Could it be that thing above the battery? If so what is keeping out the battery fumes.
Also, i want to add a sensor at the back of my car so that when i reverse i could know whether there is anything/anybody/kids behind my car which i may not notice at first. so where should i go for that change? does it require change a lot? how much will that cost?
Any help with the new toy would be greatly appreciated or maybe a link to a website that has parts over seas.
kcram - Pickups Host
SUVs and Smart Shopper
at cranking the motor at starting it. It has no motor
noise any other time and is not consist ant when it does
this. Warm cold first time starting middle of the day.
Is there a oil pump or a sensor that feeds the oil at start that could be failing?
The dealer wants to go in to the bottom end, they say their
not sure why. This seems an unusual answer?
60k mile. Excellent condition
Any of you GM owners that have experience with these tire pressure sensors or had similar problems give me an opinion.......
Rocky
We can't have the conversation here, but a note about tire pressure monitors might save you some time. They go off when there's a differential in pressure between tires not when your tires are all low, i.e. one tire is low compared to the to the others. If you simply add air to all the tires that won't reset the light. You need to make sure the pressures in all the tires are the same.
Thanks for the advice. I threw some air in them to make sure I could get home. I can't find my pressure guage so I'll be buying a new one today or tommorow.
Rocky
Anyways since then the automatic door on the left side has broke two times!
That is not right for a new car. Is there anything I can do?
You might want to share experiences with other in our Geo Prizm (Metro) discussion.
MODERATOR /ADMINISTRATOR
Review your vehicle
Review your vehicle
Review your vehicle
Review your vehicle
Review your vehicle
Also, I notice my van makes a Rattling sound in the engine when accelerating. Not sure what that means. any help would be appreciated.. thanks
