thanks jack925
whats up with this thing?
bob
good luck
they will crack or swell when warm and lock into place
which can either lock you into over drive or lock you out of over drive an old 727 servo will fit and they are aluminum
The dealership scoped it but could not find anything wrong. I don't have a lot of confidence that issues will not reoccur. Has anyone encountered something like this?
Solenoid-transmission gov
Transduce-pressure sensor
The tranny has been behaving so far (knock on wood) and we have done some decent pulling.
About a week ago my trany started to what i'm guessing now is slipping. It will head out fine but then when I get up to approximately 30 mph the rpm shoot up to 4+ and it either takes a while to shift into second or won't shift at all unless i down grade and shift it from second back into drive. I have pulled the pan changed the filter and the fluid. I have also replaced all the sensors on the outside of the transmission including the one on the rear differential. Am at a loss as to what to do next. If there are any sensors inside of the trany I have yet to change those but can if that will fix the problem. At this point I need some help on decifering if there is anymore I could possibly look at doing to fix the problem without having to look at rebuilding or replacing. Any feedback would be greatly appreciated.
