Lincoln LS Overheating Problems
Mine overheated a few years ago, and wasn't pretty when it came time to pay for what went wrong.
Would you care to repost?
Anyway, it's not cheap. Have it checked out -- could just be a thermostat.
But don't count on it. This'll probably be something that the dealer is going to have to do. It's a pretty unusual system & I don't think I'd want a general-purpose garage learning on it.
Now I have a quick question that maybe you have some insight or opinion on. It's just a crazy idea I've been pondering. No, not the one involving Salma Hayek. This is about my stick-shift Lincoln and gas mileage.
You and I know the LS 5speed is a pretty good car, n'est pas? Sure, it could use a few more HP (like maybe 80) and a bit better mpg would be nice too. There may be ways to get the HP, but this idea only addresses the mpg.
Part of the problem is the 5speed has a 1:1 final drive ratio. THis causes the engine to turn at, what, 2500-3000 rpm at highway speds I think. I should have verified the number b4 I wrote this, but my wife is pretty much the sole driver of the LS now. Anyway, highway mileage should increase if the engine rpms decrease eh?
The tranny is a getrag. getrag also makes 6 speeds. I admit I havent researched at all, but I'm thinking a 6 speed might have a lower final drive ratio? Perhaps finding a 6 speed getrag on a bimmer in a junk yard somewhere and modifying the spline might provide a nice improvement in LS mpg, and maybe increase the torque handling number so that the HP increase could be addressed too?
Any thoughts? Yeah, maybe that Salma Hayek dream is more easily achievable?
Anyway, making a transmission swap in a car like this is certainly an ambitious project. I doubt seriously that the 6-speed has the same external dimensions -- it's unclear that it would even fit. You might be better off going with a taller rear-end ratio, which would of course affect lower gear acceleration as well. I also don't know if the Getrag 6-speed you're considering is an overdrive unit. If not, you won't accomplish anything in the top gear.
Good luck. I wouldn't touch what you're contemplating with an 11-foot pole.
:P
akirby: Very funny :P Actually I think the answer is about 1500 people, though I'm not sure of accuracy of that. Well, actually the number who would WANT a stick shift Lincoln is probably higher, but dealer refusal to order them kept the number low. I wonder what the ratio of auto to manual is in the CTS? The bimmer? Volvo? ...
I think the final number was around 1800. I'm sure the CTS is similarly low - probably 5% or less. Even the BMW manuals are rare - less than 20% IIRC.
I love manuals but I got tired of them in my boring daily commute, even moreso when I get stuck in a long stop-no-go delay. I'm waiting to buy a used 06 GT Mustang with a stick for weekend fun.
Nope. That trip to AK included lots of time at 75-80 and a number of hours between 80 & 90 -- gotta love driving through Eastern Oregon & Nevada.
A few years ago I had the opportunity to set the cruise control at 105 on U.S. 60 in New Mexico & leave it there for most of a half hour. Spent much of the rest of that day well above 70.
My engine was carefully broken-in, which takes at least 5000 miles before the fuel mileage starts to get reasonable. Synthetic oil (Mobil 1) could be a factor as well.
I enjoy that manual every day, as I slip it into neutral & wait to see how slow I'll have to go in the upcoming traffic "situation." Sometimes I drop one gear, but more often it's two or three, before I slip it back into gear -- could be two seconds or 30 seconds later, jerk-free, engine at idle speed all the while.
Gotta love traffic jams.
Thanks too everyone :sick:
I still like this car. :sick: i would like to hear from people that have had this problem fixed.
Any ideas as to what could cause this. I have read many posts and it seems that it could be a number of things.
Can someone specifically say where the Lincoln LS's drain plug is for the radiator? And where is the radiator in the engine?
thank you.
Here is the procedure from the factory service manual:
1. Remove the engine fill cap.
On 3.0L engines
2. Open the engine air bleed.
On all engines
3. Open the heater air bleed.
4. Add coolant to the degas bottle allowing the system to equalize until no more coolant can be added.
On 3.0L engines
5. Close the engine air bleed when coolant begins to escape.
On all engines
6. Replace the degas bottle cap.
On 3.9L engines
CAUTION: Care must be taken to ensure the accessory drive belt does not become
contaminated with engine coolant.
7. Add as much coolant as possible to the engine fill. The heater air bleed will remain open.
8. Replace the engine fill cap.
On all engines
9. NOTE: The heater air bleed remains open.
Start the engine and turn the heater to MAX position.
10. Close the heater air bleed when a steady stream of coolant comes from it, during engine idle.
11. Allow the engine to idle for five minutes, add coolant to the degas bottle as needed to maintain the
cold fill MAX mark.
12. Reopen the heater air bleed to release any entrapped air and close again.
On 3.9L engines
13. Maintain engine speed of 2,000 rpm for 3-5 minutes or until hot air comes from the heater.
14. Return to idle and verify hot air is still coming from the heater.
On 3.0L engines
15. Maintain engine speed of 1,500 rpm for 3-5 minutes or until hot air comes from the heater.
16. Return to idle and verify hot air is still coming from the heater.
On all engines
17. Set the heater temperature setting to 24°C (75°F ) and allow the vehicle to idle for two minutes.
18. Shut the engine off and allow to cool.
19. After the engine has cooled, add coolant to the degas bottle to bring the level to the cold fill MAX
mark.
1) buy the actuator
2) buy a t-40 torque star male socket
3) remove the only cable attached to the pump
4) remove bolts from pump reservior and push to side
5) remove bottom fliud hose from reservior (you will need a form cup to catch fluid in pump)
6) now you have access to actuator with rachet and male star socket
7) loosen the actuator (the middle only turns)
8) screw in the new one and tighten
10 reinstall electric cable and pump hose and rebolt pump reservior
lincoln will run without running hot. caution filling the degas bottle with water may not fill the engine block, you may have to remove any large engine hose and run water directly into engine as well as degas bottle.
jules
I have a 2002 Lincoln LS with the same problem. Where can I buy the electric actuator?
A lot of people tell me to get rid of that hydrauli system and make the fans electric, What do you think?
