Chevrolet Avalanche Transmission Problems
The new place to talk about your Av's automatic.
I have a 2004 and have had this issue numerous times. My brother is a Service Manager and he hate's when I call! LOL
but he finally fixed it! After many encoder modules he found a update on the 2002 and did it to mine. It is a sensor that works with the encoder! Knock on wood it has worked well for several months now! Good Luck!
Thomas
http://www.chevyavalanchefanclub.com/resources/2002/owners_manual.html
Goldranger
"I've been having a problem with what I'm guessing is some type of trasfer case control/solenoid...basically, sometimes when I start it, the 4x4 selector light shows the red dot in the neutral position rather than the amber 2x4 light. Also the dash flashes "service 4x4". Other times, when I start it, it goes to Auto4x4 rather than staying in 2x4. Other times I can't shift from one mode to another. Usually, I can get it to reset by shutting off the truck and restarting. Rarely, I have to also play with the buttons and/or shift into neutral while doing so. Sound like the same thing? Mine is a 2003 with 60k miles. The problems started around 55k."
Issue has been fixed. I had it fixed under extended warranty. It was the transfer case module that had gone wacky. It's been about 6 months and 8k miles since the fix (with plenting of shifting to Auto4x4 and high and low 4x4 now that it's winter in the mountains) and have had no problems.
I am very unhappy with the dealership and GM customer complaint. What really upsets me is you buy a vehical close to home and then get this type of service. Also, when you call GM customer complain you have to speak to someone that cant speak english and you have no idea what they are saying. I have 6 Lemons to put on my Avalanche and going to leave them on and drive through the dealership and my home town.
My question is, is there really anything wrong with the transmission or has GM rigged it so their transmissions check out o.k.? Obviously there is something wrong, any advice would be appreciated.
The dealer replaced the steering arm in '06 under warranty. Last year '07, I was on a trip out west pulling a small 10' trailer and the trans. went out. It was 2000mi out of warranty, $2500 to fix it. This winter the tailgate handle broke inside, dealer wants over $300 for a new one, NOT ! I'll use a screwdriver ! Last week I took a trip to Canada pulling a 20' boat and the rear universal joint went out - $200 more. The rear end still makes a noise (clunk)when it's put in gear or sometimes when you take off from a stop. I was told by a friend that the rear universal was under recall, but I can't find anything about it it. I have been a Chevy guy all my life, I have '99 dully FWD pickup, '99 Tahoe (best car I ever had) and the Avalanche. I think I am changing to a Ford guy after this one!
I like the Avalanche allot but it seems to be cheap made. Almost afraid to take it anywhere.
Other than that, the vehicle was a good one; not a lemon. Made two trips half-way across the US, and one trip to Georgia. We traded it in April 2008 for a '08 Malibu, mainly because at that time gas was predicted to hit $4 per gallon (which it eventually did.) Because of it's (less than good) milleage, I anticipted the re-sale value of the Avalanche dropping like a stone - and it did; thankfully it dropped after we traded it. I digress. The dealer described the tranny going out as a "freak" manufacturing flaw.
Misha
Wife just told me today, it will not take gas correct when she hits the gas.
What a piece of #$%& !! :lemon:
My 07 Avalanche with 12,800 miles just blew the transmission and the dealer trying to say that they won't cover the warranty due to my 22" rims. Any advice on how to fight this would be appreciated.
Thank God I purchased the extended Warranty for 60 thousand miles! But people used to tell me when I drove my Ford - Chevys the Vehicle! And I say now..I'd rather push a Ford than Drive a Chevy I'm so sick of this big expensive unreliable hunk of junk. In Comparrison to my 2002 F150 Supercrew which I bought brand new..and put 120 thousand miles on it and only changed the Oils, brakes, and had the fuel injection cleaned. It never stranded me and took me all over the US faithfully..it was a quiet ride and even when I turned it in was running smoothe as could be? Why I traded it? I dont know..I wish I could go back but since I cannot does anyone have any advice for me? Turns out my Avalanche will reverse and run in 3,2,1st but does not move in D-drive. Really really strange..I've had cars with Transmission problems but this gave no warnings...before-hand?
you never know run a car fax and ask the dealership to run the v i n for any service work....a service history i wish u well mavrick
OTG
PLEASE let me know what settlement you received & if you had to sign any paperwork which said you could not file any complaints against GM w/ your Attorney General's Office and/or pursue GM for any remaining or future repair costs. In addition, what did GM conclude about your claim and what was your initial problem & onset of said problem.
