Anyways, even though these are GM cars a lot of stuff is computer driven - for example the gas pedal is a fly-by-wire system which explains why I loose gas when the computer crashes. The firmware update is a dealer task. I doubt that the average mechanic would be able to get their hands on the software unless they are paying for a high-end service catalog but the battery cable looks easy enough and I'm hoping that solves the issue. Firmware updates can be risky there is a 50% chance they can toast the computer module. There are some very good mechanics at some GM dealerships but most of these are knuckle draggers. I wish I could do it myself - at least I would know what I was doing.
I'm going to the dealer to pick-up some parts I'll ask what is involved and will get back here next week. Less ambiguity. I don't really expect this to solve the starting/ stalling problem - just the stalling at highways speeds.
However, while writing this email I did think of something, there is no throttle cable but there must be something throttling the engine. I would imagine there would be build-up and wear on this component. If this sticks it would idle the engine roughly and too high at times or stall the engine by not giving it enough gas. Just a thought, I'll have a look at mine.
My car has 121,000km's on it my so they replaced cat converter for free, the PCM is also covered. So if anyone else is having similar difficulties ask your dealer about this. FOr my car its covered until 130 or april of 2012.
Of course,I pulled out of their lot...and stalled! Is there any info from GM or through any less opinionated mechanics that can help me?
I love my car and she only has 118,000 miles. I take excellent care of her but when you open the hood it looks nothing like my 1970 Cutlass w/ 350 Rocket. I Know being female with a dead car is a total disadvantage but since so many others have had and are having this problem SOMEONE has to be able to help.
-Scan tool shows 2 PCMs when there is only 1
-Updating the software crashes computer x2 on 3rd attempt it took update.
- Crankshaft position sensor shows a difference of only a few RPMS then in a second Shows a difference of 1000RPM (crankshaft position sensor is new|).
My guess bad PCM or Crankshaft sensor?????
Techs have never come across this before.
2005 pontiac grand prix 3800v6 no bells or whistles
johnarenburg@live.ca
The other issue has been the key stuck in the ignition. Not always, rather randomly. Have replaced the key and the tumblers in the ignition. Helped for about two weeks. Again, any help would be appreciated.
We also have a knocking coming from the supercharger. A mechanic said it will eventually need to be replaced and may be causing the problems but cant be sure. The car has awesome power and runs great except when under 25mph.
I am in dire need of some help! Cant keep dumping money into this car forever! Starting to get to be more than its worth.
Also the driver information center is very very dim, can not read it unless the sun is shining directly on it. Have any ideas? Can definitely live with it but just figured id mention it!
Anyways Thank you for any help!!!
get in turn the key all i get is a clicking noise (very fast 30 times in 30 sec's) resets clock, date etc... and display says charging system failure, sum times the horn will even go off in the process... sumtimes it will start but still reset the system ... dealer says cant find problem... im now less then 10,000 kms away from b-b warr off the car they say they will " fix " after but i dont trust them....
anyone with same problem? possiable fixes to problem?? anyhelp is a place to start
I sat in the driveway this morning for 25 minutes cranking away.
Then suddenly and unaccountably: perfect start!
I'll be on the road driving along and the engine will die. No fluttering before hand (although I've noticed the flutter while pressing uphill). Just sudden death.
I've learned a great deal about maneuvering a dead car off the road, but would prefer some fellow owner advice before taking the car to the mechanic.
I've been dealing with a stalling/starting issue for about a month. 2002 Grand Prix, 3.8 liter. The car initially stalled while driving. The tack dropped to zero, i lost power steering, had to pull over. The car started fine and I was able to drive it home. The car started fine and drove over to the mechanic no problem. He replaced a vacuum sensor somewhere, the crank sensor, a cam sensor, a throttle sensor, and checked all the wires to make sure they weren't shorting out. The codes indicated it was a CAS but that's been replaced twice, still stalling out. This car is like Jekyl and Hide, I can't point to a single behavior which makes it stall. Sometimes it will start, sometimes it won't. He seems to think the computer (PCM?) needs to be replaced. Could it be the MAF like other people have suggested, or the fuel pump regulator?
I bought my car memorial day, my first car so im still learning things about them as i go along. Sometimes it doesnt start, i have to step on the gas while turning the key to get it to start.
Lately, it has been studdering when im stepping on the gas. I was driving on my way home from work today and my car was studdering then eventaully stalled out. No matter if i floored it or if i stepped on it , the car would not accelerate and in which caused it to stall out. After it stalled i tried starting it, however it would crank over but never actually ever start. Till like 20 minutes later when god finnaly cut me a breake and let it start and i was able to drive home with it like nothing happened.
My friend also believes that i am getting a fuel cut when i start my car he made me rev my engine and said it sounded like i was getting a fuel cut
PLEASE SOMEONE HELP ME. I would be extremely greatful, this is my first car and i cannot afford to get another one.
thank you very much guys.
My 1999 Grand Prix has been acting up with all the same symptoms many people described. Engine cut out at highway or low speed; hard to start after a hot shut down; the Trac light stayed on after the engine cut out and immediate restart in neutral etc. It was getting worse lately with the hot weather. I contemplated replacing the crank position sensor, mass air flow sensor, PCM one at a time, and hundreds of $ at a time, like many people before me. Then, I found the way to fix my problem at ZERO DOLLAR!
