Chrysler 300M Starting/Stalling problems
                    Hello there, I own a 99 300M with 207,000 kms on it. A 2.7 model for Belgium. My problem is on starting. For a few days no problems. Then when I turn the key some of the warning lights will come on some not,they flash all over the place, but just a click no fire up.The over head interior lights glow but very dimly. The battery is just fine so thats not the problem , but what is the problem ??
Any help for mthe other side of the pond would be appreciated. Basically I think the 300M is one of the better big cars I have owned in terms of looks space etc. However reliability does not seem to be its strong point. Kind regards Kevin
I will probably leave the car for a few hours maybe a day and it will start. Then it might work for a week without problem maybe less.
Does any one have an idea how to solve this problem? Did I make a mistake by removing all the fuses one by one? If I mixed up the computer, is there a way to rest the computer of the car? As far as I know all the other electrical equipment is working.
Anyone have any ideas or in formation?
I have not cleaned my TB yet, but I feel it is not real likely to be a problem since this issue started so abruptly.
Does this sound like a crank or cam sensor or anything?
Tina
Thank you,
1. Never stalls around town, only after driving awhile at highway speeds, then only as I come to a stop.
2. As I slow to a stop, I notice the tach bouncing up and down around idle point, but just goes a little lower each time until engine dies.
3. Cranks right up.
4. Never stalls while at steady speeds.
5. Once I get back into town and drive at slower speeds for awhile, problem goes away.
6. Plenty of pep, good acceleration in town and on highway.
Any guesses what I might try next?
I had the crank sensor on a Co .
My wifes Concorde had the starter go out last yr and cost $400.
I also replaced the electric radiator fan on the 99m last yr -again off ebay and did myself.
Both cars now at 110,000 and doing well.
PS when the window sticks I bang on the mid door while holding down the button and it comes down.
Good luck with yours --these forums are a great help.
Roger/Nashville rogjack6112@comcast.net
crank sensor went out on Concorde and 99M.
Starter solenoid contacts on both cars
Good luck Roger
I have read from others that the fuel pump as worked but the dealership didn't say.
I'm at my wits end - it stalled the other day on highway merging into traffic to get onto another highway, also stalled on the ramp - it is getting scary.
Is it my top cam shaft ticking? or exhaust?
I'm thinking mine might be a starter with a bad segment, or the solenoid itself clicking but too weak to fully fire and engage the starter.
I'm curious to see if there is any help. Thanks, John
Thanks and I'd still welcome any other suggestions, John
Diognosis at Chrsyler couldn't pin point it and don't want to just keep throwing money at it .. . .
thanks for any help
