-Dennis
Also, in my experience, the CR-V really extracts a large mileage penalty, once you exceed 65 MPH.. So, if you are like me, and do most of your interstate driving around 70-75.. then 22MPG is not far off..
My average fuel mileage is around 23.5-24.5 MPG, with 21 miles each way... 18 miles of that on suburban freeway... I do have an automatic, though, which tachs at a lower RPM than your manual...
I did a little experiment last winter.. Tried to stay under 60 MPH, no full throttle accelerating, etc... I increased my mileage by about 2 MPG... So, try to stay under 65 MPH for an entire tankful, and see what happens..
regards,
kyfdx
I was wondering if anyone has experience pulling a trailer with a CRV. I have a 2004 EX Auto. I've pulled a 1000# enclosed trailer with it a few times on short distances (20mi). It seems as if the transmission smells warm after I've traveled a ways. This makes me a little concerned about how the drivetrain will hold up in the long run.
Any experiences?
Capacity is 1500 lbs, and if the trans seems hot, IMO it would be wise to use the feedback your vehicle is giving you and not push it too much.
Maybe see if you can find an aftermarket oil cooler?
-juice
thanks...
The 11 mpg my Landcruiser gets is forcing me to get rid of it. Too bad, otherwise it's an awesome vehicle. Anyway, drove a 2005 CRV SE today and it was very nice. Like a mini Landcruiser! I would like to get a manual transmission and I know you can't get leather with that. Fine. I want arm rests. Can they be had with a 5 speed EX? If not are there aftermarket pieces available? What do people have to say about the auto transmission on the SE? Will it move ok on the highway? I guess I am assuming that the motor will have more pep with the manual tranny, but if I am wrong let me know! Auto would work for me if people are happy with its performance. Thanks-this forum is helpful.
I also had the previous generation CR-V (127HP), and got a stick-shift, because of the lack of power.. In the new generation, that wasn't an issue, and I equipped mine with an automatic, so that my wife could drive it... Although I miss driving the stick, I've never missed it from an acceleration standpoint.
regards,
kyfdx
As for armrests, Honda does not offer a driver's armrest for the manual. However, you can install one yourself. Check the H and A Accessories link at the top of the page.
The turbo Forester is a whole other story, though. So long as you don't need much passenger space, it's a great car. I'd also be tempted to look at the Hyundai Tucson if interior size isn't a top priority.
Good luck with the shopping.
Jopopsy
My wife's TL is a good example. Because it lacks extra headroom, I am forced to tilt the driver's seat way back. I once put my father in the seat behind me.
"You okay back there?"
He replied, "sure, sure, just fine".
When we stopped and he got out, I asked again. This time I prefaced the question with a statement about how far I have to lean the seat back. This time he said, "Yeah, it's tight back there."
That's why I read a lot of 3 series owners saying that their guests don't mind the backseat. Would you say negative things about a friend's BMW? But the fact of the matter is - there is such a thing as a cramped backseat. The Forester isn't the worst. But it ain't good.
I remember the first time I drove one (1st gen), I couldn't really tell the difference between it and the Impreza from behind the wheel.. I didn't get the "up-high" ride feel, and the back seat seemed just like what you would get in a normal sedan or wagon..
But, to me, it seems you also get more of a car handling/ride... so each vehicle has it's strong points.. I think one of the CR-V's is rear-seat comfort..
regards,
kyfdx
(who always gets to sit upfront)
I think Honda will reserve the V6 for the Pilot, etc.
dewey, "Acura RDX" #110, 18 Jan 2005 10:57 am
P.S... start at the beginning
Nobody knows if it will include a V6. Keep an eye on the Acura RDX concept car that was just shown. Most believe that the next CR-V will be based on that vehicle.
If it does ride like that, aftermarket suspension and tires would probably fix it. Any comments from you SE owners?
Salesman let me put 120lb dog in back seats; brought a blanket from home. Thought that was pretty cool. Drove the SE and a 5sp EX. Both were equally powered; if and when I buy I'll get the AT. Didn't see any advantage to the manual, unlike with the four cylinder motors/auto transmissions of old.
Checked out the Element too, pretty good stuff. If the rear windows rolled down I would get the Element.
SE passed the dog test and has plenty of pep, so now I have to unload the Landcruiser. Selling in the middle of winter isn't inviting..hard to keep cars clean here in VT.
Folk's are right though; each vehicle has its strong points. I deliberated on this for months; most who are common in these forums know.
I will say that the CRV did have more room hands down. However, if you are of avg size and pant length it won't matter which you pick.
Jopopsy
Forester XT is almost in a class by itself right now. It's priced too low to compete directly with the BMW X3 3.0, but it's a lot nicer than the Saturn Vue Redline.
I'd like to see Saturn do a nicer interior and fix the electric power steering.
Better yet let's see more sporty small SUVs, RD-X could fit the bill.
Tucson is decent but it's not remotely sporty.
-juice
So, my question is: can chains be used? If not, can other traction products, such as cable type "chains" be used? What does the owner's manual say?
http://www.detnews.com/2005/autosconsumer/0501/19/G01-63714.htm
Flyingdoc - I see no reason why the cable-style chains would be a problem. I've read of others having concerns because of the RT4WD unit, but not VSA.
Many thanks in advance.
I'm guess that if you're asking about chains, you must be in an area that sees quite a bit of snow. However, if that's not the case, all-season tires and common sense should be enough. Just go easy with the throttle and leave plenty of room for braking.
I have never before had a problem with the CEL, although my second generation CR-V is one of the early ones (2002 with 77000 km).
Has anyone else experienced anything similar?
What's the big deal? Just make sure you tighten your gas cap until it clicks a few times.
The cap is designed to fit exactly so... And, the three clicks insures that it is properly tightened.
So, that is what Honda (and the EPA) were thinking..
http://www.mag-x.com/index_ie_j.html
Bit of "Stream" in the rear-side window. Will probably mirror the RD-X quite closely, maybe with 200 hp vs. RD-X's 220 or so. Can't tell from the pic if it'll (finally) lose the tailgate-mounted spare but as the RD-X won't have one, it may be a good bet. Think they may offer 6 or 7 seats as opposed to bringing over a Stream/Edix derivative?
The CR-V has provided us with 46,000 almost trouble free miles. I say almost because of the numerous recalls/TSBs that kept getting mailed to us. And the fact that at 40,000 miles the A/C compressor locked up on us and bit the dust. $1300 later it was like new.
Other than that mileage varied between 20 and 24.5 depending on the driving. My wife did alot of stop and go driving and numerous short trips of 1 and 2 miles. She never got less than 20 mpg. OEM Tires were eaten up at 30,000 miles.
All in all a very nice car. We probably would not buy another but we wouldn't hesitate to recommend it to others.
Good luck with your CR-V's!
Anyway, I need to add some. Which brand did you add? Green Preston? Or Honda have special OWN brand?
regards,
kyfdx
That would be a pretty big departure for what's been a boxy shape all along.
-juice
Sometimes Mag X publishes good stuff. They got an early sketch of the 2002 CR-V about 4-6 months before details were released. But a few months before that, they showed a photochop that looked nothing like the production model.
I wouldn't get worked up about this one. It's too early.
