Visitor Agreement.
Why would a transmission quit uphill? I had only one instance in the past when I thought it slipped. Other than that I think this failure was sudden. I turned the car around using gravity, and rolling downhill I was able to engage trans in 2nd gear. I took the car to the mechanic (authorized he says to work on Jags), and I had the trans fluid level checked and there was no problem with the fluid.
Before it quit, here are some things that I noticed, that might mean something for the diagnostic: I once adjusted / tightened the cable on the J-shifter in the cabin (1.5 years ago). Since I bought it (used) in 2007, I always had to wait a few seconds before the transmission would go into the first gear. After, that it was a breeze. Same thing going in reverse - had to wait until it engaged in gear, before accelerating.
I read another posting's answer from SoberGuy, and it looks like there is a solenoid for the shifter. Could it be the solenoid? What are the symptoms when the solenoid quits? Can this be changed without rebuilding the whole transmission? Can it be changed by my mechanic by accessing the it from underneath after removing the pan?
The mechanic that is looking at my car did not have the right code reader computer program (it was not reading 4.0 codes). He claims that he updated the software today and he called me to tell me that there are no codes from the transmission (I had the check engine light on when I took it in). He concluded that with no codes it is evident that the trans is bad and I need another one...
When I took the car in, the first thought was the fluid level. He checked it and it was OK. Another thought was that the filter might be clogged. He took the pan down, but could not get a filter that day (Saturday). The pan magnet had some metal shavings but very little. I would say normal wear (like a thin paste on the magnet). Is it worth changing the filter and refilling the oil? Could a clogged filter cause this?
Any comment or advice is appreciated. Hopefully SoberGuyJaguar is still around. I would like to hear his opinion on this issue.
I searched eBay for used trans. I am thinking to fix it and sell it. I found trannys from $450 used to $1700 and up rebuilt. Any advice there?
Thank you everyone, and have a great day!
clutches will throw ratio codes in your trans. control module. Sounds like your technician doesn't have a scanner that will read anything but engine codes. Occasionally you can find a car that will flair between shifts due to low fluid or a bad shift solenoid. Unfortunately, a car that was pulling under full power untill you tried to climb a hill doesn't usually fall into this catagory. You MUST find a shop
that can read your transmission codes and see which part of the system failed.
Anything else is just guessing. Buying used transmissions that are 10 years old when your not sure what is wrong with yours is also a big gamble. When you call around to transmission shops, be specific. Can they read Jaguar tranny codes or not. I ASSURE you. If your transmission is acting up, then there are codes in the
TCM which will point to the failing system. Good luck, Soberguy.
when i step on the gas my temperature needle goes to high when i slow down or brake the needle goes back to normal temp. i do not know if car overheats ?
I'm thinking to buy a 2003-2004 Jaguar s-type R
I read a lot of messages. a lot of people saying that there are big problems with Transmission on 2000-2002 models, but what about 2003 or 2004?
i just sold my 2001 BMW 740i and it had similar problems that Jaguar has. The car would not go into reverse gear.
i tried to fix it but i couldn't, even bmw dealer ship said that they can not do anything except changing a transmission.
so before buying S-type R 2003/2004 i would like to know if it has the same or similar problems.
I was also thinking to buy XJR 1999-2002.Any sequestration about this car problems?
Tank you.
the parking brake before putting the car in park. This transmission has a lot of gear noise even when it's new, but it works great. This is a vastly better car than the 1999/2001 xj-r. Soberguy.
engine. For your sake, I hope it is just an exhaust leak. Don't mess around with this. Find out why it is loud immediately. Soberguy.
the cooler lines that go from the transmission to the radiator. You can burn up a good transmission by driving it low on fluid.
P.S: There is no dipstick on that transmission. Fluid level must be checked on a lift by someone who knows how to check it.
Does anyone know if this could be a torque converter or speed sensor problem? I have an OBD II code reader/scanner, but it doesn't show there are any codes stored in the system? Its been a wonderful car since I bought (used-repo) 3 years ago with 79,000+/- miles. Now showing 99,214 in miles (not my daily commuter)... Hoping its not going to be something too expensive as my wife would like to see it go and replaced with something else like an ugly Mercedes or BMW, but I love the look and feel of this car over anything they sell new or used! No other issues with this car until now and all routine items have been taken care of on time. The 100K service was also completed last month (early).
Any help anyone can offer would be greatly appreciated and if you know if a reliable and honest mechanic in the Riverside, California area (92562 zipcode) let me know as many of the Dealers close to me have gone away. Thanks again!
from 100,k service. Could be something wrong. You must get your car properly diagnosed. Does turning the car off and then restarting it cause the trans fault light to go away?
can reply to this post or kimg0530@yahoo.com
If you get the codes, report back to us and maybe we can give you some ideas of what's up.
I had a light come on saying "Gear Box Fault" twice while backing out of my garage. I went to the dealer and was told I needed to keep my foot on the brake pedal when shifting into drive !!!!REALLY??????????????????????????????? I informed them, that was what I always did, however I would be EXTRA cautious about doing it now.
When I shut off the car and restarted it, the light/message went off and it drove fine. The THIRD time this happened, a few weeks later, the car would NOT move when I put it in drive.
This car has had every service, many extra oil changes, and was not driven by a maniac !!!
I was told the problems of the earlier models (I had a 2000 model) transmissions, window regulators, etc etc had all been corrected !!!!!
I am NOT sure if the problem is the transmission. They do not repair them, they replace them without ever opening up the old one. Does anyone have any ideas about this ???? This is a very costly repair, coming at a bad time and I am not confident they have identified the problem.
Thanks for any help.
Ty!!!
Ty!!!
PENTOSIN ATF1-1L
You may want to further research this online as a lower cost alternative to the Shell ATF M1375.4 recommended by jaguar, which is very pricey indeed.
and what did it cost? Is that software or parts?
tanks tazz
When defects in a cars programming are discovered, the engineers rush
to come up with a new program that will eliminate the problem. Sometimes the new reflash has its own problems. My '97 xk8 had about 6 new reflashes
announced (transmission only) between '96 and '05 when I sold it. 1 hour labor time is the normal charge and there are few shops other than the dealer who can do it. With the "Data Aquisition Charge" It would cost about $135.00
at my shop. Most Dealers would be cheaper if they are honest because they don't have to pay to aquire the new program from Jag.
Last on your Trans, mine had torque coverter squeal which eventually chewed up the tranny.
I had the trans flashed many times, but only would last for a few months and I would get program drifts. Trust me, if you want a bullet proof transmission to go back just have program drift. The ZF trans in this car is used in many high end cars.
Oct 09, 2012 (9:04 am)
In answer to your message, I also had a tech tell me on my 2001 S V8 that I had a weak or misfire on a cylinder and they wanted to pull the heads. Case in Point I ask them to switch the ox senser from left to right, there are 4 of them on the v8. bingo, the other bank misfired. Replace one ox senser for 200.00 at 55,000.00 the car now has 100+ on it, good motor!!!
To you home or shop if you order thru "World PAC.com. just download their "speed dial" program, and you just got access to the cheapest Jag parts and even Technician advice. (for a fee) Soberguy.
