Oh yes, did put a small fan on the center hump for a few hours to dry it out after repair. (about 4 hrs.).
Do you, sure you do, have trac control? Best do some checking as to sizing that it does not through off your trac contol/abs in the computer and shut down the engine.
Had a proplem with 75R fronts against 70R rear mistake by the tire guy and it shut our 98 TC down. I imagine it would have a bearing if the tires were reversed, front to rear.
Snow tires have the agressive tread. Took a dealer 5 hours to get it diagnosed via factory representive. At hour 4.5 the rep. asked if any tires we of larger or smaller size. BINGO Tire guy had a large bill to pay pluse two more new tires for compensation and shop time at dealer..
happy hunting :shades:
No need to pay $200 to the dealer, I fixed mine and cost $5.00 silicone sealer or you can use a rubber gasket.
After you done with the repair is a good idea the lift the carpet out of place and let dry, just a vacum wont do it, it will remain wet for long time and you wont be able to know if the leak is gone. After is dry have someone wet the car with the garden hose while you visualy inspect under the dashboard to make sure water is not comming in. Sounds hard but is not. I did it, takes about an hour plus the drying time. HAVE FUN!
jessetheoutlawoutlaw@yahoo.com
I have the exact same problem. I started troubleshooting by duck taping over the key hole thinking the seal around the key hole might be leaking. That didn't fix it. Next I duck taped over the two holes at the leading edge of the trunk lid just under the back window. It hasn't rained so I don't know the results yet.
Dom
My problem was finally resolved by replacing the chrome trim that surrounds the license plate. Seems someone at the factory didn't properly caulk it, which eventually caused minor cracking of the trim on the inside surface, where nobody could see it. Hasn't leaked since! The dealership honored the replacement by not charging me because it was obviously a factory error.
Hope this helps.
Mr.B
My issue with leaks turned out to be the hood release cable.Water getting in thry that area.
