Chrysler Sebring Water Leaks
1235
  • schaferjbschaferjb Posts: 2
    Great work and info/pictures on your website. My water leak is AC related. Twice now, I have had to lift the carpet and soak up all the water. After the first time, I took it to a Chrysler dealer and they said my evaporator drain line "must be clogged up." They "blew out the line" from under the car and said they ran the air for awhile and saw that the water was draining properly. I put the car all back together and was able to use the AC for a week. Yesterday I ran the AC and the passenger side filled with water again. I am currently in the process of drying out my car for the second time. Obviously the dealer did not fix my problem. Is my evaporator the problem???? The AC cranks out cold air (to the point your freezing). Is there something I can do or check. I am not to interested in giving it back to the dealer.
  • kaycankaycan Posts: 2
    Cricket,
    OMG that is what happen to me... (speakers, hissing popping) then smoke coming from what looked like the dash but not sure. We had heavy rains here in Illinois last night and this morning. I have had the flooding problem for abt 2 years, but last year I found the rubber plug holes (rear wheel panel), and that seemed to have held off heavy water leakage into the car. I have a '99 Sebring Convertible JXI and the flooding started happening about 2 years ago... I once found some slits under the car, I jammed a wire hanger in it, but it really didnt do much to stop the flooding. but from what I am seeing (as now more and more ppl are having the same issue)... I see that there are probably more than 1 slit and more than 1 plug. My radio is shot.
    I took it to my mechanic had him take the radio fuse out, for now to stop the popping and hiss ( I was scared I was gonna get electrocuted)... My electronic door locks no longer work and I hope those are my only problem. I have to wait until it "dries" out before my mechanic can tell if I have futher electric damage... I LOVE this car... and dont want to replace it... Im going to have the carpet replace as well as the radio, new wiring to new speakers.... I just hope it wont hurt my wallet too bad. I dont want to by a new car. Oh, the amp (passenger side) was siiting in about an inch or 2 of water this morning...The driver side was soaked, but not flooded... Im going to see if I can pull up the rubber railing thingys and put a coat hanger down in the rear qtr panels to see if that will loosen up any debris that is clogging the drain holes....
  • My 2001 Sebring Coupe AC started having intermittent operating problems about 3 years ago - seemed to be related to humidity, but would frequently start operating after a brief engine shutdown, AC repair shop said it was a sensor integral to the compressor ($900) and recommended I drive until it got so bad I couldn't stand it. Recently found water puddling in front of drivers seat, but could not locate source after ripping up floor mats. Also could not find AC drain even with car on jack stands. Local mechanic identified drain as passing through the firewall just above and to the right of the gas pedal, he said that it came out just behind the steering rack with about 1/4 inch clearance - no room for a drain tube. He blew out the drain and sealed (at least tried) the tube to the firewall with silicon. Both problems have been fixed. I suspect that water accumulating under the evaporator because of the clogged drain was causing an error reading on the AC instrumentation kicking it out.
  • I have a '97 JX convertible and every time it rains, water is getting into the frame on the passenger side. There is no water in the car at all, but I can hear the water sloshing around in the frame. I've had small holes drilled to help drain it out, but the mystery is where its getting in. Any suggestions?
  • Mr_ShiftrightMr_Shiftright Sonoma, CaliforniaPosts: 58,806
    Must be a convertible top drain somewhere. Most converts have them but I'm not familiar enough with your car. Anyway, it's possible the drain leaks internally as it passes water to the ground.
    MODERATOR --Need help with anything? Click on my name!
    Share Your Vehicle Reviews Here
  • I noticed all of the inside water leaking / pooling mentioned in the Sebring Convertible Posts. I wondered how everyone felt about the long term advisability of running my new Sebring Convertible through an automated carwash in the fall / winter months ??
  • ydasilvaydasilva Posts: 2
    edited September 2010
    We had a large amount of rain fall in the DC area this morning (3-4 inches overnight). Now I have about 1 inch of water pooled behind the driver's seat. I called the dealership right away & they said they have a guy that comes out every Wednesday just for this kind of issue. That makes me think that they know about this problem & wait until someone complains before they do anything about it. I don't know if my warranty will cover this. I've had this car for 14 months without any problems. Of course, this is the first BIG rainstorm it's been in. I guess all that snow last year didn't count. Oh yes, this is the first car I've ever had that has a sunroof. Maybe that's where the problem lies.
    Clogged sunroof drains are a suspect, as are clogged drains for the fresh air vents under your wiper blades. Other less likely but possible areas are the outside mirror mounting seal, and the windshield, of course.
