Pontiac Grand Prix Starting / Stalling Issues
mylilpontiac
Member Posts: 1
Okay so whats new with my little pontiac? Ever since i've got the thing ive had nothing but PROBLEMS. 2002 gt 85,000 miles...recently when i would try to start my car i would hear a loud clicking noise like my battery was dead.it would take me a few trys but eventually it would start. so i bought a new battery (it was 4 years old anyways) that made the problem go away until about a week ago it started again. now this time i know its not the battery. we tested it and it is fully charged. it wont take a jump. it wont do anything!! all i hear is a loud clicking noise. im not sure what it could be! i do not want to replace the starter if it could be something smaller.. any ideas?
Also i got a anti theft alarm installed. someone told me that if its faulty it could cause a problem starting the car.. i need help! my only car and i need to be to work on monday!!!
See also: (Video, 2:18) 1997-2001 Grand Prix GTP Stalling Fixed
I have 89 grand prix. Problem started when car felt like losing power and car smoking and pulled over and smoke coming from engine. found hole in raditor fixed with jb weld and flushed the system out. car will not turn over. what are we missing.
wallie
Bought in 1999 for a grip of cash. 3 Weeks after I. Got it, it started to die for no reason at all. I would wait for a few min and it would start. Had someone with me when it did it, so popped hood checked for spark NOPE! Check for Fuel Yep! so the is an issue with ignition system. Then it would start wile I was searching for problem. Run for a week or so then start it stalling crap again. Off to dealer it went $$$$ later no problem found new dealer $$$$ later no problem. this took me to PEP Boys where they Changed CSP Crankshaft position sensor mega $$$ Week later it's towed back in to PEP Boys under warranty new CSP and Module $$$ 8 weeks later towed back to PEP Boys for CSP MOD and 3 new coils. 2 yes 2 FN hours it died back to PEP Boys "Why well under warranty and cheaper than dealer"
Was told when 1 part fails it takes down many OK Now new ECU CSP coils module plugs wires oil filters water temp oil sensor and a battery. [non-permissible content removed] did I get a new Car. Warp to 2007 I have put 1200 miles on the car since then It sits till I get home Over the road truck driver
so it gets little use, But hey it runs with a battery minder on it, it has not let me down for 5 years. So I trade the hoe in on a new 2006 GP 3.8 SIII that has absolutely no guts at all.
Well, the 06 has to back for warranty work on brakes, Damn thing. They did a lot of recall work on it as well. Well, I am now an in town truck driver so need a car. What do I see? My old hoe right there, There going to scarp her out for parts. Why she looks brand new 67K on her and I loved her. What an [non-permissible content removed] I was to sell her. So I buy the hoe back and will park the 06 for you know good dates and what knots. Bad idea the hoe has started her crap again. Now I dive the 06 to work white out side white parchment inside am get her messed up so I have to fix the 97 soon 2 car payments and a truck payment too. Don't ask yes semi truck $567 a week ouch. Oh and I failed to tell you I'm an ASE certified master mechanic with 190K of tools and I hate to work on cars LOL.
The GM Repair shop can never duplicate it.
Recently an 02 sensor in the manifold make the engine light come on. When the 02 sensor was changed the new one was defective and shut down nearly all the gas right after I left the shop, I made it back to the shop on very little power.
I'm still not sure if there are more problems with the engine or not.
I have always liked Pontiac until this one.
I do have a new question and it pulls up every time I look for parts. Camshaft Position sensor. I can find one on the car and the part locator can not tell me where it is.
Does the 3.8 S II have one?? Oh on another note I will be paying the Hoe off soon and parting her out.
I was wondering if you had discovered what the problem is with your grand prix.I have a 97, grand prix and mine is doing the same thing.I noticed if I drive in 3rd it does not stall while I am driving anymore.. Also, when I was driving it had like jerkyness to it and the mph meter jumps all over the place...Mostly in Drive!
I imported a 1998 Pontiac Grand Prix to the UK as the begining of the year, had no problems until recently.
