The BCM is located in console area (next to or just in front of shifter I believe). Replacement shouldn't be to difficult but it has to be programmed by dealer and I'm not sure if it would even start if not programmed. As always when working with electrical stuff you would want to disconnect battery if you decide to try messing around with it.
Dave R.
The manual says the typical cause for needing to use the override is low or dead battery. Everything else on the car is working fine. Has anyone seen this issue before and know of any other causes??
Gary.
Ok I did some checking, there is an issues with some 2003 and 2004 Teks with shift interlock troubles that are corrected with new BCM (new updated version) BTW part of the doc mentions if you turn vehicle off, then restart problem usually goes away (in this instance). There could be a number of things that cause the trouble in general, but one other fix I saw was re-wiring to the switch due to corrosion. I'll see if I can find other stuff.
Its a 2001 with 119,000 miles. The battery was replaced last year.
-Gary.
netnerd, "2002 Buick Rendezvous Class Action?" #7, 18 Apr 2006 12:01 pm
-Gary.
Thanx again
1) put your key in and turn the vehicle into the on position, don't start it
2) FULLY (meaning as far down as it goes) press and release FULLY (let it go all the way up) the gas pedal 3 times in 5 second
3) Turn the key to the off position
It may take you a few (or many) tries to get timing down jut right to get it to turn off.
Thanks (my email is in my Profile - click on my user name to get to the Profile).
Thanks again and by the way "Love my Aztek"
Here they are:
1. Insert an existing key into the ignition cylinder.
2. Turn the ignition cylinder to ON (run) and back to OFF.
3. Remove the existing key and, within 15 seconds, insert the new key and turn it to ON (run).
4. The security light will light up for 2 seconds to indicate success in programming the key into the vehicle.
I had a 1988 Bronco (in 1994), which was great, but not nearly as versatile or comfortable as the Aztek, and a 1998 GMC Sierra (new) amongst several other vehicles, and this is the nicest ride yet.
The passenger side carpet is soaked but no visible drip.
thanks.
