Thanks again!
Ang
Thanks for your help!
Ang
28,000 - Aztek wouldn't reverse, transmission replaced
69,000 - Aztek chugs in reverse, EXACT SAME DAMN transmission problem
Yes sir, I'm looking at my THIRD GM transmission in 70,000 miles. I've dropped so much money into this vehicle that at this point it doesn't make any sense for me not to fix it, or to trade it in. At 55,000 miles, injector coils had to be replaced, prior to that at 37,000 miles (just out of warranty) $900 a/c repair, prior to that, at least 5 computer replacements in warranty, numerous other minor recall and other repairs.
Its a great car, pity the quality has turned it into a lemon!!! :lemon:
I have a 2001 Pontiac Aztek with 69,000 miles on it. The transmission was replaced at 28,000 miles, and now the exact same problem is occuring again at 69,000 miles. So far I have found 8 other 2001 Pontiac Aztek owners with the exact same problem, and I've read at least 4 or 5 other people on-line with these problems, some scarey enough within a few miles of both of my transmission problems.
If you have/had a tranmission problem with a 2001 Pontiac Aztek (or later model) please contact me and reply to this post.
Both transmission problems had the same symptoms:
a) Aztek fails to reverse or "chugs / shakes" while in reverse
b) Aztek lacks power on hills
c) Aztek goes from 45 mph to 60 mph in about a minute (floored)
d) With the air off, radio off you'll hear a "wind / howling" noise
from the engine.
You know you have this problem after the dealership / mechanic takes the transmission pan off it'll be full of metal shavings. If its not, and there is no noise, have the mechanics run the car with it propped up in the air, after a few minutes it should be apparant.
Some things to catch it early:
a) You notice a loss of power (might be slight) while travelling 50mph or faster.
b) Aztek doesn't shift smoothly between Park and Reverse
Right now, I'm looking at a third transmission for this 2001 Aztek of mine. I don't trust GM, they seem to be aware there is a problem, they tried to "talk" the dealership into paying for most or doing the repair for free (at the dealerships cost). The dealership, who acknowledge that I've taken it in there every 3000 miles, done all the maintenance on time, and its only seen GM dealers are pushing this as a GM problem.
So to get to the bottom of it, I'm taking the thing to a local transmission expert to see if they can figure out whats wrong with the transmission, if it can be repaired or rebuilt, so hopefully I'll get to the bottom of this soon enough.
Robert
As a side note, my driver's side curtain impact bag went off when I shut the door the other day..now it was cold (in the negative teens) but there was no impact! Calling Pontiac to figure out what to do about this but any info in the meantime would be appreciated.
:confuse:
Looking back, here are my lessons learned:
1. Get the warranty. If you can't get full coverage, atleast extend the powertrain coverage. I gambled and lost.
2. Watch out for the puddles. I never had any water enter the car, but the body harness was definitely exposed to moisture. I took mine thru a major ditch at the beach, and I'm pretty sure this is how the water got there.
3. If you tow anything, service the transmission often (20k-30k). I have no official proof, but I suspect this was a contributor to the transmission failure. What's funny is that I had just made the appointment to service the transmission when the tranny went.
When this car worked it was functional and a good ride. I do not believe I abused this car, and all service checks and maintenance were up to date when it failed. I'm getting the car fixed, and plan on using this car to commute to the commuter train lot 2 miles each way. I have owned Hondas, Subarus, and an Acura, and never had any problems even close to this with my cars (and I am sure that I treated them much worse). This is my own experience, and for me that's enough. Sorry, but this will be the last GM product I will buy.
How much should I pay for 1 of these things? Edmunds TMV would seem that my offer is a good deal, but I'm also seeing people that have bought 2005s for around 15k.
I think I would definately want to get an extended warranty from warrantydirect.com, but that would set me back another $2500 (with $0 deduct and the added emissions protection).
That being said, I can still get a better deal on one of these than an older Odyessy. Would I be better off looking into a Venture or Caravan? I just need something bigger than a car, and the AWD aspect makes the Aztek appealing.
Is this car something to consider, or should I run away?
I would be ever so grateful!!!!
1. the trunk won't open all the time only when it wants to.
2. The gas gauge goes to full then to empty all the time.
3. The temp guage goes to hot and stays there until i shut the car off. now the temp guage does not work at all
4. If it is below 40 Degrees none of the inside lights, radio, windows, seats work until the temp warms up to above 40
5. The headlights wont come on until you put it into gear until then they will come on for a sec and go back off.
