Quick Links
Quick Links
Are you under 40 and think that you might not be able to afford a brand new vehicle when you purchase your next car? If so, a reporter would like to talk to you. Please reach out to [email protected] by 12/16 for more details.
Jaguar S-Type Climate Control Problems
in Jaguar
AC or Heat controls acting erratically? Post your questions or experiences here!
Under warrantee, the dealer reprogrammed the computer (which one?) two different times and that seemed to have taken care of the problem.
I'm not very pleased at being so dependent upon computer chips that may crap out unexpectedly.
jerry steinke
Everything works fine now.
I'm 3 days out of my 4 year warrantee now I wish I would have brought it in.
I don't know if the damper is loose, or the vacuum servo or what. The Temp and air work fine though,, have you fixed your problem?
I don't know if the damper is loose, . The Temp and air work fine though,, Of Course its at the dealer now and hasn't made a peep!
This a low mileage car that has a climate control problem. In summer, the AC will work just fine for days and then start blowing hot air until it decides to work again. In winter the opposite occurs.
I would love to fix this myself. Any ideas?
I bought recent a Jaguar S-Type 2000/2001 and I am with the
same problem in the control climat. I work the automatic but
the air only conditioned the fan works and it doesn't cool.
He begins hot and later the fan only works.
What can be happening?
It will be that the conditioned air needs product to work perfectly
in the cold function?
Please help as soon as possible.Thanks
the conditioned air perfectly worked in the cold and
in the hot? Greetings!
before the light went out i did notice movement in the light as i was hitting bumps in the road.
pfib
pfib
could it be the auxiliary water pump?
I took the auxiliary water pump off then it worked. Once the car got hot, it started blowing hot air.. You think it might be the auxiliary water pump?
Any suggestions