The car starts, however as soon as it is running it starts too stall and sucks in load of air, blows back through the exhaust and dies, very odd, fuel is fine!!
Anyone have any ideas?
I have a 2001 Pontiac Grand Prix and it has insane problems. The Service Engine Soon light came on a few days ago and has yet to turn off. Also I get the Tac dropping to 0 and then about 5-10 seconds later the Traction Control turns off. Also when the car is cold it seems and if I am going around corners or up a hill the car will stall and sometimes it will start right away and other times it takes 5-10 minutes for the car to start. Any ideas? The car has regular oil changes and when I bought the car (summer 2004) I had the thermostat fixed and later on (mid 2005) the servies engine soon light was on forever and it turned out I needed a new Catalytic Converter and a tune up. :mad: :mad: :mad:
I used to be able to put in nuetral & it would restart and I would put into drive and keep going. It wouldn't happen for weeks then it would get worse, then stop and start again. Now when it stalls it won't start for a good 20 minutes, too dangerous to drive, My mechanic has had it 5 times over the past 6 weeks. He said there's nothing wrong with it.My husband thinks it might be the crank shaft sensor.
I also have problems with the heater only working on 5. I did find the threads regarding the blower motor assembly & the ignition wires. Any feedback on the stalling issues would be greatly appreciated!!! :confuse: :lemon: ">
I have a 2004 Grand Prix and I'm having similar problems. How much did it cost to fix the thermostat and a new catalytic converter?
None are cheap.
Stalling and not start up right away, But will after a few minutes?
Oh it will only get worse. It will soon take up to hour before re start!
Dealer even pontiac will fine no issues.
It will subside in cold weather to a point.
Answer.......... Crank Shaft Position Sensor Is Getting heat soaked.
And slowly diying.
Heat soak send bad or no info to Modual under coils Thus Over heating it
And it goes out as well. Random misfire. Lean bank 1 Will show
just b4 it all dies. When it does die for last time is sends mass of High voltage
spark form coils Back thru system to ECU and Camshaft position sensor.
[non-permissible content removed] [non-permissible content removed] [non-permissible content removed].
Well pontiac Admit to this NO!!
Where did I get INFO Had Car On dyno 3/4 throtle for 2 hr 45 min with Sun Diagnostic Hooked to all the above Parts, and more when it all gave loose.
No I did not hut motor. New Checker auto parts a Cool 1K and all is good
Oh dynoed it again to See CSPS at 140 degrees and climming to 273
after 1 hour. Where the hell is is getting it from.
Serp belt is getting hot from who knows where?
FIX? Replace CSPS ASAP with what? Dealer delco part.
Make sure the lower chin on bumper and air flow to lower engine is good
I could see some one getting some duct work down there.
Then Sell the hoe!! lol
We took it into a decent local shop, but they told me it hasn't thrown any codes. They said it could be the crankshaft sensor, ignition module, or fuel pump. They don't want to just start replacing parts as each repair can be costly with the fuel pump being the most expensive. We were hoping that it would start failing more often, especially when they had it (it always started for them) as they can't really do much as long as it always starts for them. We thought the car problems were consistent (always starts when when cold, sometimes won't start when warm, but will eventually start when engine gets cold), but it threw us a curve the other day when the engine stalled while my wife was turning into our development. Luckily, she was able to coast it a half mile to our driveway. Again, after it cooled, it started.
I have heard that a bad battery or one that will soon fail (or one that is defective) can possibly cause this (the battery in the car is 4 years old), so I might take it to a shop and have them check it and maybe replace it anyway as this would be the cheapest fix that I can do myself.
Has anyone had this problem w/the 3800 V6? Any advice? I'm hoping that if the battery doesn't do it, the car will start failing so the shop can fix the problem.
The engine has just begun to stall without any warning, no hesitation. Sometimes it will restart initally, other times multiple tries are needed. 2 out of 16 times the "Check Engine Light" has come on but soon went out. I did notice that when I can restart it and while parked, it will only rpm to 4K. At 4K with constant pressure on the accelerator, the rpm's stop at 4K and the engine / rpm's act as if my 10 year old is quickly, repeatidly gunning the accelerator.
