In other words is the factory keyless entry system some module and parts that could be gotten from a junkyard Aztek or is there more to it. Like it interfaces with the computer or anti theft system and can't be done. I really have no interest in getting an aftermarket system but it is tiresome to lock and unlock the car without the keyless entry.
I suspect the Body Control Module but I don't want to spend the money to find out it's something else. Does anyone know what module controls these functions?
Thanks for your help.
Gas gauge ,AWD,ABS may be trouble with C305 connector (google 'gm c305 connector' for various things it can cause). Gas gauge could also be issue with sensor in fuel tank, AWD/ABS could be problem with wheel speed sensor/wiring.
1. The ABS light, AWD message check engine light and check gauges message all are on when car is turned on.
2. a few seconds after starting it the Brake light comes on and an incessant beeping starts.
3. When turning wheel all the way tot he right a clicking sound can be heard from the front.
CAn anyone hep me out? Where to start. I'd rather not spend a fortune on this and just start replacing things.
Any thoughts? I'm hearing that dinging noise in my head, in my sleep, and it's driving me crazy.
The car is shut down. I can turn key and you will hear a clicking under the dash. But it still won't start.
Battery was weak, needed a new battery.
Welcome to the world of computerized cars.
