I would suggest taking your vehicle in to your dealer of choice. Please keep me updated on your progress.
Christina
GM Customer Service
I would encourage you to have the vehicle diagnosed by your local dealership. Please keep us posted when the issue has been taken care of.
Thank you,
Caron, GM Customer Service
Glad to hear the air is now working! If you have any questions or concerns please feel free to contact us directly.
Thank you,
Thanks so much for any help that you can provide. I do not want to have to spend hundreds of dollars that I do not have to find out that it might be something simple and inexpensive.
Were you planning on having this issue looked at? Please keep me posted when the issue has been taken care of.
Thank you,
Were you planning on taking the vehicle in to be looked at? Please keep us posted when the issue has been taken care of.
Thank you,
'05 Tahoe with digital climate controls and dual AC. The front AC does not blow anything at all when stopped, when you start moving it starts blowing after about 20 mph. It will only blow at 1 speed regardless of what you select even if it is on automatic. Rear AC works fine. Anyone have any ideas?
I found 3 other postings with the same exact problem make, model and problem description
no resolution to it. help would be great full :sick:
I apologize for your concerns. Have you spoke with your dealer? If you would like to send me your VIN I will look into recall information for you. I look forward to your response. Have a great weekend!
Christina
GM Customer Service
If you want to provide personal information to gmcustsvc, then click on their name and send them an e-mail!
Think twice about buying GM again.
I won't hesitate in buying a honda or toyota.
Good luck .
I have had the ac checked and of course the mechanics cannot replicate the problem in the shop. It has been suggested that it needs a whole new control unit? But, now I am thinking that it is somehow tied to an outside thermometer maybe? It is just so hot!!!!!
Any help is welcome. Thanks.
http://www.gm-trucks.com/forums/lofiversion/index.php/t80775.html
Grover103
~A/C fan blows in the rear once Tahoe is turned off. Found out that its what was draining the battery.. this after purchasing a new battery.
~Front A/C blows on defrost and feet only. This has been happening for a month now, but once it did blow from the front.. once!
~Rear A/C use to blow cold, but now its hot!
Mechanic says I have a module that needs to be replaced, $298.00 and entire A/C needs replacing $600.00 . Please tell me this is not right.. :sick:
Note: A month ago I had another issue fixed where the water was draining on my floor board and it wasn't the drain hose clogged, after two cleanings took it back again and there was a penny blocking the hose to drain outside.
Any feedback would be greatly appreciated!
Any suggestions would help?
