Visitor Agreement.
My front end problems are not solved - not even close.
BTW I can not see post numbers 414, 415, and 416. How can I retreive them? Based on your post 417 it sounds like I may have missed something important.
JMJK
I believe they were even more off-track than mention of "bud-vases" and were deleted...
Ocassionally, I also get a "bo..ing" (sp) noise coming from somewhere. It sounds like a spring suddenly releasing pressure. I suspect an improperly seated spring and insulator pad. Has anyone else heard this noise?
I sometimes get a very muted sound, like two metal coat-hangers clinking together, from the back seat area... that's a kinda spring "boing" sound...
Don't anyone tell me this is a normal suspension sound. Believe me, I've had many, many cars in my lifetime and many were very high-mileage vehicles. None ever came close to the noise this Azera makes. Most of those were owned when I lived in Detroit. Anyone who has ever been to Detroit knows how poor the roads are. I could only imagine what this Azera would sound like on really rough northern roads.
My other vehicle is a 2001 Ford Ranger with 140,000 miles on it and it's perfectly silent going over the same exact roads where my 6 month old Azera with 5,000 miles sounds like some component of the front suspension is coming apart.
The same Azera was nearly silent when the ambient temperature was low (below 60). Now that it's warmed up here in Florida, this thing has become very noisy. Mine was assembled in January of 06. Since the newer 06's and the 07's are reported to NOT have any clunking noise, is evident that someone at Hyundai did something to fix this. Someone at Hyundai must know how to resolve this.
I noticed that some of the suspension components were ground out to make certain bolts and nuts fit properly. I wonder if there is some problem with the parts that was fixed properly on later models.
Somebody must know what is going on. I will be scheduling another appointment with the local dealer next week. I don't expect any results but I want this documented clearly as a "new" vehicle problem for any future fixes.
It is my first Hyundai, I am not impressed.
My car had an excellent ride in the winter (purchased in Feb) but now that it is above freezing, I find the ride much too soft for me. Eventually, I would like to beaf up the suspension, but I want to correct all problems first.
I don't recommend this car for rough or uneven roads here in the north. But then I am probably spoiled with my Volvo and Ford pickup.
The ride/handling balance is fine for me and was one of the main deciding factors for this car. No, it's not a sports sedan, but I've had those and on smooth southern roads, I prefer them - but not on Michigan roads. Around here, stiff suspensions will beat you to death.
I would not recommend Azera's for dirt roads, you are absolutely right.
WHo mentioned anything about dirt roads? Did I miss something?
Brian
Also scraped one muffler, so I guess I ran over the #$@!! with both front and back wheels. They say they don't see any other damage and when they get the parts in ($180 installed) we shall see. Seems not to have affected steering and no shimmy resulted, completely drivable, but above 60 mph I start to hear the loosened trim rattling in th' breeze...
I wrote about this some weeks ago in detail. The car needs to be jacked up in a manner that lifts both the front and rear wheel and then securely held with jack stands. Note the car was not set down on the stands. They were in place under secure frame members just in case the jack slipped.
my clunker started after 6,000 km, and the suspension seems to be getting looser with more rattles over time.
If this is true then the body is 'HARD' mounted to the frame and the rubber part does nothing. If this is not tight then the steel bushing will 'clunk' with every bump, think about it.
If in fact you are talking about the rubber bushing in the bottom of a typical rear shock absorber then yes the steel bushing prevents the bolt and washer from over tightening. But remember the movement is up and down so the load of the shock movement is softened by the rubber bushing and not the bolt.
Body frame mounts are typically a high durometer rubber sandwiched between the frame and body. This rubber mount should be slightly deformed when secured. If it is not tight you will get a 'clunk' of a different tune.
This repair makes the most sense to me. By replacing the strut the tech had the necessity to tighten all of the associated connections and fittings.
I suspect Hyundai is having sporatic problems with it's strut supply or supplier.
Interesting. My dealer said that he would not order a new strut assembly (he said this a long time ago) because he was certain that Hyundai would not reimburse him for this type of "warranty" work. Presumably your dealer views the clunk as warranty work . . . this is a step in the right direction but I am curious if other dealers will follow your dealers lead - particularly mine.
Would you kindly provide the name of your dealership so that I may refer it to mine?
JMJK
Please let us know when the repair parts become available.
Thank you for your interrest and input.
This is great news. My build date is 1/25/2006. While I understand that you "just sell em" your post is inspirational (i.e. there's light at the end of the tunnel). Did your service rep for your region mention a pending Technical Service Bulletin, in other words how do I authenticate that there is a Hyundia approved fix for the Azeras? I don't want to go to my service manager and ask for a fix if he hasn't heard anything about this news - our relationship has been strained given his unwillingness to acknowledge the clunk.
Thanks a million,
JMJK
Thanks SO VERY MUCH for looking into this for us. I'm sure you have several hundred on this forum awaiting an answer...
btw, if you're reading this and have not yet called Hyundai customer service to get a file number about this problem, PLEASE DO SO.
Re: 465
My front suspension continues to get worse, including the left side. It is getting hotter here in Texas (Houston) and as the weather gets hotter the clunk gets worse (there have previous posts regarding hot weather and a worsening clunk). I continue to have the radio as loud as necessary to mitigate the clunk. I haven't seen a post from Richardr35 regarding his search for a TSB - richard are out there working on it, if so please let us know - we do appreciate it.
I have an oil change coming up and will again voice my extreme heartburn about the front suspension problems.
Man I wish we I could get this behind us.
JMJK
yes bring it in to my dealership here in Houston (Hub Hyundai West on I10)... we need to check the build date. we can also do the oil change for you while you are here. Look me up, my name is Richard, I'm the only Richard here. At this time there is not a TSB yet. But there is a fix!
Richard you said you need to check the build date. does that mean the new Azeras that are coming from the factory with the fix and are OK?
