Note that most vehicles will NOT ever have all these problems.
I suggest printing these pages, please NOTE these TSB cover many Engines from 4.8L V8 to the 6.6L to the 8.1L so be patient with your technician.
Take your problematic vehicle to the Biggest OR the Best GM dealer within driving distance, be patient, be nice and be Generous to those who help.
Quote:
"448 Technical Service Bulletins May Apply, 2002 CHEVROLET Silverado"
2002 Silverado TSB
These are "brief" descriptions, you have to buy a subscription to Alldata to get the full deal.
The "few" I copied may or may NOT help your issues.
Bulletin No: 00149C
11/21/2003
Summary Description
MALFUNCTION INDICATOR LAMP ON WITH A P0300 SET AND A MISFIRE. VARIOUS MODELS INCLUDING THE 1996-1999 P32 AND THE 1996-2002 GMC C/K TRUCK. *TT
Bulletin No: 3232
5/10/2005
Summary Description:
1999 - 2005 GEN II COLD ENGINE MISFIRE AT IDLE WITH POSSIBLE P0171 AND/OR P0174. *TT
Bulletin No: 3004
08/25/2004
4.8L 5.3L 6.6L 8.1L P1285 P1286 OR P2133 AFTER REPLACING APP SENSOR. *MJ
Bulletin No: 00266
07/02/2004
LOSS OF POWER, HESITATES ON ACCELERATION ON 4.8, 5.3 AND 6.0 ENGINES COUPLED WITH THE 4L60E OR 4L65E TRANSMISSION. *TT
Bulletin No: 100803
01/22/2004
THE ENGINE DIAGNOSTIC FUEL LEAKS INSIDE OF THE ENGINE. GM VOICEMAIL LOG. THIS INCLUDES 2000 - 2004 CHEVROAND GMC C4500 AND 5500 TRUCKS. *TT
Bulletin No:030604059
01/06/2004
REVISED FUEL LEAKS INSIDE OF ENGINE DIAGNOSTIC. 2004 CHEVROLET KODIAK AND GMC TOPKICK ALSO INCLUDED. *TT
Bulletin No: 3147
11/02/2004
CONCERNS REGARDING BULLETIN 00-02-35-003F. ALL FULL SIZE TRUCKS AND UTILITIES AND HUMMER PARTS AVAILABLE. *TC
Bulletin No: 04039
07/13/2004
CHEVROLET\GMC SERVICE CAMPAIGN: SEE DOCUMENT SEARCH BUTTON FOR OWNER LETTER. SPECIAL POLICY ADJUSTMENT - INJECTORS - REPLACE. *MJ UPDATED 2/21/08. *NJ CSC LETTER WAS RECEIVED. UPDATED 3/5/10. *PE
Bulletin No: PIP-4138K
06/08/2011
GM: THE SERVICE ENGINE SOON LIGHT IS ON, THERE IS ALSO A MISFIRE OR ENGINE NOISE. THERE ARE MULTIPLE POSSIBLE CAUSES.
Bulletin No: 5500
11/10/2005
THE IGNITION DISTRIBUTOR CAP AND ROTOR MAY CORRODE AND CAUSE IGNITION SYSTEM FAILURE. A PRODUCT EMISSION RECALL TO INSPECT / REPLACE THE DISTRIBUTOR IGNITION SYSTEM. *TT GM PARTS BULLETINS & INFORMATION. *TT
Bulletin No:050604007
11/08/2005
POOR ENGINE PERFORMANCE - MISFIRE, ROUGH IDLE, STALLS, ENGINE CRANKS BUT DOES NOT RUN, SERVICE ENGINE SOON/CHECK ENGINE LIGHT ILLUMINATED, DIAGNOSTIC TROUBLE CODE (DTC) P0300 SET. *TT
Bulletin No: 030604030
08/14/2003
MULTIPLE DRIVEABILITY SYMPTOMS OF LONG OR HARD STARTS, CHUGGLE, ROUGH IDLE AND LIGHT OR INTERMITTENT MISFIRE DUE TO CLOGGED FUEL INJECTORS. *TT
Bulletin No: 050604029
1/03/2005
FLEXIBLE FUEL (RPO L59) ROUGH IDLE, MISFIRE, MALFUNCTION INDICATOR LAMP DIAGNOSTIC TROUBLE CODE P0300. *TT
Bulletin No: 3317
10/28/2005
HARD START / NO START OUTSIDE TEMPERATURES BELOW FREEZING. *TT UPDATED 7/13/09. *PE
Bulletin No: 3325
0/27/2005
SUPPLEMENT TO BULLETIN 99-06-04-047A FOR FUEL SYSTEM CLEANING. *TT
Bulletin No: 3312
10/27/2005
NO START, HARD START, LOSS OF POWER, OR WHITE SMOKE. *TT
Bulletin No: 050604024
05/13/2005
REVISED DIAGNOSTIC TROUBLE CODE (DTC) P1172 AND DTC P2636. *TT
Bulletin No:50604025
05/13/2005
