Has anyone else experienced this issue, and if so, were you able to fix/address it?
If none of that works, you might try flushing the transaxle and putting in a good synthetic fluid like REDLINE...kinda expensive but not expensive like synchros are expensive that's for sure.
Synchros do wear out over time--it's not that unusual but 117K seems a bit premature for this sort of thing.
I have a 2002 Jetta, automatic transmissin with ~67,000 miles on it. Just this Saturday I noticed the gears were slipping (making a jering sound) when thecar shifed from 1st to 2nd gear.
I took the car to the shop that my family has gone to for some years. They told me it could be either that the transmission fluid needed to be flushed or that there was a problem with the transmission. They were about to close so the owner asked me to bring the car Monday morning to flush the transmission fluid. Well on Sunday the jerking/kick back noise got a lot worse, and
the check engine light went on too. This morning the repairman told me the error he got was P1778 indicating the transmission is no good anymore.
So it looks like I need a new transmission.
My warranty information said the Powertrain warranty is good for 5 yrs/60,000 miles. Has anyone else had similar experiences/problems? Any luck in getting VW to cover the cost of changing the transmission. Or does anyone know of a good place to get the transmission replaced that isn't too expensive in the Washington DC area?. I hear transmissions can cost ~$4000-5000
By the way I looked up error code P1778 and supposedly it means "Solenoid EV7 Electrical Malfunction" - what does this mean? Does it actually mean the transmission is bad?
I owned a 2002 jetta 1.8 T AUTO recently which had 23000 miles on it. It was running good the first one week and then it suddenly has some problem shifting
gears. When its shifting from 1-2-3 gears it drags a bit and we can know that its changing gears and the rpm runs to above 2 when shifting gears. I dont know what the problem is. If you guys know anything about this just let me know before i go to do some repairs.
The comment above about no dipsticks on newer jettas is true of automatics. Manual transmissions, however, have never had dipsticks...it is nothing new or unusual.
My question is: is it better to downshift by shifting into neutral first and revving the engine a little bit to bring the rpms up then shift into the next lower gear, or should I just shift right into the next lower gear and let the clutch out? I heard that its better to bring the rpms up a bit, but does Volkswagen recommend this?
Thanks for your help
(a newbie, first message posted)
By blipping the throttle, you avoid the nasty thing called 'compression braking', which could, if the car is unbalanced, cause a spin.
As far as your Jetta is concerned, the 2.0L automatic transmissions were made in Mexico, and are a mixed bag when it comes to reliability (at best). I have a 2003 Wolfsburg 1.8T with the 5-speed tiptronic transmission which was made in Japan by Aisin (the same supplier for Toyota, Honda, etc.) - which has been rock solid approaching 110,000 miles.
The Japanese and German-sourced automatics are less likely to give you headaches than the Mexico-sourced ones. Unfortunately, these are only available on the Jetta/Golf 1.8T (Aisin), and the Passat (German transmission).
Golf/Jetta 2.0 cars manufactured between 1993 and early 2005 came with the Mexican Transmissions.
We had a similar problem in our '05 new Jetta with the 6 speed automatic and they had to replace a part in the transmission called "valve body", IIRC.
I have a 2005.5 New Jetta 2.5 Automatic and I had the same problem, it started at about 9,500 miles and was only a hard shift from 1 to 2 gear and got worse where it was hard shifting from 1 to 2 and 2 to 3 so at about 14,000 I started having the dealer look at it at first they said it was the control box and that needed to be replaced, took it in and they did that, and the problem was still there.
So I took it back and they told me that there wasn't a problem but that they would call the VW Rep. I think the VW Rep suggested that this dealer call VW Engineering. They did that and they called and told me that the car needed a New Valve Body (guess this is a box that has little balls in it that when you shift gears the balls inside the valves move). Once they replaced the Valve Body Box the problem went away and I now have 33,800 on my car and the problem has not resurfaced...
My boyfriend has the same exact car just a different color and his never once hard shifted so we knew that it wasn't right. You just have to be persistent with these dealers until you get satisfaction!!!!!
I suggest you take the car back to your dealer and suggest to them that the Valve Body may need to be replaced or that they need to call VW Engineering or your local VW Representative.
Hope this helps and Good Luck!!
mls0413
I'll miss my leased accord, but that is the fun part, you get a new car often. You know, you make memories your own car, you get attached, oh well.
Thanks for any input you may have!
You could have them ride with you, hope you are lucky enough to have the problem occur and point out what you are talking about when it happens. Also make sure that you have documentation from the dealer indicating what has happened, so if it finally gets worse you can try to make a case that the problem was there before warranty ran out.
I'm not a big fan of extended warranties, but if you are really worried about a possible expensive transmission repair you could look into the cost of one just for the power train.
I guess I do not have full understanding of the warranty. My car has 48000 miles. Do I actually have coverage for the transmission under 5yr/60,000? I mentioned my concern about the warranty to the dealer and he told me 4yr/50K.
Does anyone else have this problem with 04 Jettas?
http://www.edmunds.com/used/2004/volkswagen/jetta/100352546/standardwarranties.h- tml
2002 Jetta GLS 1.8T
60,500 miles
2002 Jetta GLS 1.8T
60,450 mi