I figured that it could be a voltage problem. I used a multi-meter. I measured the voltage across my battery, which show the normal 12.7 V. But from the positive terminal junction to a good ground on the engine (e.g. Al engine mount) the voltage has dropped down. I also measure the conductivity as well, and I did not get zero Ohm between the negative terminal to the good ground spot on the engine. I removed the grounding cable attached to the body panel and found that it was bolted on to a part with original body paint! What a bad design! Paint is not the best conductor in the world! After years of dirt and rust build-up, the conduction between the bolt threads won't be as good as before. So you get intermittent voltage drops that stalled the engine. I gave the contact a good rubbing with sand paper. I check voltage and conductivity after and it was good as you would expect. Since than, I never had a single staling. It has been three weeks with lots of kilometers in hot weather.
I trust that the same remedy will solve a lot of your problems. I apologize to many garages for reducing tens of thousands of dollars of their potential business.
I have a 2005 GP base model - I had similar issues. My engine did not die at hwy speeds BUT the computer would crash leaving me to fly a dead elephant down the hwy with no gas or instruments. There is a secret GM TSB I pasted it a while back for Chev, Pontiac and Buick cars running on the Impala platform. The first recommendation is to check the ground strap and the second procedure is to flash the PCM's with a firmware update (not your naked body - although you can try this for kicks). I did what you did and cleaned off the strap and have had no issues apart from a rough start after a hard drive which is likely an oxy sensor on its way out or a filter. Good on yah dude - that's a good fix. Sorry you had to spend so much money - but it sure feels good when you stop!
I have recently bought a 1998 Pontiac Grand Prix SE 3.1 for $600.
When I purchased it, it had the Low Coolant light on, and check engine light on.
I knew right off the go what the coolant light was. Damage to the intake manifold gasket due to the DexCool that was in the cooling system. I had that replaced. The Low Coolant light is still blinking, I'm thinking it is a bad sensor because I had also just replaced the radiator cap and upper hose, no further leaks are found in a pressure test. Oil was changed when intake was replaced as to get out all the coolant/water from the engine oil. This is not my main problem.
The main problem is the car has a somewhat of a rough idle. More now than before.When you start the car (It starts fine by the way) the RPMs fluctuate from 500 RPM - 1000 RPM. It doesn't die out, but sounds sluggish. It is fine while moving, and when it slows back down to idle, it fluctuates only minorly.
The Check Engine light I am getting is for a Camshaft Positioning Sensor.
I know where it is, and how to change it. But, would this be the reason of why it is acting so strangely?
I had my 2002 grand prix at a local mechanic with stalling issues. Sometimes it would start, and stalls near idle, but has also stalled while driving. He initially fixed some vacuum seal and that didn't do the trick. He replaced the crankshaft position sensor and that didn't work either. I took it to a dealership where they put in a new PCM and ignition control module, not a damn thing. The service engine light just came on (after all of this work) and it's reading P0300, multiple random misfires, and i have no idea what the problem is. It will start and run beautifully sometimes, other times it takes multiple attempts to stay running (will turn over, quickly die), and often it will run very rough and will "rev" for no reason. Anyone!?
However, I'll also say: The guys at the garage NEVER had a problem with the car.
For them, it always ran great.
For me, it often refused to start or just died in the middle of traffic.
The car runs fine now, but I feel some loss in power -- as if the V6 has gone down to a fully functioning 4-cylinder.
thank you for your response. I did indeed try that fix. I used a wire brush to clean up the terminal, the screw, and the frame of the car where they all bolt together. I was initially encouraged because my car started quicker than I'm accustomed to, however it faded within minutes as the car stalled while idling. I spoke with the dealer again today who had been working on it. They test drove it last week with an Ignition Control Module (factory) from a spare engine they had in the shop and they said it never gave them a single problem. After installing my aftermarket part ("standard" brand) it didn't give me any problems after 3 short trips but sure enough, it stalled out again. This is the first time the CEL came on too, code P0300 (random multiple misfires), and the engine was oddly "revving" after a cold start, it would run rough too. They're going to put their ICM back in and let me test drive it for a few days, assuming it doesn't give them any problems. I'll keep my fingers crossed.
Too bad that what you did to the grounding cable did not fix your problem, My '99 Grand Prix GT was stalling up to 3 times per day until I cleaned and removed the paint from the grounding point. The stalling stopped immediately and I have driven over 8000 km (5000 miles) in one month since then (I have to drive into Detroit almost everyday for the past 4 weeks and desperately needed to have that problem fixed). Since I did not spend a penny on the fix, I bought an OBD-II analyser (on sale) with the money I saved so that I don't have to run to my friends to check for error or pending codes. By-the-way, there were never any codes tripped after the stalls.
The key to see whether your grounding cable is a problem or whether you have fixed it properly, if it is, is to use a multi-meter to check for voltage drop or resistance that should not be there. A consummer grade digital multi-meter costs about $25. It is worth getting if you don't have one or can borrow one easily. You should confirm the engine, therefore all components such as PCM, sensors, etc. are seeing the full battery voltage. The unwanted resistance may be in a different part of the circuit. A multi-meter has many other usages too. Good luck!
