Nissan Murano Power Seat Problem
in Nissan
I've been having a problem with the power Driver's seat in my '03 Nissan Murano. It is loose and shifts side to side when I turn corners. I contacted my dealer and they said that the Lifter Link Slide Assembly was broken and would need to be replaced at the tune of $600. There is a TSB (Technical Service Bulletin) out on this exact problem. Since my vehicle is out of warranty, Nissan North America has refused to fix it and therefore, own up to this safety issue. I would hate to see what would happen during a crash. I filed a complaint with the NHTSA. If you have had this same thing happen with your Nissan power seat, please file a complaint with them.
http://www-odi.nhtsa.dot.gov/ivoq/
First the seat would be lose like excessive movement for some time, then all of the sudden it will eventually break.
I am about 250 ponds and that dose not seam to be excessive enough to break the back bottom cross bar under the drivers seat. (I'm sure this is a expensive repair)
This was very dangerous and scary for someone who is unsuspecting of this issue.
Everyone and anyone who has experience this problem or know any information about this,please file with http://www-odi.nhtsa.dot.gov/ivoq/
Thank you 03muranosl for posting that information.
Thanks for reading.
I will report this because if you are ever in accident I'm not sure the seat is secure
when I asked about the cost for repair and what was involved, parts and labor are approx. $1,000. Incredible. They said I need to replace the entire seat bottom assembly (I weigh 200lbs). Said the assembly just comes apart and is not repairable. I asked the service guy at the dealer ship if this was a common problem, said they'd fixed 4 in recent months. He told me even with an extended warranty, this still would not be covered. With this kind of service, I think this will be my last Nissan product. Very disappointed.
Dealer Diagnosis: (and a no thank you)
1- Driver seat...broken track $600 part $200 labor. :lemon:
2- Airbag light...needs new "module" $800part $200 labor. :lemon:
3. Visor....$300 part $75 labor. :lemon:
Personal Diagnosis:
1-The power driver seat has a "weak link". It's not a "track" it's a bracket (see post #3) that was not designed strong enough and eventually shears off at two points...I've got the pictures to prove it. I'm going to see if i can get it welded back together by my mechanic. Taking the seat out is fairly easy. And a small weld job should be fairly inexpensive.
2. The airbag module can be sent to a company in Texas to have it "reset" for $50 to $100, instead of replacement for $1,000. It's tricky to get to (and that's where the dealers get you) but easy to remove once you get to it. This is for the mechanically inclined but is doable if your time is worth less than $100-200 per hour.
3. The visor i haven't figured out yet.
This is a great car to drive...if you don't mind spending lot's of extra money to keep it healthy.
Note: Transmission service needs to be done at the dealer $300 every 30K. The spark plugs are not for the weekend mechanic another $200-300.
Nissan...has lost my business.
I also went to the NHTSA and filed a complaint.
http://www.odi.nhtsa.dot.gov/ivoq/
I just had this happen to me today. My seat started to lean to the left and while driving broke. Now I have to fugure out how to fix it since my car isn't under warranty.
Any suggestions?
The cost of the parts and labor was $205. Cost of moving the seat back, so it doesn't happen again...$0.
How much should one expect to pay to have this fixed with a welding? Does the average autobody shop do this sort of thing or should I look elsewhere?
You stated that you made a metal gear due to the stripped nylon gear. Do you have the specs or are you willing to make one for me?
Thanks - I have a stripped gear right now. Nissan will not see the gear only - you have to buy the whole seat assesbly ($800). Junk yards are also not receptive to selling just the gear, either.
Nissan took care of the first repair with 'good will' This morning the request was declined. It is a $919.40 repair. I have since contacted NissanCustomer Service, as I too, believe that this is a design/manufacturing issue. Will keep you posted on the progress.
Do you have a contact from NHTSB and a file number?
Luckily, I sit with the seat all the way back, but my wife can't drive it now without having the seat all jacked up.
I would think this is a large enough safety issue to warrant a full recall and not just a TSB.
For everyone else who has power seats, you might want to consider turning off the automatic seat retraction when you get out of the car. It really isn't needed, and it increased the wear on this gear at least 2x. This might save others from an expensive repair.
With an 05, you should still be close enough to your warranty that they should accomodate you. . Talk to your Service MANAGER - not the writer. Ask them for the Zone Rep's name and number. The Zone Rep for my area got back to me the day after I contacted him. He then called me back three days later with their decision, as he promised they would. I was very pleased that they did the right thing. Based on their service, I am seriously considering a new Rogue...Good luck to you...Explain that the seat frame is not like a mechancial part, that could be anticiapted or expected to wear out. It's obviously a design defect, that they should be repsonsible for.
Great vehcile otherwise, still one of the best looking ones on the road
I filed a complaint with NNA consumer affairs and they denied any warranty assistance even though the issue originally manifested during the warranty period.
What is quite clear is that the drivers seat issue is a very common one. A search of NHTSA reveals hundreds of cases where the seat has failed on 2003-2006 Muranos. Nissanmurano.org also has a long running thread on the failure.
I urge everyone who has had a seat failure to file a report with NHTSA - its the only way to protect yourself if the part fails again, and you have to pay ~$1000 to repair it like me.
I just experienced the same problem with my 2005 Murano and i would like any suggestions possible on how I should go about trying to get this problem repaired. after reading all of these posts it seems like this may be a very big problem. Does anyone have any pointers on what i should say or do in this instance? :sick: Does anyone have a contact for NHTSA & file number?
here's another clue - if by chance you have a new congressman - link there office to this issue.....
For those of you out of warranty, I suggest getting it welded. The weld that connects the bar to the seat frame is what breaks.
If there is anyone who could help me resolve this issue i would greatly appreciate it! I never thought I would have this kind of issue with this vehicle! nissans response to an obvious design flaw is utterly irresponsible
Granted the seats should handle this, but this is a stop gap solution for those that don't like taking the seat in every few months.
Some of you mentioned that you can just buy the frame without replacing the whole seat. If you do this, did you repair it yourself, or did you take it to a professional? If I buy the frame, what part do I order?
http://www.safercar.gov/ or http://www-odi.nhtsa.dot.gov/. Please let's make them pay....
I have sent the link to this town hall discussion to the Automotive columnist in our local newspaper. You should do the same. You should also try calling your local TV 'consumer warriors' February is sweeps period, they are always looking for these kinds of stories - big corporations and no customer service. The more bad publicity we can get Nissan, the better chance we have of getting the issue addressed and properly administered.
What's the number and city of your dealer?
Mine's charging $850 for the part and $420 for labor!
