a certain year where the connector is tilted down in an angle that somehow can allow a leak to migrate all thought anywhere on the whole wiring harness and affect a plethora of things throughout the vehicle causing you to need to repeatedly replace parts over and over thinking it is defective parts when the actual cause is actually the coolant leak migrating throughout the whole car! We just found this possible idea today and I wanted to share to help others be aware of this possibility when you seem to feel there is no answer! I will update after my husband takes a look at all and we check where there may be any corrosion from coolant migrating to what areas and affecting electronics and other things, Heidi
Not sure if this will help at all but I have a 2012 Jetta that randomly shuts off when driving. I've had it in the shop numerous times and they couldn't figure out what was going on.
Fingers crossed, I will be picking my car up again today and they think they may have found the problem. A software update was needed. The dealership contacted VW who told them they have been having a few issues with this and said after they run the software update the problem seems to be fixed.
I love my Jetta, my experience with the dealership and VW has been the best I have received anywhere. I hope this fixes the issue and maybe can help you too!
The Stalling Issue occured again last week. I have it on video because the dealership never believed me. When I called the dealership they wanted $120 to put it on the computer again.. since this never produced anything last year... I did want any sensible person would do... I now drive a Honda and am so happy that I don't ever have to worry about stalling issues again Good Luck, my heart goes out to everyone that has this issue!!!
Ok this is my first post so sorry if someone has already asked/answered this question but i have a 1999 jetta manuel transmission that will run fine for a short time then it will start sputtering and trying to die to the point that i have to pull over and kill the engine. After doing this it no longer wants to start and i have to sit and wait. At first it would start after just a few minutes now it takes any where from 30 minuts to an hour before it will start again. I have been told it is the fuel pump so. purchased a new one yesterday but before i put it in (cause it was $350) i would like to know if it might be something else. Please help a girl out. Thanks in advance. Oh i have also already takin it to have codes read to try and fimd out what it could be and it wouldnt communicate with the machine
I had an issue where my key would not go in my 2005 Jetta ignition. I literally looked around the stuff in my car to check that I was in the right car. A locksmith came out to try to fix it, but they weren't able to. Ultimately, I had to get my car towed. The dealership quoted me around $700 to replace the ignition lock. I have no idea what was going on with my car? Was it something I did to somehow break it?
I have a 2003 Jetta VR6: and my friend a 2002 Jetta, both cars stall if fuel level is at or under ¼ tank. After many Web search results I see many stories like mine, car stalls on Highway, traveling at speeds from 50 to 75. Sometimes I can feather the accelerator and will save from stalling but if not I have to pull over put the car in park and it will restart.
This has been trouble on both cars for over 2 years, we never let the fuel get below ¼ tank. The tanks get flushed and filter replaced every two years but same problem. VW had done many tests but can’t figure it out. Someone said the fuel pump could over heat and shut off, that the gasoline keeps it cool, it makes sense when the gas is below ¼ tank that the pump is more above the fuel than under. If the manufacture had the pump designed with a low heat tolerance than maybe all the OEM replacement pumps and aftermarket pumps would react the same causing same failure and confusion after replacing one.
In conclusion, I believe there are multiple diagnoses posted that are correct. More than one specific failure could cause the same symptom. I’m told by VW a faulty crank shaft sensor would typically cause a computer error code, they are either working or not unless it has poor connection. The tank is clean so I am going to try replacing the fuel pump with a more superior one pump like BOSH and not an OEM part.
I’m curious as to the person that posted they used the BOSH pump and seems to have worked if this stall had resurfaced or not.
Lets be clear, this car is over 10 years old and not worth a whole lot. It makes no sense to pour money into this 'problem' you describe.
Personally, I would not waste much time nor money on this 'issue'. Since you have already diagnosed the problem as happening ONLY when the fuel-tank is less than quarter full.
Hence, you have already figured out how to resolve the 'issue'. JUST KEEP THE FUEL ABOVE QUARTER FULL..
I have a 2011 Jetta S that is having starting issues. Been at dealer 4 times. They can't repeat or get error codes. My lease is up today. I opened a ticket at customer care. Any advice? I took a video on my phone to have proof.
Hello there! I have a 2011 2.0L GAS AUTOMATIC jetta, I am the second owner and have had this car for 1 full year in the last month I have taken it too three different mechanic shops and just recently found a guy actually willing to try too figure out what the heck is going on with my car but we are stumped, I had a Vw tech run a reader on my car but no codes came up, but there is clearly a problem. Oneday as I was leaving the store my car would crank but would not fully start, I waited 5 mins tried again and fired up like there was nothing wrong with it, two weeks down the road same thing happens again and since then its happened almost everyday too me. Last week I was stopped at a red light and the car completely died on me. Put the reader in and still no codes showed up. I have had the crank sensor amd fuel pump tested and both came back good? I'm so stumped on what could be causing thi . You can smell the fuel under the hood so I don't think its fuel related at all
Also with late Model VW I have noticed this issue relates to the speed sensor. This seems to be happening alot, People having random stalling issues, replacing something and it works for a couple days to a couple weeks and then having the same issue. With both my jetta's I have replaced the speed sensor due to random stalling and starting issue and not had a issue since.
The Technical Service Bulliten is dated April 2001 which proves how long it has been understood.
However, a vehicle suffering from the symptoms of the "Coolant Migration Problem" may have too much damage to be financially feasible to correct.
In other words, it is FARRR easier to be proactive and often check for "Coolant Migration Problem" than it is to FIX the damage it causes.
1. Removed the steering power sensor plug from the sensor.
2. Changed the fuel pump (it was cracked, and hardly notice!).
Since then i have no issue. Hope this solve your issue too.
End of problem, worries and no money spent.
Did you get a new car? It's not you.
https://www.google.com/search?q=vw+stalling+while+driving&oq=vw+stalling+&aqs=chrome.2.69i57j0l5.7575j0j1&sourceid=chrome&espv=210&es_sm=93&ie=UTF-8
