I have a friend who has both Honda and BMW Mechanic Cerifications (has worked for several dealers for both at different times) and he says all vehicles should probably have transmission fluid changed every 15,000 miles as it has been his experience that it would probably prevent a lot of expensive repair problems later in vehicles from both of the above manufacturers.
I have also been told to change the trans fluid at 15,000. You do not have to blow out but just change whatever will drain. This is easier than changing the oil since the drain plug is readily accessible. You might consider a total fluid change at about 60,000. One other point, use transmission fluid from the dealer (yes I know it will be more expensive) because the fluid in the Montero uses some type of special additive that is not in the over the counter fluid that you buy at a auto parts store. If you do the fluid change yourself it cost less than $15.
What does the oil pan has anything to do with the transmission fluid? I have a 1994 Montero LS with 205,000 miles on it, still running fine with the original transmission fluid.
My point was after ("Iiffey Lube") cracked the oil pan they may have screwed around with the transmission fluid as well. I will never know the answer to that question. However, I will never take any car or truck to Jiffey Lube again. You are supposed to change the transmission fluid every 2 years or 15,000-20,000 miles according to the dealer. Your fluid most be pretty dirty at that high mileage. But if it works well, don't change it.
My wife and I have two (2) young kids and a dog. We are a very busy and active bunch.
We currently have a VW Passat 4-motion wagon but need more space. We have been looking at the SUV market but don't want one of those monsters but need something that can do a little of everything.
We find the Montero attractive.....any feedback would be appreciated.
Last week, I had my 2003 Montero Ltd. worked on for a fuel line recall. Since then, my Monty makes grinding noises and the 4H does not engage (going from 2H to 4H). Re. the 4H, no warning lights appear indicating transmission failure. And, the gear indicator lights blink as if the Monty is in the process of switching to 4H, but those lights never become solid, which would indicate that it actually made it into 4H. Help! Winter is here in upstate NY, and I NEED my 4H to work!
Well, try to help it a little. Stop the car, put the transmition in neutral and move the shifter to 4H. If it doesn't go, put the car in drive and move forward a few feet. If that does not work either try reverse (I hope you remember that can't shift if you are driving over 65MPH).
Have you had any luck with this? I am experiencing the exact problem and have had no luck getting the 4wd to transfer. Please let me know what you did to get this resolved. Thanks.
Despite wonderful reviews from co workers about the Montero, I wonder if Mitsuibishi is actually going to survive with everyone pulling the plug on their support (Daimler Chrysler).
Is the Montero in its final year, any replacement in sight?
Does anyone know how to remove the radio? My battery died and the radio needs the code to be resurrected. I don't believe I was ever provided a card, and when I called the dealer where I purchased they no longer are in business. Therefore , I need the radio serial # and the other dealer wants $85 to remove radio. How do I get the radio out on a 2001 montero.
As I have just put in a DVD player in my 2004 montero by CircuitCity which required to install a RF antenna, I saw the Radio/CD removal process. you have to pull/pry out the plastic ( wooden texture) portion on top of the radio with a flat screw driver carefully so that you do not scratch it. Then simply remove 2 bolts ( or 4 bolts, I do not remember) are holding the radio. Disconnect the Antenna connection from the back and the power connection. It's very easy as long as you can take the top cover off carefully. You may have to unscrew the Airconditioning unit and simply put screw it back to remove the radio.
Whoever is thinking to buy the NEW Montero/Pajero should do this by this year as this great SUV is going to be discontinued with the 2005 model production ( which is available to dealers now). Here is the news blurb for future replacement by Edmund's -
It's believed that Mitsubishi will be introducing a seven-seat version of the Outlander for the 2007 model year. Part of the appeal for Mitsubishi to introduce this larger variant of the Outlander is the fact that the company is dropping the seven-seat Montero from its lineup for 2006. It is not certain whether the five-seat Outlander will remain in production in its current form, although the company has apparently considered pairing the tentative seven-seat Outlander with an entry-level SUV. The new Outlander is expected to be powered by 3.0-liter V6 which will yield about 250 horsepower. This engine will be mated with a six-speed automatic transmission.
I went out to the garage this morning and noticed something that I haven't before, on the top portion of the spare tire cover (black), there's about a 1'x2' section in which a clear layer has separated from the black. Has anyone else experienced this? FYI, it's a silver '01 LTD, 50k miles, So CA car. I can't imagine this as being normal wear and tear, and wonder if this is something Mitsubishi should be responsibe for? Thanks for any advice/opinions.
I was having diffy issues as well (it would make noise on tighter turns, ad buck slightly) and the dealer said the fluid was very dirty. Changed it out and all is well. Dealer recommended every 30k miles.
Checked with my SA yesterday, and apparently he's been seeing more than a few of this. I should be hearing from the manager this coming week. Also, I passed another LTD this evening and noticed his cover looked even worse than mine, with a lot more peeling.
All the 01 covers are going bad. I caught mine right before 36 months was up. Replaced with an 03 cover in black. After 36mos it wont be covered under warrenty. I havent seen an 01 yet that hasnt peeled.
