Plz let me know if anyone knows the cure.
J
We changed the filter and its still shifting hard. It seems to be the 2nd shift that shifts hard. What else could be causing this ? Any suggestions ?
shift so smooth
Thanks again
Phil
Phil
About 2 weeks ago replaced both batteries all was fine. Then a day or 2 later I cleaned up around the posts with degreaser and coated terminals with anti-corrison treatment. The next morning after I did the clean up and treating the transmission wont shift correctly into 2nd. If I slowly accelerate all is good. If I accel to fast it wont shift until I back off the throttle and RPMs drop. Then it shifts. It goes up the gears just fine and stays in OD.
Ideas before I take to Dodge dealer?
Thx
HELP PLEASE going on a long drive next week want to try and correct the problem. also my speedometer isnt reading the right speed any connection?
thanx
any question?
1 - someone had put a slightly shallower pan on the transmission and when we changed from the 1997 tranny filter to a mid 70s (fit the same but thinner) that MAJORLY helped my shifting issues. The other basic issue with many vehicles is the connections. My mechanic sprayed PB blaster in the back of the connections at the harnesses and then dielectric gelled the connections themselves. It helped settle the computer down. Good luck
