Your top probably has drains that run through the rear panels in the back seat area (the panels under the rear windows).
I drilled a 3/16 hole in the tire well and it has stopped the water collecting.
I read last week that it is probably a seal on the convertable top, but I run water down the top and it doesn't collect.
Let me know if you have any ideas, and in the mean time, drill a hole.
There was no evidence of water running from the front to the back until they started pulling the carpet and padding up. I fought with the dealer on this for a long time, until they finally called a 'leak doctor' who found it in one day. Now I just hope it dries out fast enough after two weeks to not mold!!! Good luck!
For the same reason that car manufacturers should never honor a claim for carpet damaged because windows were left open during a rain storm, consumers should never let a car manufacturer insist that carpet soaked in water caused by an unrelated defect hasn't been damaged.
Jax
Mike
She also lost her washers. It turned out the plastic splitter (tee) mounted under the hood had broken into a million pieces from age and heat. You can go to the dealer and pay him for a replacement or go to your local parts house and go into the "Help" section and buy the vaccuum connectors assortment. There is a tee in there that will suffice in the replacement. It will require pulling a little of the slack out to attach it to the tee but when you are done, it fits nicely and does not require attachment to the hood. It is tight enough to stay in place.
Later!
Mr. Ed
Yes, same thing here with mine. I bought my Sebring Limited Sedan last September. My car stays parked in the driveway, so it gets the full force of any rainstorm. Although I don't check the trunk often, I have found standing water in the spare tire well.
The one time when there was a considerable amount I just wiped it up with a few rags. I haven't taken it to the dealer (yet). If I do maybe I should print out your story to show them and perhaps save them some trouble-shooting steps to getting it corrected in one trip.
Let me know if this last trip to the dealer has fixed the leak for you. Thanks.
Edit: We had a rather intense rainy weekend, so I figured it was time to check the trunk. I just went out and inspected it and the spare tire well is dry.
One way to see for sure where this water is leaking in from would be to remove the trunk liner panels (I believe there are 3), lower the rear seats, get in with a flashlight and have someone spray the back end with a garden hose. Try to simulate the force and water volume of a rainstorm, not some pressure you'd use to powerwash the deck.
I had the trunk panels off when I was installing a backup camera (pretty cool results - PM me if interested) and I noticed those trunk vents. I think the louvers are tilted downward, so I don't see how water can be getting in there. I guess it's possible.
If I ever notice any water inside the trunk again I think I'm going to try the above diagnosis before taking it to the dealer multiple times and maybe I can explain to them exactly what's happening. I'll include your story, too, of course.
If you mean the "squeegee" gasket on the side windows--that could be trickier. Generally they slide off and shouldn't cost very much to replace.
So you step on the brakes and water sloshes into the passenger compartment.
There is a drain hose for the air conditioner moisture that is supposed to run to the outside of the firewall. Somehow this hose gets kinked or put in wrong, causing the condensation to run inside the car instead. Even though the front passenger floor board appears to be dry, if you lift up the carpet, you will discover water running underneath it and pooling in the back passenger floorboard. It was a simple warrantied fix for the dealer to make, and a known issue.
Water can come from the trunk area (rushes forward as you brake). Also if that passenger door was ever worked on, someone could have ripped out the moisture barrier. (not good).
So is there any place to view this hose inside the car?
Later!
Mr. Ed
:confuse:
Does the a/c drain out of the drain at all? It is possible that the case has a crack in it
this would also drain into the vehicle. but make sure that the plastic outlet does not have a rubber elbow attached to it this to may be plugged up and require removal and cleaning.
I also have a 98 convertible... wondering exactly where those holes are located... I found just one place today and it is definitely not a place that could be blown out with an air compressor. I had to use a wet vac to suck about 4 inches of water out of the driver's side front and back floorboard today.
Mendi
Surely with all the posted notes Chrysler must have a fix. thanks
Any one have a quick fix, and drawings showing were the drain plugs under the door are.
Any one starting to get sick and considering class action against Chrysler due to mold bye product of the floor mats being so wet all the time .
