Lee
Hopefuly, I've come to the right place for help. My '03 Aztek has been nothing short of superb. Up until June of this year all I've had done was brake pads and oil changes. In June, the front wheel bearings feel apart without warning, other than the anti-lock brake light coming on. The mechanic who did the repair was as shock as I was when he took the tire off. Anyway, that's not my issue today. About 3 weeks ago, the stereo quit. No sound, but it kept full display. When it came back, everything was "poppy and crackled", like a poor AM station in a thunderstorm. Then it put out a sound that I only can compare to a harpooned dolphin, turning it off doesn't stop it, only unplugging it. I was also getting an airbag light while the radio was going through this. I lost complete sound from the back speakers, very poor quality from the passenger side, and the door chimes and warning sounds are faint and static.
I did the un-hook the battery and remove fuse #28, no help. So, I purchased a replacement radio off eBay for $25. Only to find the wonders of GM Theftlock! After a trip to the dealership to unlock, which they didn't(That's another story), I found out that the radio can be tested before it goes into lock. The "new" radio does the same thing. Poor rightside sound, no rear, faint door chime, then it goes nuts and gets the dogs in the neighborhood howling!
By leaving it unplugged, I have no other issues. No warning lights are on. But I need a stereo. Please, any help will go a long way in keeping my sanity. Driving with earbuds is getting ridiculous!
Like I said, gm real fouled up on some if not a majority of the manufacture of the parts need for the Aztek. It is a great concept car that was not thought out. I am strongly considering trading "up" for a foreign suv.
Hhmm seems a trim removal tool would have allowed getting under the panel from inside and gently prying would have allowed release of the retaining clips. Panel would still be held on by 2 screws for handle, and 2 hidden ones under weatherstrip on sides, but panel would still open a bit.
For now, the problem may be with lock actuators (one for each side), something with wiring perhaps.
Hey ray,
I have an 01 Aztec with 69000 miles on it. We had to replace the engine as soon as we bought it 9000 miles ago, but that is a separate piece of drama. Recently, the Service Engine Soon light came on. When I took it to my mechanic, they said that the computer kicked back a message that equated to me having to replace my gas cap. I replaced it, then a week later, the light came on again. I had them clear it off one more time when they told me that it was giving them the same message and then today (three days later) it came back on. So with that said...any thoughts Ray, or any others of us who have experience? Please!
Also when the problem is corrected: The system is checked everytine vehicle is started and it may take several days )and start/stop cycles) for the light to go out on its own.
mechanic...Now i have a terrible burning smell from my air..and sporatically , the air doesnt seem to be cold....but last year i had a new compressor installed..Might i inform you...MY AZTEK is a LEMON. :lemon: ..!! I love it tho..and refuse to sell it....
FUN FUN FUN.....
I just had the same problem and was scouring the internet for a solution. A friend of mine discovered the problem.
I too had the flatline for all of the gauges while the car still worked. We replaced the fuse for the ignition and everything started working perfectly again. Our ignition fuse partially worked as the car still was able to start making us think that it couldn't be this fuse. The fuse was partially burned out allowing it to start but causing the other problems.
I hope this helps!
I completely agree with you and have been trying to get a class action suit going myself. I would be happy to sign a petition and would love it if more people would ban together and get a suit going against GM...these are not isolated problems and GM is well aware that they have dupped all of us...why do think they only made the Aztek for a couple of years???
Let me know if you decide to pursue this in any way.
Lights, Instrument panel, locks all going nuts.
GMC explains their not aware of any problems.
The problem with ours was one of the seals err headgasket was broken, that's why I was saying on my post do not drive the car any further if a piece falls into the engine it will be a very expensive repair bill.
Spending that amount of money is crazy.I noticed that are many non-original replacement parts available for about $60 brand new.Is it worth buying these or is one better of with a used original part?
Can anyone make suggestions where I could find an original used part and I believe its an AC Delco part.