I did as you suggested and the radio was then easily accessable. However, there is two screws that connect the whole ensemble? which are under the top of the dashboard. Thanks for the info, it saved me $85.
Hello Dinel - sorry about not mentioning the 2 screws on the dashboard but at the end glad to know it worked for you. Just for information - what you really have to do to bring the radio back to work ? Is it every time you have to do if the battery goes down?
So I call Mitsu customer service about this, and all he can say is that I'll have to have the dealer check it out. What does that mean? He says there has been no recalls about it, etc., and the dealer needs to see it and determine if it was nornal wear and tear, weather related, abuse, etc. How could it be normal for the clear to separate from the paint in 4 years of So CA driving and keeping it in a closed garage nightly?
I'm not too confident about my dealer, because I had recently taken it in for a check engine light and they wanted to charge me ~$300 for an O2 sensor. They said it was 3/36k, but I had to show them in the warranty booklet that CA has a 4/50k emisions warranty.
Anyway, the CS rep at Mitsu wasn't helpful. My SA talked it over wih the mgr, and he will talk it over with the Mitsu rep, who come in next month. We'll see...
Looking at a 94 Montero LS 4WD. Seems to be in VERY good shape for an 11-year-old car. We're having a mechanic check it out tomorrow. KBB lists $3775, Edmunds $2061. 165k miles, very clean interior. Don't know what problems Monteros typically have. If anyone has any suggestions or opinions we would like to hear them. Seller asking $3800.
On any used 4-wheel drive vehicle I personally would drain the transfer case and then smell and examine the fluid and the metal shavings. If the fluid smells burnt or has a strange color or the shavings are the lease bit angular I would walk away because you may be asking for some major problems. Most people have a tendency to not change their fluids on a regular basis (especially the transfer case fluid) and this leads to problems in an older vehicle.
I have an 02 Montero and the cover barely made it a year before it started to separate. I have not seen a single Montero in Houston without some amount of separation. I took mine back to the dealer and they replaced with an 04 cover. I think the separation is probably a defect but I could never get them to admit to it. Nice thing about the 04 cover is the screws are attached unlike my 02 cover. Those screws had a tendency to roll around in the most amazing places. Lost one one time on the road - guess I just did not have it tightened enough. Anyhow, I would press the manager at the dealership if they balk at replacing the cover.
I am thinking to buy one, who can tell what price i can get right now? and what price diference should be between 2004 and 2005 models? I would like to go as low as possable.. -:)
43,000 miles on the montero and the check engine light just came on. Most likely an o2 sensor. I believe there are 4 sensors on the Montero but I have not crawled under the vehicle to check. Can anyone tell me how to tell if an o2 sensor is functioning properly since I don't want to replace all the units until they go bad because of the cost? Thanks for the info.
O2 Sensors: Some auto parts shops - Checker, AutoZone, etc.. will check your check engine light for free. Or, starting about $100 - $200 you can get a OBDII reader that plugs into the diagnostic port and you can read it yourself.
Clear Separation: I wonder if it is due to the black tire under the cover absorbing extra heat and cooking the paint? Is the separation around where the tread of the tire is??? Or more on the body of the cover???
Thanks for the info on the O2 sensors. The separation of the clear membrane material happened on top of the tire cover. Most of the ones I see are also on top only, although I have seen one or two that the separation was on the side. Don't think I have seen a cover that the separation has occurred on the front. Others may know better.
The separation started for me after I had taken the cover off to replace a flat tire. I think the tire cover is more flexible than the clear membrane so the membrane ends up cracking and then peeling but this is just my idea. Since replacing with a new cover I now carry an under-inflated spare. One problem with my old cover was that it fit so tightly over the spare that it was difficult to remove without really tugging on it, thus causing damage to the clear membrane. By carring a slighly under-inflated spare I no longer have that problem. I have had two flats since replacing my old cover and have not had a problem yet with the clear membrane on my new cover. I carry a foot pump with me to inflate the spare up to the recommended pressure if it needs to be used.
We love our truck and have had no problems, but for the last 15k miles we have had the truck to the dealer 4 times for the brakes. At 32k we had a full brake job and it performed well. 8k later they developed a pull in the front and the dealer cleaned the caliper slides and replaced and aligned the shims. 4k later the same problem on the drivers side and once agin the slides were cleaned and the shims adjusted. 2k later the rear brakes began to modulate and it was clear that the rotars were warped. As a result they were turned and at my dime as the warranty expired on the replaced part. Now 16k after the first brake job the truck is having problems again. Did I get a bad brake job? Any TSB's on brakes? I just find it odd that I got 32K on the orginal brakes and half that on the replacements done by the dealer. Should I take it to a different dealer(there are 3 in my area) or go to Midas? I love this truck but these brake issues are driving me nuts!
It's not a body-on-frame, rock-crawler it used to be and the body will flex if pushed too hard. The independent suspension that works great on the highway or in the Dakar desert, doesn't help in hard terrain either.
