A. Stay away from Toyo. Stock on my 2008 Highlander Ltd. was Toyo A20. Junk tires that did not last very long, real bad on WET roads. When wore out at 24K, I had no choice to get TOYO H/T because my 2008 Highlander had 19 inch tires.
These lasted ok, but not stellar. Wet roads just so-so. Michigan Winter, not too good.
I now have Goodyear Assurance CS tires on vehicle. Been VERY happy with them so far. Comfortable ride - good grip on wet roads - seem to handle high speed and cornering pretty good. I had Assurance tires on a Bonneville a few years back and they were good tires, so I went with these. I have heard from dealers the Comfy Tred + Triple Tread were former styles.. This one is called Assurance C/S and has quieter tread design compared to former styles.
I would also imagine it does boil down to one other important factor --- How long do YOU plan on keeping vehicle? Tires are big/expensive investment and you can pay lesser money and get lesser quality tires -- OR -- you can buy better quality like the Goodyear tires and pay a bit MORE for them, but get better results and longer lasting tires that are quieter-better handling - better fuel efficiency - better on wet roads. Mine are Goodyear Assurance C/S - 19 inch and have them on vehicle for about 4,000 miles so far. Happy with the purchase and will see how they handle when Michigan Winter arrives. Hope this helps and happy shopping and safe driving.
Late Saturday night the low pressure light came on, so I messed with it Sunday and couldn't get the reset button to do anything after I adjusted the tire pressure to 27 in all 5 tires. Three of the tires measured 27, the right front was 31 and the spare was 25. I don't know why, did someone at the party mess with it? Nah. I figured Goodyear was aiming for 27 when I bought the new tires 7 weeks ago. It was actually chilly Sunday morning and I was parked in complete shade fwiw.
Yesterday I gave up and went to Goodyear after lunch to ask for advice. The man on the desk said he used to work for Toyota. In about 2 minutes they had all 5 tires up to 30 pounds. When he started the car the light went out. He never touched the reset button and added that you should seldom (ever?) need to reinitialize the system.
Oh, and he told me that the light will come on if one tire is off by a single pound. So how did my pressures get so out of whack without the light coming on? Hmmm? I hate computers.
John
Now comes the new Goodyear tires. Have not installed them yet, but have them in garage ready to install when winter arrives. How do you like the ride, gas mileage, etc. of the tires so far?
Regarding the sensors - Tire store wanted to sell me a so-called rebuild kit with some sort of gaskets and other stuff they sell. My mechanic told me to have them install stainless steel valve stems like "olden day" cars and forget about these stupid sensors all together. Reason for sensors are for those folks who DO NOT take a tire pressure reading periodically and is nothing more than a nuisance to those who do when fueling vehicle or when your trusty oil change guy checks the pressure for you. Anyone who spends a bunch of CASH on tires should have enough gusto to check pressure on regular basis anyhow. I do, especially during temperature changes in my area. Thus, I will be omitting the sensors and installing stainless steel valve stems to prevent against corrosion in salty roads in winter around here. Let me know how you like the Goodyears so far....
I used to do a lot of surf fishing and own a digital pressure gauge and a fairly expensive one with an 11" flexible hose. When you need to be at 10 or 15 psi to drive on the beach you get good at putting air back in. I completely wore out an '86 Subaru wagon surf fishing the Outer Banks. It took 14 years, but rust finally ate the front sub-frame.
Ideas?
Quiet running tires on dry pavement - hold the road good on wet pavement - and track thru the snow good. Only complaint is gas mileage I am getting with theses tire. Past mpg was 18-19 city driving -- 21-22 on expressway-toll roads. Has fallen to 16.5 in city and can only achieve 20 mpg. MAX on long road trips. Don't know what to say about that aspect.
Even though tires were a bit expensive, I did get a Goodyear rebate of $80.00 on a set of 4 when purchased. Other than decreased fuel mpg. I've been happy with the set of 4 put on my Highlander 08 (4WD) LTD. 19 inch wheels.
So, it probably boils down to: If you plan to KEEP vehicle for awhile, why not put a GOOD set of tires between YOU and the Road. If not keeping vehicle and plan to trade/sell, then go with cheaper options.
Mine has been running very good with no complaints. I see Highlander did get very good reports as vehicle of the Year for 2013, so it all can't be that bad... right?
Jack
Sorry, but that is the situation and there's no getting around it. The only thing you can do is buy tires that have high treadwear ratings and warranties, but tires are never going to get the mileages that other parts of the country experience.
2010 Highlander Limited
2012 Tundra TRD
The reason I always look at the actual survey results is that I don't necessarily weigh the results the same way Tire Rack does when calculating what order to put them in.