Ideas? :confuse:
My question is, is there a shutoff switch by the manufacturer in the event of a roll over or high speed accident that will disable the car?
Please help.... Thanks!
Walt
Now this past weekend, when I decelerate to come to a stop it feels like it jerks a little when the transmission switches to its lowest gear (thats the best way I can describe it), and sometimes the "service engine soon" light comes on but usually just briefly until I accelerate again and then it goes away. Sometimes when I am idling the engine sounds like it is about to cut out, almost like it is sputtering along, but this goes away when I hit the gas pedal. at times, when it is idling, the service engine light comes on. When it is doing this the car definitely gets louder (with the sputtering..). I'd really appreciate suggestions and more information about what the possible problem could be. Also, since the car is 20 years old, I'd like to get a best guess on how much the repairs might be for this. Obviously I don't want to spend to much $$ on this car. Its done this a few times before in the past (usually every couple of months or so) but it has usually gone away when I added a half pint or so of engine oil. But this time it doesn't seem to be working.
of them.
Gearr
Thanks again!
Walt
Great engineering by GM!
Any help would be greatly appreciated.
Ron
I disconnected the battery, charged it up and reconnected it. Dash lit up again, but then one click and everything electric turned off and key is stuck again.
Then tried to jump it, same result. Anyone know what could be wrong?
revving very high. I'm not fond of starting the car like this, because it obviously should not work this way. Been taken to the GM dealer few times, but it starts fine for them. (Obviously) Wondering if you ever found out what was wrong with yours?
bleukrayons@yahoo.com
Thanks :confuse:
Stalling issue is CSP Crank shaft position sensor. Period. that is your problem.
If the engine is not running and the CSP is not sending info the ecm Has no way of setting a code. No info no injector pluse ect. the only thing that will run is fuel pump. This is a rare problem fuel pump failing? The CSP is the problem.
DO NOT Replace with off shelf parts store replacement/ they are cheap repo of a good AC DELCO part. Heat Soak is the issue here where it comes from is diffrent for all. Lower chin spoiler bad missing{curb checked} obstruction in the cooling chin/ bent warped ect. Correction 4" dryer duct from front chin to CSP. AC DELCO CSP only!! ok in park 4k rpm? the engine has a saftey rev limmiter that cuts fuel/spark thus over heating CSP as well. Rad Fans not running so it heat soaks wile not moving.
Over rev to rev limmiter after start is a bad O2 Sensor /Cat/MAP sensor's they are trickey to find the correct one, start by un hooking each 1 at a time till issue goes away and that is your problem.
Old oil will heat up faster than new. Dirty air filter will choke motor heating it up as well. This motor is MAP not MAF so it has no idea it is being choked. You will get cyl missfire bank 1 or lean miss bank 1. to over come it will run engine out to 4k hit rev limmiter to heat up cat and O2 to clear problem.GM's idea of self protection.
ECM reflash is bad idea it adds more peservation codes, ment to keep engine up to date and clean running. air leak in map is caused by age hot cold ect. there is also the vacume line that may rub thru.
Just My 2 cents
This is easy the cat is no longer working correctly and the O2 is bad as well.
Exhaust is backing up cat is pluged. O2 is allowing excess fuel not reading right showing lean condition thus extra fuel killing cat.
Unless it is a series III it will be the Cranshaft position sensor Period.
It will not set a code.
The engine must be running for any code to set.
Since the engine is stalling no start Cranking over ect.
There is no referance for the engine to accept that it is in start run.
No signal is being sent there for the ecu ecm cpu what ever you want to call it
feels you are but sitting with key on not running.
Get an AC DELCO Only part. The off shelf parts at local parts store
Are pure junk. They will work But will!!! fail in less than 5k miles.
Why is the CPS failing? Heat soak getting hot and slowly deing. The AC DELCO will fail as well but it is of better quality. 20 to 30K easy.
Good luck