REVISED DIAGNOSTIC TROUBLE CODE (DTC) U2104. *TT
Bulletin No: 040604088
05/12/2005
REPLACEMENT OF CONNECTOR WHEN REPLACING FUEL TANK MODULE/FUEL PUMP MODULE. *TT
Bulletin No: 3375
05/11/2005
ROUGH IDLE, SERVICE ENGINE SOON (SES)LIGHT, UNSTABLE IDLE, HESITATION, SURGE OR STALLING. WITH DIAGNOSTIC TROUBLE CODES P0300, P0335 OR P0336. *TT
Bulletin No: 11062003
04/11/2005
AIRFLOW SENSOR PROBLEM. *EH
Bulletin No: 040603002
03/10/2005
DIAGNOSTIC INFORMATION FOR INTERMITTENT VEHICLE NO CRANK DEAD BATTERY. *EH
Bulletin No: 040604007A
3/08/2005
SERVICE ENGINE SOON (SES) LIGHT, P0087, P0093, P1093, LOW POWER, NO START, HARD START, FUEL IN CRANKCASE. THIS SERVICE BULLETIN REPLACES 040604007. *EH
Bulletin No: 030604036
03/07/2005
INFORMATION ON SERVICING FUEL INJECTORS TO AVOID CONTAMINATION. *EH UPDATED 03-19-07. *KB
Bulletin No: 040601018
12/15/2005
INFORMATION ON REVISED DESIGN OF INTAKE GASKET AND RELATED BOLTS FOR 2004 MID-YEAR ENHANCEMENT AND PRIOR YEAR SERVICE USAGE. *TT
Bulletin No: 040604007E
02/15/2005
SERVICE ENGINE SOON (SES) LIGHT, P0087, P0093, P1093, LOW POWER, NO START, HARD START, FUEL IN CRANKCASE. *TT
Bulletin No: 040604040
02/15/2005
IDLE INSTABILITY, LOW OR ROUGH IDLE WITH ELECTRONIC THROTTLE CONTROL. *TT
Bulletin No: 3239
01/31/2005
LB7 ENGINE VIBRATION MISS OR RUNS ROUGH NO DIAGNOSTIC TROUBLE CODE. THIS ALSO INCLUDES LB7 C2 C3 C4 C5 D4 D5 E4 E5 K2 K3. *EH
Bulletin No: 3232
01/28/2005
MISFIRE AT IDLE COLD AND POSSIBLE P0171 AND OR P0174. *EH
Bulletin No: 040849019
01/11/2005
CRANKS BUT NO START, STALL, INACCURATE/INCORRECT FUEL GAUGE READING, NO FUEL, VEHICLE IS OUT OF FUEL AND FUEL GAUGE READS ABOVE EMPTY. *TT THIS BULLETIN REPLACES PREVIOUS BULLETIN NUMBER 04-08-49-019. *TT
Bulletin No: 040604001
1/03/2005
VARIOUS INTERMITTENT DRIVEABILITY CONDITIONS - HESITATION, LACK OF POWER, ETC. *TT
Bulletin No: 3149
12/15/2004
FUEL PRESSURE REGULATOR CONNECTOR OR TERMINAL REPAIRS. *TT
Bulletin No: 3187
12/15/2004
ENGINE LOW POWER WILL NOT GO OVER 2300 RPMS. *EH UPDATED 6/11/10. *PE
Bulletin No: 3056
11/17/2004
CHECK ENGINE LIGHT WITH A P0300 DUE TO 2-4 CYLINDERS MISFIRING ON THE SAME BANK OF THE ENGINE. *TT
Bulletin No: 3107
11/04/2004
P0420 AND P0430 DTSC IN THE DETROIT, MICHIGAN AREA WITH GEN III V-8 ENGINES. *SC
Bulletin No: 3119
11/04/2004
ENGINEERING INVESTIGATION - CATALYTIC CONVERTER REPLACEMENT. *SC
Bulletin No: 3121
11/04/2004
6.6 LB7 ENGINE WITH A NO CHARGE CONDITION WITH DIAGNOSTIC TROUBLE CODE P0380 P0621. *SC
Bulletin No: 3055
10/14/2004
Summary Descr
Only about HALF of them showed up, NO warning from Edmunds that I was running over the text limit.
Anyway folks, follow the link, see if your vehicle meets some of the issues, or better yet, tell your Tech to stop being so cheap and buy an Alldata subscription.
Can yo imagine, looking through 448 TSB
Good Luck
Rusty Wrench
Do you get any codes ?
2002 Chevrolet "Truck"?
Theres quite a few TSB on the 1500 pickup, several include running conditions..
check them out, and see if your wrench can identify the issue.
Sometimes it's cheaper to let a "good" dealer to diagnose the problem
2002 Silverado 1500
the only code that comes up is a misfire on multiple cylinders! yes it is a truck.
-B
Check the throttle position sensor?