  • When it rains My front passenger floor is soaked in water , about twoto three inches. There seems to be a few drops of water on the inside of the car next to the dashboard paneling that meets with the door. Is it the drains on the door or under the seal on the door , roof area or even the windshield? The water is no where else. PLease help......also, does anyone think it would be covered through my dealership warrenty? : :(
    If you could get under the dash a bit and see if you see water running down the firewall---that would tip you off to a fresh air vent drain being clogged...usually roof drain leaks don't enter that way, and windshield leaks...well...maybe but generally they are in the corners of the windshield.
  • mopar70mopar70 Posts: 1
    I to have this water leak in my 1996 Convertible Sebring. I hear a swishing of water in a tank that seems to not be emptying out. The back floor floods deeply and then it swishes up to the front floors. I will be taking it in to the Chrysler shop in town to see if they can clean the drain holes unless someone knows where the holes to clean out are? They had told me there is a drain pan that must not be emptying out. The person we purchased this from did not tell us that he had had any of these problems. Now I wonder?
    My 2009 Sebring has a sunroof. As I described water kept pooling up on back seat's floor. I took it to the dealer & they fixed it without charge. They said it was under warranty. It was a drainage tube that was blocked up.
    You might try lining the trunk with newspaper, then closing it and washing the tail lights with water. Tail light gaskets are a very common source of water entry from the rear of the car. These are the gaskets that mate the entire tail light assembly to the body, not the gasket that mate the lens to the bulb area.
  • rjg63rjg63 Posts: 1
    I have the same problem with my '97 Sebring convertible but it is on the drivers side. Wiki answers says it is due to plugged drain holes (3-4?) on the underbody on a strip of metal where the underbody and visible body come togerther (wherever that is.)
  • jopeckjopeck Posts: 2
    And that's exactly what it was!
  • rbenderrbender Posts: 30
    go here and see the pictures I took of the drains under the car and in the doors http://chryslersebringdrainslots.webs.com/Drains.htm
    edited May 2011
    Awesome info! Thanks for posting this for us!
    Visiting Host
  • ClairesClaires Chicago areaPosts: 1,222
    Thanks, rbender!
    ClaireS, Host
    Automotive News & Views | Coupes & Convertibles
  • hms121hms121 Posts: 1
    in the 2007 the hose runs to the right of the gas pedal put a pan under when you unclog. lots of water
  • Same thing happend to me and i was wondering how did gettin your radio replaced? i was going to keep the drain holes clean and also park in my garage on rainy days but i dont want to get it replaced if the same thing will happen again.? please get back to me asap!
    I was able to get the radio replace, without having to get a amp, BUT the sound is not as great with the amp. Thinking abt having an amp put in. I slightly have a wet floor on driverside, but no flooding. I took it to the dealer, and allegedly they cleaned out the stoppage, but like I said, I have damp floor board in driver's side when it rains.
  • cynthccynthc Posts: 1
    Your site was EXTREMELY helpful. I'm a new Sebring owner 2005 and loved the car til I drove it through two hours of rain and found the passenger floorboard soaked. Took it to Chrysler explained my problem and all the tech did was check to make sure it wasn't the air conditioner. I read all the advice on line about cleaning drain slits but had no idea where they were located. Can't wait to try it out and fall back in love with the car again
  • Thank you,thank you,thank you. I can not thank you enough for the information on water leaks on my 98 chrysler convertible. My wife loved that car until the leaks started on the drivers side. I only wish that I had found this out before.Thank you again.
  • I have a 2005 Sebring convertible that I purchased in May 2011. I took it thru the carwash and it leaked around the driver & passenger windows. It also leaked during a heavy rain. Do I just need to replace the weatherstripping along the top of the windows or is it something else? If it is the weatherstripping, where online is the best place to buy from?
  • jbuscjbusc Posts: 11
    Two questions regarding my 2001 Sebring Convertible - I pulled up my driver's floor mat to find the drivers floor & carpet soaked - the rest of the floor was dry - I drove in heavy rain 2 days ago but none leaked in the roof/side window area. Where should I be checking for leaks, firewall maybe?
    Second question the hooks that attach the roof to the header appear to have threaded hokles that look like set screws should be in them but there are none - aren't there supposed to be set screws to keep the hooks from turning & where might I get some? (I called the local dealer's parts department and they seemed to think there are not supposed to be set screws - then why the threaded holes? Thanks
  • I found this on another web site, it seems plausible, I just vacuumed 4 inches of water from the back and front driver side floor boards. It's sleeting right now, so I'll have to wait to look for the weep holes but I have a good feeling about this one. Please let me know if this works. Sebring Convertibles have weep holes under the body that get clogged with debris and cause the water to back up into the floor. Take a paper clip and straighten it to clean out the weep holes. The weep holes can be found just under the frame at the doors where there is a seam(about where the jack would go). Along this seam about every 12 or 16 inches there will be a small slot for the water to drain.
  • I've posted photos and web of the drainage holes many times!
