Visitor Agreement.
Totaly lost please help!!!
any help would be much appreciated.
my car is doing the same thing. Have you got yours fixed yet and if so what was the problem?
Sheldon
On cold start it starts fine but after driving for a while and letting it sit, the vehicle won't start unless i give it some gas. Could it be the fuel pressure regulator?
Brad
Bonnie & Sheldon
The 2nd issue is a major hesitation problem which is ALSO intermittent. I will stomp on the gas and even though it still accelerates, it feels like it hesitates and almost sputters. It's strong enough to actually "feel it" when it happens BUT yet there are times when I stomp on the gas and the car accelerates just fine. It's kind of scary when your passing someone because it doesn't feel like the power is there that should be.
Thank you for taking the time to read this and even replying to this post if you have any answers. I can clarify both issues with more detail if necessary.
Thank you again...
Please any suggestion will be greatly appreciated.
Note..GM discourages use of K&N filters for this reason, unless you very lightly oil the filter. And cleaning the Thottle plates and throttle body at least once a year.
I have had my car to the dealership & of course it did not die on them.....when they connect my car up to the computer it throws back no codes.....My car dies with out warning sitting at an idle or going 55 mph......any ideas what is the cause? So far my car always starts back up after waiting a minute or so....
Any ideas? If I figure out something, I will reply to your post & let you know as well!
My 98 Grand Prix (145k miles) failed to start, happened with no warning, in between errands. The engine would start but immediately die. Giving it a little gas to keep it going sounded like it was running on half the cylinders. Had to have it towed to a local repair shop (had been there twice before over the years when the battery went dead out of the blue). The shop called today and said it was a bad Air Flow Meter, $350 part !! I browsed the forums but no mention of an Air Flow Meter. (may be called something else?) Does anyone know what that part is? Sound familier?
Coincedently two weeks ago I had the car in the shop (dealorship, not the same place it is now) for routine maintence and state inspection, that incuded replacing the air filter. Is this AFM located in the area of the air filter?
Appreciate knowing if replacing the part will fix the problem or could it be something else that will pop up "out of the blue" again?
Best Regards and GOOD LUCK with your Pontiac!
Oh yeah....when I turned my defroster on the fm signal would go out and when I made a left turn the car would make a weird noise each time...as if something was going to break in pieces.
Being an ASE master mechanic 4 12 years and then moving on to other job " I hate hate cars" After doing it for so long you just can't do it any more.
Your CSP "crankshaft position sensor" is located behind the Lowest pully and Is the largest one on the crank shaft. To pull this pullt you will need a special puller that will cost you $150 or so most parts stores do not have the right 1 to rent. Good luck finding the right 1. Best bet a stearing wheel puller but you will need to buy very long very small boltz that will go thru the puller and all the way back the the threded area of the balancer. they ar I thin 4" and 10mm head so small stuff.
The center of the puller is to short so you will need to use a spacer 1/2 inch deep socket 3/8 drive. When threding in the puller go slow and don't use an impact wrench those little 10mm boltz will pop and now you have a new problem. GUILTY Yes I did the impact thing once"once" the I had to fab up some offset boltz when turned 1/4 turn they are bigger and lock in place in the balancer. Ugly idea but it worked and was lucky not to tear the rubber balancer apart. All this can and will just piss you off. Break out the BFH a knife cut of the balancer $250 ouch and pull the old fasion way. Bad Idea. Oh the dealer will not sell you a puller, Snap on has no clue Mac Matco Cornwell There all lost too. Good luck.