1- TURN IT IN & BUY AN OTHER ONE, BEFORE SOME THING GOES BAD.
2- SPEND A LOT OF MONEY AT THE DEALER TO TRY TO FIND THE PROBLEM .
3- JUST TO DRIVE US NUTS THINKING WE HAVE A BIG PROBLEM.
OUR TRUCK RUNS FINE ACCEPT FOR THAT CODE, THEREFORE WE DO NOT CARE HOW MANY TIMES IT FLASHES.
I SAY ENJOY YOUR TRUCK FORGET THE CODE 300.!!!!!!!!!!
SAINTLEN, MACH. FOR OVER 50 YEARS.
about 3 months ago I bought a GMC sierra 2012 V6 4.3L from the showroom brand new.
Last month it went for its first 10 000km service, but from around 5000km on the car I have had a problem with my car not wanting to pull away, for example when I am at a roundabout and i need to press the accelerator to go forward, the car does not move, it goes forward really slowly and then makes a loud bang noise from the right front side of the engine, only after this sound comes the car has its normal speed back and moves.
Though this problem only happens sometimes. somedays this does not happen and other days it does it 3 for times.. I have been to the Main GMC service centre several times and the assistant manager even took it for a test drive but this problem did not happen with him in the car. now he is accusing me of lying.
Does anyone have this problem or know what it might be, it will be a great help.
ps. my car has been more in the service center than i have actually driven it.. :'(
Sarah, GM Customer Service
I have a 2003 silverado 4.3L that I have an issue with when I try to accelerate. I turn the truck on and it turns on perfectly fine, when I put it in gear and try to take off it stalls like if gas was being restricted, this is only when i have it in drive! I can drive it but it will stall literally every other second and i've noticed that when it blows black smoke. It doesnt give me any check engine light, put a scanner in and no codes....I have replaced fuel pressure regulator, fuel pump, fuel injectors and fuel filter and not it does this...any help will be appreciated.
kcram - Pickups/Wagons/Vans+Minivans Host
I HAVE FOUND 3 GOOD FORUMS TO POST THIS TRUTH, PLEASE LET ME KNOW OF ANY OTHER GOOD FORUMS TO POST TO........THANKS FOR LISTENING TO THESE 100% TRUE FACTS
I understand the frustration you're feeling with your vehicle and apologize that the dealership hasn't been able to find the cause of your concerns. Have you spoken to GM Customer Service about this issue? If not, we'd like to set up a customer case for you within our system to document your transmission shifting concerns. If this is of interest to you, please feel free to email me at socialmedia@gm.com [attn Amber]. Please reference this post and include your full name, VIN, mileage, and dealer. Please feel free to include your screen name as well.
Amber N.
GM Customer Care
Again, I understand that this situation is highly frustrating for you, and I apologize that your vehicle hasn't been fixed yet. I would be more than happy to take a second look at your case to ensure that every option is being considered to resolve this issue for you. If you decide to hire a lawyer however, I am no longer allowed to assist with this situation.
Amber N.
GM Customer Care
Have you been working with your dealership for the shifting issue or have they not been able to recreate the problem? If you'd also like for us to start a case for you in our system and try to look more into this situation for you please let us know.
Amber N.
GM Customer Care
I'm helping a friend out with his 2002 GMC Sierra 1500 4x4 w/ 4.8 vortec engine(recently bought used) approx. 90,000 miles. It began to stall about 2 weeks ago and today after picking it up from the shop, it stalled in the middle of an intersection after a red light. When it stalled, he described it as, "it started hopping around and shaking. All the electronics shut off and it took about 15 minutes for it fire back up."
I pretty much have it narrowed down to 3 possible issues; crank shaft position sensor, idle air sensor, altitude sensor. I know that all 3 of those possibilities will not immediately produce an error code, if one at all. I hooked my code reader up to it anyway and I got nothing out of it. These are all fairly probable causes for it to stall. From his description, I am leaning towards the crank shaft position sensor. But why would the crank shaft position sensor cause the electronics to shut down with the ignition on?
So far I haven't found any issues with the alternator or transmission(that would cause it to stall).
Does anyone have some advice to throw my way, besides cleaning the sensors and checking the grounds(basic initial diagnosis steps).
Any useful info will be greatly appreciated. Thanks.
pump to the injectors along with various sensors, the problem ultimately came down to the pick up on the distributor having crumbled magnets. After changing all that we did in the fuel system (which was going to happen in the restoration anyway so I don't feel so bad. Truck only had 74,000 miles on it), after finding the distributor issue and setting the timing, the truck ran like a brand new vehicle. My mechanic friend had just recently had another Chevy truck with a similar issue to what I was experiencing and when he checked the distributor, it had cracks in the pick up magnets as well. Solved the issue right away. So, if you have hesitation issues and have tried all your sensors and still having issues, it is worth taking a look at the pick up magnets in your distributor to look for cracks. From what I was told, this will not trigger a check engine code for some reason. Good luck!!