The following review will paint a decent picture and cover some limitations:
I have been working with ADDCO to develop Sway/roll bars to help improve ride quality. Here is where we stand.
Bars are in with new end links that are adjustable. My montero has aftermarket springs/struts to increase ride height approx 1 inch.
First impression is that cornering and roll are greatly improved without increased harshness. There is still roll going from extreme side to side but far less than stock. From what I am feeling on the road I suspect the snow and dirt handling will also be improved via more positive control of the vehicle in spirited driving, sliding, or any other condition that would increase roll tendency.
I have to thank ADDCO for undertaking this project as no other manufacture that I know off currently offers improved bars for the Montero.
It is interesting that Edmunds states the private party value of a 01 Montero LTD with all the opitions, 49K miles and best condition at only 15,700. Thats a steal. I cant help wondering if that faulty roll over report years back still plays a major roll here. Since that report I really havent heard anything about Monteros rolling all over the highway???
thank you for info... it was usefull.. they tested 2001 model , in 2003 it was redesinged a little bit.. Did they improve wheel travel for better off-roading?
Where do you reside? The buzz is if Mitsubishi is not gone today ...it is only a matter of time.Type in the question hit search.Before you buy any old vehicle lift it and study it from below.Not for ten minits.Turm off the lights in the shop and look up with a bright hand held light.You may be amazed.Let "it " parked on the rack over night.Cool down can show a plethora of leaks.Call salvage yards with a grocery list of parts.Do the same at dealer parts department.Many imports do not carry parts..two days turns into two weeks.Call the bank for a loan on a nice 165k plus any thing, they will run as you should.The best home for any 165k import is where it is now.Unless it is $1000 or free.
EASY WITH YOUR MONEY! MITSI MAY WELL BE RUNNING OUT THE BACK DOOR IN THE USA.How many CEO's in two years?Read the posts at Mitsubishi sucks.com.Non performing loans and poor track records of quality and service are the death of MITZ North America.Lights are about to go out.Ask your bank who pays when they go?
Was wondering if anyone might know what the problem is that I'm experiencing. Have a 2001 Montero Ltd with 58K miles on it. No problems at all up to this point. On a trip from New Mexico to Arkansas with the family we experienced a situation where the Montero wants to die and not idle. I can start it back up and drive, but when I stop and try to idle it dies. It's Saturday evening at 7pm and the nearest dealer won't be open until Monday morning. We're staying in hotel right now in Fort Worth. Any suggestions as to what to look for in hopes that I might be able to remedy this myself?
It wasn't clear from your message how far you drove with this condition but one thing I'd try to rule out first is whether you have gas in the tank (despite what the fuel gauge says!). Also, is your battery fully charged? Does the idle condition or lack thereof change if you turn off things like air conditioning? Just some thoughts.
Thanks tidester, We had drove approximately 450 miles and stopped at our hotel. Have a half tank of fuel left and I'm not sure if it might have been bad gas.
Went to start it back up after checking in and there was no electrical power. I jostled the battery terminals and it was able to start as normal. Got about 1 mile down the road going out to dinner last night and as we were idling as we were coasting into the parking lot, and it died. Was able to start and drive, but it would not idle - it died every time when it tried to idle. Since it was getting dark and late, I did not look at again until this morning. Never had a bit of trouble from 58K miles from this vehicle until this.
This morning I cleaned off a little layer of scum off the battery terminals (but they were pretty clean already) and tightened them up, and started it up. I let it idle for 15 minutes and drove it around for a little while. There seemed to be no repeat of the problem. Will take it down to AutoZone or PepBoys and have them run a diagnostic and also check the battery this morning (original factory battery).
I hope that was the problem. I heard that fuel injected vehicles like our Montero actually needed the battery while the engine is running. Is that true.... that this fuel injected engine requires a good battery condition and connection to operate properly?
I'm glad to hear you got it running! I'm not familiar with the specifics of the Montero but you might want to make a quick run over to Got a Quick, Technical Question?. And, certainly, you'll want the problem diagnosed ASAP by a qualified technician.
I think the fluid is supposed to be changed at 30,000 miles, anyway.
although DARCARS in MD, will tell you it should be changed at 15,000 mi.
PS: I heard that the 2005 Monty's will have a reworked engine for a little more power.
FWIW.
http://www.edmunds.com/new/2005/mitsubishi/montero/100491990/stan- dard.html?tid=edmunds.n.researchlanding.leftsidenav..7.Mitsubishi- *
Mitsubishi: Falling Further Behind (Business Week)
Warranties aren't worth much if they aren't in the US.
Mitsubishi Announces Future U.S. Product Plans (Inside Line)
in reveiws everybody says: excellebt off-road ability, but avybody did actually take that vehicle off-road? How was it?
I like Montero, but there is no way to check how it handles off-road untill you buy one and it can be too late after that...
please, advice...
http://www.fourwheeler.com/roadtests/13258/index3.html
We love it, our first SUV.
I am planning to get the running boards, spoiler and the hood guard, any suggestion on where to find them for a good price will be helpful.
R
Thanks!!
Bob
