Jeep Grand Cherokee Transmission Problems
I have a 1998 JGC with Quadra Trak. When cold, I can be driving down the road, pushing down on the gas pedal when suddenly I'm coasting, the engine will rev when I push down on the gas but the transmission won't engage. I have to continue pushing on the gas pedal and letting off until finally it will engage and away I go. Anyone have any ideas of what this could be. It did it last winter and again this winter but never had a problem in the warm weather.
See Also: Jeep Grand Cherokee Transmission Troubleshooting (Cold Weather and other shifting problems)
When I went to move the jeep I found the throttle sticky. I had difficulty freeing it up when suddenly it was free.
I fix the brakes. When I went out on the road to test the brakes I found that it wouldnt upshift unless the RPMs really were high.
I can select individual gears both forward and reverse, there are no noises.
The upshift cable is connected on the top of engine. I can pull on it and seems really easy to move.
I thought it might have disconnected itself underneath but the cable disappears into the transmission. I pull on it and hits a stop. Is it possible that it came off inside the tranny. Will removing the tranny oilpan expose it for insepction?
cheers
Jeep Grand Cherokee TCC Solenoid
buy a toy and you will be happy??????
THANKS
http://www-odi.nhtsa.dot.gov/cars/problems/tsb/tsbsearch.cfm
If the final analysis is I'm missing high gear; can I drop the pan trouble shoot the problem and have some reasonable chance of fixing it? Should I try changing the fluid again?
What are the most probably candidates, that can be reached without pulling the trans? Could the torque convertor be causing this. It probably still has a fair amount of dirt in it. Can it be flushed without pulling the tranny? :confuse:
Also, there is a clicking noise in the steering column when turning right or left, regardless of whether the blinker is engaged. Is anyone else experiencing this?
This is so frustrating. This is my third Jeep in 6 years, but my 2000 Cherokke and 2002 Grand Cherokee did not have these sort of problems even well after the warrantly ran out!
Help! :mad:
As soon as I got it started again (after sitting in the middle of the intersection for @ 30 seconds with oncoming traffic) I went straight to the dealership. I told them that I refused to drive it home and that I was leaving it there until it was fixed. They called today with no results, so I told them to keep it again and try tomorrow.
I mean seriously, I almost caused an accident! I am going to the top with this one. I guess they are waiting for someone to get injured or killed before they do anything. This is insane!
They told me the same thing about it is normal for the transmission to slip the first time I complained. Well what the heck do you do when your car dies in the center of the intersection and the light has changed for oncoming traffic? I guess you do like I did & frantically try to start it & hope no one T-bones you!
:lemon:
Please keep me informed.
Has anyone else had these problems? Does it sould like two seperate problems or are they related? Is it the transmission? Does it sound like a transfer case problem? What the heck is a transfer case? Help!
From what I understand, this transmission is an old design, like the 4.0 litre engine. In fact, up until 99, the trans required tightening of the bands(see Haynes). I THINK that the extra material in the pan is related to the design on the design of friction surfaces.
The moral of the story, try the fluid and filter change before you spend another buck. I think it'll do more than all of the rest of the work you've done. Also, don't rely on the 100k service interval on the transmission. Change the fluid and filter at 30k and no more.
PS A Durango with the same issue and trans went to the same wrench. They did the fluid and filter and the issue resolved itself. The Durango had 180k miles on it.
Btw, I have run into some intermittent problems over the past 3-4 years when shifting from 4WD back to 2WD, even though I have only used 4WD occassionally, only about once a year. I like to keep it in 2WD drive unless there is snow on the road, then I use 4WD. Occassionally, after shifting back into 2WD, I can hear a whirling sound coming from the front and the front jerk intermittently while turning. This lasts until it finally disengages from 4WD back to 2WD. Each time this happened I re-read the manual to make I had shifted correctly, and each time I reread where it says that it is ok to shift at any speed. The last time this happened it didn't stop the whirling sound and jerking until I heard a big "bang" sound, and then it was ok. So, I drove it to a trans mechanic and he drove it and told me there is probably a problem with a vacuum canister in the front. I also called (today) a radio show about car repair and the host (pat goss) told me I should have it checked out because the front transaxal can be damaged in just a few seconds. The Selectrac trans is part mechanical, electical, vacuum, and part computer run. I mention all of this so that you will know what to do if you ever have these problems.
would be nice if you told us the engine type tran type etc
However, after reading all the transmission complaints about the 2005 & 2006 models, I am beginning to get nervous.
Did Jeep make and changes to the transmission in the 2007 model?
In conclusion, if you own the 2005 and newer GJC with the 4.7 Liter engine (a sweet engine) with the 5 speed transmission...... GET RID OF IT!!!! If you are thinking about getting one.... DON'T!!!
Awhile later I noticed engine reving from 2000-3000 rev's, cruising 65 or so. More throttle = 2000 rpm. In and out of O/D? Only seems to be happening at a very light throttle. Seems I remember shifting manually into 3rd, (a day or two later 35mph or so, same symptom?), different speeds, diff. rev's., (Possibly It may've been an erratic, or unusual shift point), just can't say for sure. I tend to pull shift lever back 'til it stops, i.e. "D", not sure what happens w/selector in third. Anyway... Couple weeks ago new tires. Got onto the freeway, thought U-joint had suddenly gone. Too fast a vibration for tires. Reading about t/converter lock-up etc. Maybe the two are related. Regardless, anyone out there got any ideas? 230 k on the odometer. I can't lock the driver's door and windows are sometimes too slow, but as I said, "I Love my Jeep", I only need for it to keep up w/me. Cheers
Obviously ATF contaminated coolant thru the cooling system.
Question: How concerned should I be that my new transmission, if they balk at replacing it, has a problem with contaminated ATF, (clutches, seales, etc.), and should I insist on changing the transmission...under warrantee.
kmitch
GD
